BNC connectors and SWR
fvalarm(at)rapidnet.net
PostPosted: Wed Mar 16, 2016 9:51 pm    Post subject: BNC connectors and SWR Reply with quote
I am considering moving a VHF Comm antenna to the upper rear fuselage of the RV7, requiring a longer feed cable. To do this, I will make an extension cable which will result in two additional BNC connectors which will result in two BNC's (male and female) be located mid stream in the new antenna feed cable.
My questions are...
Will these two additional connectors significantly increase the SWR and have a negative affect on the radio's health over time?
Will these BNC junctions bundled with other wires "leak" any RF from the BNC joint that will effect other systems?
Should I just run a new cable thereby eliminating the junction?
Thanks.
Bevan
PostPosted: Fri Mar 18, 2016 5:09 am    Post subject: Re: BNC connectors and SWR Reply with quote
Since nobody else has replied, I will give my opinion which is only based reading these forums.
No, the BNC connector splice will not affect SWR.
No, RF will not leak from this BNC spice.
Should a new cable be run: maybe. Anytime wires are spliced, a potential trouble spot is created. If the spice is readily and easily accessible for future inspection and troubleshooting, then OK, splice on additional cable. On the other hand, if you want peace of mind and less chance of future problems, replace the cable. RG400 or RG142 is better than RG58.
Joe Gores
rv10pro(at)gmail.com
PostPosted: Fri Mar 18, 2016 6:27 am    Post subject: BNC connectors and SWR Reply with quote
Affirmative to each of the above points.  However each connector introduces additional db loss which will degrade transmission and to a lesser extent reception.  Don't cut the corner.  Run a new cable run.  We have fits with four cable runs to upper TCAS antenna and especially lower runs.  8 cables are a bitch and the central failure point in the absence of lighning strikes directly with the Antenna.
John Cox
Avionics Tech
On Fri, Mar 18, 2016 at 6:09 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=453905#453905
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
ceengland7(at)gmail.com
PostPosted: Fri Mar 18, 2016 8:28 am    Post subject: BNC connectors and SWR Reply with quote
You're technically correct.
But run the numbers to see if the degradation is enough to justify the hassle of re-running an existing cable. The original post didn't make it into this post, but if he's talking SWR, he's probably talking about a comm; not a gigahertz range radio. How much range loss is there for 0.2 dB insertion loss when a typical max *needed* range is maybe 30 miles? 1/2 mile? 1/10 mile? 50 feet?
The reliability issue remains, but in my experience, cutting into wire bundles all over the plane to extract the old cable and run a new one introduces many more and greater risks.
Another perspective...
On Fri, Mar 18, 2016 at 9:26 AM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
John Cox
Avionics Tech
Joe Gores
Kellym
PostPosted: Fri Mar 18, 2016 8:56 am    Post subject: BNC connectors and SWR Reply with quote
That is one of the great trade-offs, difficulty vs quality
communications. A good com(6-8 watts), with good cable and good
antenna/ground plane can communicate over at least 50 nm or more. Very
important in some parts of the West, especially IFR.
John Cox
Avionics Tech
<mailto:fransew(at)gmail.com>> wrote:
<fransew(at)gmail.com <mailto:fransew(at)gmail.com>>
Joe Gores
Kelly McMullen
KCHD
PostPosted: Fri Mar 18, 2016 9:39 am    Post subject: BNC connectors and SWR Reply with quote
Fine; call it 70 miles. Run the numbers.
On 3/18/2016 11:54 AM, Kelly McMullen wrote:
<kellym(at)aviating.com>
> John Cox
> Avionics Tech
> Joe Gores
