Elevator/Stabilizer hinge ass'y
Goto page Previous  1, 2, 3
patrickjladd(at)hotmail.c
PostPosted: Fri Mar 25, 2016 2:50 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
Richard,
re your first item on the list.
I had a few flights, always solo in my new Xtra. One notch flap for take off
solo and `knew` the trim position. First heavy passenger, first notch of
flap, same automatic set of trim position. Open throttle, tail up, speed
build up a little slow, no problem, plenty of room. She didn`t lift off. Bit
of back stick. Still firmly on the ground. Speed still building with me
pulling harder and harder. Just crept into the air and squeaked over the
hedge. The passenger never knew there was a problem. I adjusted the trim
next time and everything was fine but I was astounded how immovable the
stick was when I was fighting the out of position trim.
This was the first tip I passed on to the new owned when I finally sold her.
Pat
PostPosted: Fri Mar 25, 2016 5:23 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
byoungplumbing(at)gmail.c
PostPosted: Fri Mar 25, 2016 6:06 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
Instability. Kolbs are unstable. You can add dihedral to a Firestar or Firestar II and they will become stable. The MKIII will not. Don't know about doing it to the Xtra, the Firefly or the Slingshot. Just so you know.
Xxxxxxxxxxxxxxx
When I rebuilt my mkiii I doubled the dihedral. I went from negative to neutral roll stability...   I think if I had increased a bit more that I would have ended up with positive roll stability.   Mbg,,  my best guess..
Boyd
PostPosted: Fri Mar 25, 2016 6:29 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
Kolbers:
The only reason Homer put any dihedral in the Kolb wings was to prevent the wings from looking like they were drooping when the aircraft was sitting on the ground.  He would have used zero dihedral because he preferred getting more performance than stability.
Jasper, Tennessee
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of B Young
Sent: Friday, March 25, 2016 9:04 AM
Subject: Re: Re: Elevator/Stabilizer hinge ass'y
Xxxxxxxxxxxxxxx
Boyd
ceengland7(at)gmail.com
PostPosted: Fri Mar 25, 2016 7:15 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
On 3/25/2016 12:22 AM, Larry Cottrell wrote:
I do hope that you are right. Personally I came to the conclusion that
if he looked in the mirror he would see the "bully" that he was
describing. I guess he reminds me a bit too much of Jet Pilot. :-/ I
guess I prefer do'ers rather than talkers. I probably spent too many
years as a cop, and my belief in my fellow man was most likely
stunted. Smile
I shall wait with interest, and hope for the best.
Larry
Who and what are you talking about? For those of use who get individual
emails from the list, what you see above is all we see when you post a
message like this. Are you talking about one of the people that
responded to Bill Berle's questions? Because that could be any of a
number of responders.
In the context of the elevator/stabilizer discussion:
As a somewhat disinterested observer (mostly lurking here because I
would like to own a Kolb in the future), I'd have to say that most of
the responses to Bill Berle's questions have been, well, more like
watching the current presidential debates than reasoned,
scientific/engineering based answers. Most have, at least in spirit,
accused Bill of being a communist fascist atheist muslim terrorist for
even suggesting that anything Homer designed might be less than perfect.
All he really asked for is an explanation of why a particular mechanism
was designed the way it was. It should have been easy enough to simply
say something like, 'Every design is a compromise, and it was done that
way because it's strong enough to be safe, and allows a simple
implementation of another feature (like folding the tail).' Instead,
because no one seems to know the answer, the questioner was attacked for
asking a legitimate question about a design point that is apparently
outside common engineering practice.
I'd like to commend Bill for maintaining a thick skin and sticking
around after all the attacks. Most would have given up and gone
elsewhere for answers. Which, Bill, you'll probably need to do, since
all that's available here is a religious devotion to Homer and his
preaching. Smile
w0odi
PostPosted: Fri Mar 25, 2016 1:36 pm    Post subject: Re: Elevator/Stabilizer hinge ass'y Reply with quote
Kolb List..... I am a lurker that is in a holding pattern over a possible future purchase of a Kolb Firestar II.... I have heard nothing but good and here I go.....
I am going to open up another can of worms....the tail seems fine to me but it is those little u-joint attachments of the wings that make me nervous..the wing attachment is as Bill called the tail a little "wonky" but far be it from me as I am a current quicksilver sport 2s owner and know only what little i have read and seen with my own eyes...never gave the tail much thought but the folding wings I have had more than a passing thought about.... Now all of you guys can give me hell and rightly so because I truly know very little about the machine other than it has REALLY intrigued me ever since I saw my first KOLB at Oshkosh in 1991 and I was in awe of its performance.....never saw anything that took off like the kolb short of a helicopter.... Please guys know I am not bad mouthing the design or the aircraft or Mr. Kolb... I just don't know enough about the design of the wing folding mechanism/attachment and the unknown can sometimes lead to fear for no reason...
Larry
victorbravo(at)sbcglobal. wrote:
Understood, but in this case the person in question is sharp as a tack. It's MY cognitive acuity that is suspect !
Bill Berle
On Mon, 3/21/16, Eugene Zimmerman <etzimm> wrote:
Subject: Re: Elevator/Stabilizer hinge ass'y
To: "Kolb list" <kolb>
Date: Monday, March 21, 2016, 3:13 PM
On Mar 21,
2016, at 1:55 PM, Bill Berle <victorbravo>
wrote:
So I called a friend of mine who is a
retired aerospace structural engineer, with 50+ years of
experience.
LOL
The cognitive acuity of anyone with
50+ years of experience should probably be
suspect.Trust me, I have
50+ years of experience.  Wink
PostPosted: Fri Mar 25, 2016 2:04 pm    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
Let me be the first... the wing rear hinge looks to be pretty well designed to me. The majority of the flight loads are taken by the massive main spar, in this case including most of the torsional loads.. The drag / anti-drag loads, and fixing the wing angle of incidence (wing mounting angle) are the only significant loads on the rear attach. Built per the plans it looks perfectly good for an aircraft witth his weight/speed/load
Make no mistake, the people here who lit a fire under me (for asking a question they didn't like) were 100% correct in saying that the fleet safety history of the Kolb is high. My poking back at them was limited to the hinge and elevator pivot, which once again has a very low if any failure rate.
The fact that I might want to ask a few pointed questions does not mean that the airplane is unsafe. The problem over my questions was a technical, even academic one. I sand by the question, but the reason things got out of hand is because nobody was able to answer the specific "design practice" aspect of the hinge.... not that the hinge was or was not shown to be unsafe.
From all the research I've done, I decided to go look for a Kolb FireStar and get one. For whatever it is worth I will highly recommend the FireStar, even before I have flown one.
Bill Berle
Date: Friday, March 25, 2016, 2:36 PM
"w0odi" <woodyz1957(at)gmail.com>
Larry
> Bill Berle
> www.ezflaphandle.com  - safety & performance
upgrade for light aircraft
> www.grantstar.net           - winning
proposals for non-profit and for-profit entities
>  To: "Kolb list"
>  On Mar 21,
years of
>  experience.
>  LOL
http://forums.matronics.com/viewtopic.php?p=454149#454149
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
more about
Gifts provided
www.buildersbooks.com
              -Matt
Dralle, List Admin.
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
R. Hankins
PostPosted: Sun Mar 27, 2016 6:49 pm    Post subject: Re: Elevator/Stabilizer hinge ass'y Reply with quote
Larry,
Legitimate question, not a can of worms at all. Here is my experience with the wing fold mechanism.
I remade my left wing fold attach fitting a few years back to change the angle of incidence in the left wing. This allowed me to trim out a slight roll tendency at high power settings without an ugly trim tab. Knowing the consequences of a poorly made part here, I cut out five sets of parts. I welded one up and then destroyed it. Changed my welding technique a bit, made another and smashed and pried until it failed. The fourth one is on my airplane. You would be amazed how difficult it was to break even the first one with shallow welds. It took no end of prying, bending the ears in a vise and smashing with a 4 lb hammer to get it to break.
I beveled the edges on the rest of the parts to get better penetration on the welds. The second took a good half hour of work to destroy, but I finally got one of the weld joints to start to split. I made one more adjustment and built the third. I mangled it badly but could not get the welds to fail. I wish I had taken a picture of how badly I smashed, bent and chewed on that fitting. It was seeing the fitting take that kind of abuse that gave me the confidence to put the fourth one on my airplane.
That is a long way of saying, don't worry about the folding mechanism. It is a strong and elegant design.
Roger in Oregon
1992 KXP 503 - N1782C
w0odi
PostPosted: Mon Mar 28, 2016 5:45 pm    Post subject: Re: Elevator/Stabilizer hinge ass'y Reply with quote
Thanks Mr Hankins for the info and I also wished you had taken pics also that would valuable in showing everyone how strong the attachment really is... Thanks again
Larry
R. Hankins wrote:
Larry,
Dennis Kirby
PostPosted: Tue Mar 29, 2016 6:28 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
Kolb Friends -
This has been a lively discussion ... precisely what this forum is intended to bring out.
I ask, however, if we could please follow Matt's guidelines to crop all the previous discussion thread that is not pertinent to the poster's direct point.
We're seeing MILES of previous post material following someone's short reply. I'm getting carpel-tunnel in my right index finger trying to scroll down to the next message ... and it's all unnecessary text to the context of the actual post.
Not tryin' to be the List policeman here. Just asking that we try to be a bit more brief in our responses.
Thanks, everyone ...
Dennis Kirby
rickofudall
PostPosted: Wed Mar 30, 2016 11:17 am    Post subject: Elevator/Stabilizer hinge ass'y Reply with quote
I think this may be the record for discussions on the Kolb forum. Wow, and I was there to see it. I'll tell my grandkids someday when they're big enough.
Rick Girard
On Tue, Mar 29, 2016 at 9:28 AM, KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS <dennis.kirby.3(at)us.af.mil (dennis.kirby.3(at)us.af.mil)> wrote:
--> Kolb-List message posted by: "KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS" <dennis.kirby.3(at)us.af.mil (dennis.kirby.3(at)us.af.mil)>
Kolb Friends -
Dennis Kirby
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
“Blessed are the cracked, for they shall let in the light.”   Groucho Marx
Page 3 of 3
