bobnoffs
Joined: 04 Jul 2012 Posts: 137 Location: northern wi.
Posted: Sat Mar 26, 2016 4:26 pm Post subject: fused or not |
i am mounting my capacitor about 3 inches from the main bus.i planned on connecting straight to the bus main lug with #12 wire and no fuse. should i fuse the cap. for 3'' run?
bob noffs
ceengland7(at)gmail.com Guest
Posted: Sat Mar 26, 2016 6:36 pm Post subject: fused or not |
On 3/26/2016 7:20 PM, bob noffs wrote:
| Quote: | i am mounting my capacitor about 3 inches from the main bus.i planned
bob noffs
Context?
If this is a filter capacitor for a dynamo alternator, shouldn't be a
problem.
Posted: Sat Mar 26, 2016 6:59 pm Post subject: Re: fused or not |
12awg seems way too big.
There is not much danger for a 3" wire shorting out. But capacitors have been known to short, not likely but possible.
_________________ Joe Gores |
Posted: Sun Mar 27, 2016 4:23 am Post subject: fused or not |
At 07:20 PM 3/26/2016, you wrote:
| Quote: | i am mounting my capacitor about 3 inches from the main bus.i planned on connecting straight to the bus main lug with #12 wire and no fuse. should i fuse the cap. for 3'' run?
 bob noffs |
No . . . that wire is not at-risk for
generating any smoke or burning of
other wires. No would a fuse prevent
the very rare condition where the capacitor
goes bad, swells up, smells bad and sometimes
bursts . . . the things should be on your
periodic replacement list . . . say every
5 years or so.
Also consider experiments to see if the
capacitor is necessary/useful. I've not been
able to measure any operational utility beyond
helping us get some PM alternator/rectifiers
to self-excite.
bobnoffs
Posted: Sun Mar 27, 2016 4:35 am Post subject: fused or not |
thanks guys for the info. i am told it is to keep noise out of the ecu.
bob noffs
On Sun, Mar 27, 2016 at 7:20 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
 bob noffs |
5 years or so.
to self-excite.
bobnoffs
Posted: Sun Mar 27, 2016 4:40 am Post subject: fused or not |
i guess i don't really know how much a cap. pulls initially. i am sure somewhere i saw a schematic using 12 ga. if this is overkill what is recommended for a 10000uf?
bob
On Sat, Mar 26, 2016 at 9:59 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=454201#454201
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Posted: Sun Mar 27, 2016 5:05 am Post subject: Re: fused or not |
I do know what wire size to use for a 10000uf capacitor. But a capacitor only draws lots of current when it is first energized. And that is for such a short time (less than a second) that the wire does not even begin to warm up. A wild guess would be to use 18 awg. Maybe someone more knowledgeable will answer.
yellowduckduo(at)gmail.co Guest
Posted: Sun Mar 27, 2016 5:41 am Post subject: fused or not |
FWIW I agree if there is no battery in the circuit.
If there is a battery then my advice would be to forget the capacitor.
I've run for many years without a capacitor with a 20 amp PM alternator
and a small battery. I've run many different ecu based electronic
devices (homemade and commercial) without a problem and without any
evidence that a capacitor would add any value. Even running my ignition
off that system makes no practical difference. Who needs extra parts and
extra maintenance issues. Lots of urban legend involved with the use of
this large capacitor from what I can tell. I'm not saying the battery
replaces the capacitor, I'm just saying that I've no experience running
without a battery.
Ken
On 27/03/2016 9:05 AM, user9253 wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=454211#454211
bobnoffs
Posted: Sun Mar 27, 2016 8:27 am Post subject: fused or not |
well........one failure mode of an engine with elec pumps etc. is alternator power only. whether or not i ever need the cap. is another issue but it was recommended i use one. this is for the honda/viking 110 installation.
bob
On Sun, Mar 27, 2016 at 8:39 AM, C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
I've run for many years without a capacitor with a 20 amp PM alternator and a small battery. I've run many different ecu based electronic devices (homemade and commercial) without a problem and without any evidence that a capacitor would add any value. Even running my ignition off that system makes no practical difference. Who needs extra parts and extra maintenance issues. Lots of urban legend involved with the use of this large capacitor from what I can tell. I'm not saying the battery replaces the capacitor, I'm just saying that I've no experience running without a battery.
Ken
Joe Gores
br> fts!)
r> > href="http://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Posted: Sun Mar 27, 2016 9:59 am Post subject: fused or not |
At 08:05 AM 3/27/2016, you wrote:
I do know what wire size to use for a 10000uf capacitor. But a capacitor only draws lots of current when it is first energized. And that is for such a short time (less than a second) that the wire does not even begin to warm up. A wild guess would be to use 18 awg. Maybe someone more knowledgeable will answer. |
that short of run would be fine with 22AWG
but most of the TC world uses 20AWG minimum
under the cowl just for mechanical robustness.
Posted: Sun Mar 27, 2016 10:34 am Post subject: fused or not |
At 07:33 AM 3/27/2016, you wrote:
| Quote: | thanks guys for the info. i am told it is to keep noise out of the ecu.
 bob noffs |
That IS the legacy rationale for adding such things
and it's a deeply rooted idea did
a failure analysis on a modern, 100A alternator
that came equipped from the factory with a 680uF
electrolytic capacitor mounted right to the back
of the alternator.
[img]cid:7.1.0.9.0.20160327122948.0099ede8(at)aeroelectric.com.0[/img]
I am quite certain that noise from this alternator on
EMC laboratory equipment would not be materially
reduced for having added the capacitor. I'd
LOVE to see an EMC test report that illuminates
the 'benefit'.
I just purchased a spectrum analyzer that sweeps
down to 1Hz and up to 2.4 Ghz. When I begin
development testing on the next generation of
PM alternator rectifier/regulators for B&C I will
quantify the value of adding this component
to our airplanes.
213.13 KB |
7973 Time(s) |
