Extending instrument panel
Goto page 1, 2  Next
Mcabbage
PostPosted: Sat Mar 05, 2016 2:11 pm    Post subject: Extending instrument panel Reply with quote
I would like to extend my fs2 Inst. panel I have seen a few have done it and was hoping to get a little guidance and or pictures of the process. I was thinking to hinge it for better access.
How far to extend
What materials how to fabricate it
How to hinge and how to secure to existing panel?
I found these pics on barnstormers and really like the layout.
Thanks for any help
 Filesize:  80.48 KB
 Viewed:  26254 Time(s)
 Filesize:  51.28 KB
2007 Firestar 2 503 N203SD
Moster 185 Flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike & Northwing Stratus XP
PostPosted: Sat Mar 05, 2016 2:21 pm    Post subject: Extending instrument panel Reply with quote
Do a Google search of the N number. It will produce the first, second, and
third owners of this FS.
Mcabbage
PostPosted: Sun Mar 06, 2016 6:22 am    Post subject: Re: Extending instrument panel Reply with quote
Thank you John. I did contact seller from the ad but I think he was busy . Maybe new owner could help some.
Another question, when replacing ruder and elevater cables wher is the best source for materials?
PostPosted: Sun Mar 06, 2016 10:45 am    Post subject: Extending instrument panel Reply with quote
I recommend Kolb Aircraft Company.
Phone (606) 862-9692
rickofudall
PostPosted: Sun Mar 06, 2016 6:26 pm    Post subject: Extending instrument panel Reply with quote
For control cable, first get the proper mil spec cable, second read the
section on cable in AC 43-13 1B. I know there will be a lot of carping
about recommending covered cable but you owe it to yourself to read what
FAA certified mechanics read when they don't have a manufacturer's spec to
go by. Covered cable, one properly swaged Nico sleeve is the recommendation
George Alexander
PostPosted: Sun Mar 06, 2016 8:06 pm    Post subject: Re: Extending instrument panel Reply with quote
.S N I P .
Being one who must remain conscious of leg room, I would be careful how deep you make your extension and/or the top to bottom measurement. Too much in either of these dimensions will cut down that leg room. Looking at the inside shot of the pictures you posted, there's not much room between the pilot's shins and the bottom edge of the extension.
As Beauford would say.... "Worth what you paid fer it.."
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
lcottrell
PostPosted: Sun Mar 06, 2016 10:05 pm    Post subject: Extending instrument panel Reply with quote
I am not sure how big you are, but let me tell you how I get into my plane. I am 6 feet- 235 lbs. I sit backwards on my seat, lift my left leg over the stick, and down onto the rudder pedals. I of course reverse this process to get out of the plane. My plane has longer gear legs, so I had to change the method of entering the cockpit. With the smaller gear legs, One can lift up the wind screen- stick the left leg in, then put your butt on the seat. Much like what you do to get into a sports car. These are only ways to get in that I have found. Smaller younger pilots will be able to do things that I probably cannot.
The only thing on my cockpit that I need to do anything with is adjust the altimeter. I do that on the ground. The rest of the controls that I need- tank selection- fuel pump, strobe, ignition switch are all located in various spots that are within reach.
Primarily what I am saying is that you can position every thing that you need in spots that allow you to reach them while seated and flying. It just takes some thinking on your part. However you are the one that will be flying it, your choice, but give it some serious thought. I have a small center console in front of the stick that holds my radio, all my switches- plug ins for the intercom. HAC man system on the left side by the throttle, fuel selector switches on the gusset to the left of my seat. Take a poll and see how many have moved their console out.
Larry
Larry
On Sun, Mar 6, 2016 at 9:06 PM, George Alexander <gtalexander(at)att.net (gtalexander(at)att.net)> wrote:
--> Kolb-List message posted by: "George Alexander" <gtalexander(at)att.net (gtalexander(at)att.net)>
> .S N I P .
> Mike
George Alexander
FS II R503  N709FS
http://forums.matronics.com/viewtopic.php?p=453484#453484
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
The older I get, the less tolerant I am of those who are intolerant.
Mcabbage
PostPosted: Mon Mar 07, 2016 3:57 am    Post subject: Re: Extending instrument panel Reply with quote
Thanks guys yes proper planning! I am 6 feet 190 lbs size 12 sneakers! So I agree not much room down there for sure!
Mcabbage
patrickjladd(at)hotmail.c
PostPosted: Mon Mar 07, 2016 3:59 am    Post subject: Extending instrument panel Reply with quote
<<The only thing on my cockpit that I need to do anything with is adjust the altimeter. I do that on the ground>>
Thats interesting Larry. Do you not set your altimeter to read zero when you land at an away field? Normally we set QFE Baro pressure at your home field if just messing about locally. When approaching another field the local pressure will be passed to you along with wind speed and direction, circuit direction, circuit height etc. So if you are supposed to join the circuit at 1000 ft then that is the height which your altimeter shows.
Pat
Sent: Monday, March 7, 2016 5:55 AM
Subject: Re: Re: Extending instrument panel
Larry
Larry
.S N I P .
George Alexander
FS II R503 N709FS
br> fts!)
olendorf
PostPosted: Mon Mar 07, 2016 4:29 am    Post subject: Re: Extending instrument panel Reply with quote
This is how I did it. The panel is attached to a rubber hose at the bottom. The top rests against the nose cone. This allows the nose cone off by itself. Not attached to the panel at all. Yes you lose a little shin room. Just be sure to account for that. I rounded off the panel at the bottom so I didn't cut my legs off in a crash.
Two things I would do differently next time around. The compass needs to be vertical. The panel should be painted black.
 Filesize:  196.76 KB
 Viewed:  26125 Time(s)
 Filesize:  200.51 KB
 Filesize:  218.54 KB
 Filesize:  222.42 KB
 Filesize:  166.98 KB
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
Richard Pike
PostPosted: Mon Mar 07, 2016 7:00 am    Post subject: Re: Extending instrument panel Reply with quote
<snip>
Larry
I agree with what Larry says here. (Even if Scott Olendorf's panel setup is extremely cool)
It is really easy to make the panel on the FSII slide out a bit; notice that the wood has holes drilled in it and the windscreen tubes fit through it. You remove one screw on either side and the panel will slide up the tubes about 8 inches, plenty of room to get access to the back side.
Radio Shack is out of business, but the little black box with all the switches on it has lots of room for all your wiring needs. Probably other electronics shops sell similar boxes.
 Filesize:  142.83 KB
 Viewed:  26110 Time(s)
 Filesize:  137.69 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Richard Pike
PostPosted: Mon Mar 07, 2016 7:17 am    Post subject: Re: Extending instrument panel Reply with quote
One more thought: if you do extend the panel back toward your shins, make sure it is not rigidly attached to anything.
 Filesize:  172.54 KB
 Viewed:  26103 Time(s)
Richard Pike
Kingsport, TN 3TN0
neilsenrm(at)gmail.com
PostPosted: Mon Mar 07, 2016 8:26 am    Post subject: Extending instrument panel Reply with quote
Pat
Many of us live in remote locations that never talk to control towers. I think it has been ten years since talking to any tower. Even flying into the the LSA strip at Oshkosh and Sun N Fun, just flew in. I set my altimeter at the base elevation of the airport I take off from while on the ground.
I have a stick that I use to adjust my altimeter and switches on the panel while belted in. I have a holder that keeps the stick safely stored when not in use. George A got a chuckle and took pictures of it a few years back.
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Mar 7, 2016 at 6:44 AM, Patrick Ladd <patrickjladd(at)hotmail.com (patrickjladd(at)hotmail.com)> wrote:
Pat
Larry
Larry
.S N I P .
George Alexander
FS II R503  N709FS
br> fts!)
Mcabbage
PostPosted: Mon Mar 07, 2016 4:02 pm    Post subject: Re: Extending instrument panel Reply with quote
Thank you Olendorf, George, Larry, John and Rick
Richard- Ouch! that looks like it hurt! a lot.... it hurts just to see.
Larry, how did you extend the gear legs?
Many thanks
lcottrell
PostPosted: Mon Mar 07, 2016 4:17 pm    Post subject: Extending instrument panel Reply with quote
"Larry, how did you extend the gear legs?"
I got a pair of 4130 gear legs built by a friend that were 36 inches long. That gives me 24 inches sticking out rather than the stock alum legs. I also run 800X6 tires.
Larry
On Mon, Mar 7, 2016 at 5:02 PM, Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
--> Kolb-List message posted by: "Mcabbage" <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)>
Many thanks
Moster 185 flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike &amp; Northwing Stratus XP
http://forums.matronics.com/viewtopic.php?p=453544#453544
br> fts!)
Mcabbage
PostPosted: Mon Mar 07, 2016 4:23 pm    Post subject: Re: Extending instrument panel Reply with quote
Nice!
victorbravo(at)sbcglobal.
PostPosted: Mon Mar 07, 2016 4:31 pm    Post subject: Extending instrument panel Reply with quote
The extra long 36 inch gear.... do you notice a shorter takeoff roll because of the higher ground angle of the wing??? Enquiring minds want to know ! I want to build up my Firestar 2 as a STOL airplane Smile
Bill Berle
On Mon, 3/7/16, Mcabbage <Mc(at)americanbuilding.com> wrote:
Subject: Re: Extending instrument panel
Date: Monday, March 7, 2016, 4:23 PM
"Mcabbage" <Mc(at)americanbuilding.com>
Nice!
http://forums.matronics.com/viewtopic.php?p=453547#453547
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
more about
Gifts provided
              -Matt
Dralle, List Admin.
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
lcottrell
PostPosted: Mon Mar 07, 2016 6:17 pm    Post subject: Extending instrument panel Reply with quote
--> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>The extra long 36 inch gear... do you notice a shorter takeoff roll because of the higher ground angle of the wing??? Enquiring minds want to know ! I want to build up my Firestar 2 as a STOL airplane Smile
I am afraid that I cannot say for sure. You would have to ask others for that answer. I only know that it looks better, feels better, and I like it. Smile
Larry
On Mon, Mar 7, 2016 at 5:31 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
Bill Berle
On Mon, 3/7/16, Mcabbage <Mc(at)americanbuilding.com (Mc(at)americanbuilding.com)> wrote:
 Nice!
 Lists This Month --
 Raiser.  Click on
 more about
 Gifts provided
               -Matt
 Dralle, List Admin.
 Forum -
               -Matt
 Dralle, List Admin.
br> fts!)
PostPosted: Tue Mar 08, 2016 1:37 am    Post subject: Extending instrument panel Reply with quote
I have a stick that I use to adjust my altimeter >>
That beats the band. Well worth a chuckle.
I must admit that having learned to fly in gliders where you are more than likely to land out in a field with no known height I never bothered too much. More `that elm tree is about 50 feet high, turn final a bit above it`. We also have a `transition height` when going higher for serious xcountry flights. This ensures that everyone is on the same baro. pressure to enable them to maintain the quadrantal rule accurately. Never used it myself.
Pat
Sent: Monday, March 7, 2016 4:26 PM
Pat
Rick Neilsen
Pat
Larry
Larry
.S N I P .
George Alexander
FS II R503 N709FS
br> fts!)
Goto page 1, 2  Next
Page 1 of 2
