lcottrell
Posted: Sun Feb 28, 2016 12:11 pm Post subject: Hydraulic brakes? |
| Quote: | | I am considering changing to a Hydraulic system for my Firestar ll. I have looked at O'brian and Black Max so far. The only problem is that I want two hand operation. ( individual braking) It appears that will run about $500 bucks or more. Somehow I hate to do that, but still might depending on the feed back I can get from those using hydraulic braking. BCC is fine - lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com) I only want to do this once, and I hate buyer remorse. |
Larry
The older I get, the less tolerant I am of those who are intolerant.
stuart(at)harnerfarm.net Guest
Posted: Sun Feb 28, 2016 3:33 pm Post subject: Hydraulic brakes? |
Larry,
I have the Black Max setup on my Firefly. Individual toe brakes though, not a hand brake. This included the wheels and tires and was purchased as an option when I bought the kit.
Some people say you don’t need brakes at all and especially not individual brakes on the Firefly. As a general rule I don’t use them much. However, it is nice to be able to keep the engine RPM up and still taxi at a reasonable speed on pavement or not move at all.
Occasionally I use them to help on a turn, although without a swiveling tail wheel like you have the effect is not as noticeable. I am not sure how you would rig the dual hand levers for individual brakes. One lever on the stick and one on the throttle? J
Anyway, I have no regrets getting the Black Max setup. Easy to install and simple in design.
Stuart
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell
Sent: Sunday, February 28, 2016 2:11 PM
Subject: Hydraulic brakes?
Larry
lcottrell
Posted: Sun Feb 28, 2016 4:11 pm Post subject: Hydraulic brakes? |
Thanks for the reply. After checking I may have to forego the dual hand brakes and stick with heel brakes. It would run about $550 for two separate systems. I am using mechanical heel brakes now, and may have to stick with that.
If you have not already braced the tail post on you fly, you should really consider it.
Thanks again,
Larry
On Sun, Feb 28, 2016 at 4:30 PM, Stuart Harner <stuart(at)harnerfarm.net (stuart(at)harnerfarm.net)> wrote:
Larry,
Stuart
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Larry Cottrell
Larry
Herbgh(at)nctc.com Guest
Posted: Sun Feb 28, 2016 5:32 pm Post subject: Hydraulic brakes? |
you can save most of that 550 dollars by using Mtn bike disc brakes...either hydraulic or mechanical...Gotta be a bit mechanically inclined...will need to make a couple of spools that attach the disc to the rim...and a couple of adapter plates that attach the caliper to the large washer that is welded to the axle... I found my mechanical versions at the salvage yard...for maybe 5 bucks.... Requires some design work...but was a good two day project...
Ebay has both styles...Herb
On 02/28/2016 06:11 PM, Larry Cottrell wrote:
| Quote: | Thanks for the reply. After checking I may have to forego the dual hand brakes and stick with heel brakes. It would run about $550 for two separate systems. I am using mechanical heel brakes now, and may have to stick with that.
Thanks again,
Larry
Larry,
Stuart
I am considering changing to a Hydraulic system for my Firestar ll. I have looked at O'brian and Black Max so far. The only problem is that I want two hand operation. ( individual braking) It appears that will run about $500 bucks or more. Somehow I hate to do that, but still might depending on the feed back I can get from those using hydraulic braking. BCC is fine - [url=mailto:lcottrell1020(at)gmail.com]lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)[/url] I only want to do this once, and I hate buyer remorse. |
Larry
Signature text; Fort Marcy Park? Sure...Mr. Foster...Third red light and turn left.
west1m
Joined: 19 Apr 2014 Posts: 155 Location: Hastings, MN
Posted: Sun Feb 28, 2016 7:59 pm Post subject: Re: Hydraulic brakes? |
I put the Black Max hydraulic brakes on my firefly. I use a dual hand control by the throttle. Quite handy, no regrets.
116.59 KB |
25247 Time(s) |
_________________ West1m
Hastings, MN |
lcottrell
Posted: Sun Feb 28, 2016 8:06 pm Post subject: Hydraulic brakes? |
Do you remember the cost for dual controls?Larry
On Sun, Feb 28, 2016 at 8:59 PM, west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=453278#453278
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Posted: Sun Feb 28, 2016 8:34 pm Post subject: Hydraulic brakes? |
Yeah, that is on my “to do” list for this spring before flying season. I haven’t settled on exactly how to do it yet. Also need to cut out all the inspection holes and have a real good look-see inside. About 15 hours in the air, I figure it is about time for a new bird. Many other “little details” to attend too as well. Weather is getting better every day…
Stuart
Sent: Sunday, February 28, 2016 6:11 PM
Subject: Re: Hydraulic brakes?
Thanks again,
Larry
Larry,
Stuart
Larry
west1m
Posted: Mon Feb 29, 2016 6:49 am Post subject: Re: Hydraulic brakes? |
I don't recall the cost, they came from Black Max.
Expensive but I wanted brakes flying off the blacktop all the time.
| lcottrell wrote: | Do you remember the cost for dual controls?Larry
On Sun, Feb 28, 2016 at 8:59 PM, west1m <west1m> wrote:
| Quote: | --> Kolb-List message posted by: "west1m" <west1m>
West1m
Hastings, MN
br> fts!)
If you forward this email, or any part of it, please remove my email address before sending. |
Hastings, MN |
Thumper
Posted: Mon Feb 29, 2016 7:17 am Post subject: Re: Hydraulic brakes? |
Larry
Try these for dual hydraulic hand brake actuators. I did something similar on my old Firestar with the levers just in front of the seat between my legs. I used Mt Bike brakes but this would work. This is similar to what we had on a drifter in my hangar at one time and it worked excellent. And lots less than 500. Maybe buy the throttle like the one picture as part of this subject. Shop around for the best price on 5" or 7" levers. Hagar is the brand. Good Luck and I'll get out that way sometime.
https://www.cps-parts.com/categories/aircraft_parts/ap/menus/lg/masterbrakecylinders_hegar.html
| Dual hydraulic brake master cylinders. |
5.97 KB |
25180 Time(s) |
_________________ Dennis Long
Oakland TN
2000 Aeroprakt A20 Vista Cruiser, 2016 A22LS Aeroprakt
Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar.
1200+hours since 1/1/2009 |
victorbravo(at)sbcglobal. Guest
Posted: Mon Feb 29, 2016 9:46 am Post subject: Hydraulic brakes? |
If your feet could bounce off the pedals in a rough field, then make a little loop out of nylon webbing (from a broken ratchet strap or something) and tie it to the pedal. Put your foot into this loop and use it like a stirrup. Adjust the size and location of the loop so that it only goes around your toes, so it cannot trip you getting out of the cockpit. Tie it to the pedal system in a location that allows you to move your foot to activate the brakes.
Problem solved, cost zero.
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
Date: Monday, February 29, 2016, 6:49 AM
"west1m" <west1m(at)hotmail.com>
the time.
handy, no regrets.
> > West1m
> > Hastings, MN
> > Read this topic online here:
(http://forums.matronics.com/viewtopic.php?p=453278#453278)
> > br> fts!)
> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
> > Â Â Â Â Â -Matt Dralle, List
Admin.
> > -List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?Kolb-List
> > FORUMS -
> > eferrer" target="_blank">http://forums.matronics.com
> > b Site -
Admin.
are intolerant.
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=453285#453285
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser. Click on
more about
Gifts provided
-Matt
Dralle, List Admin.
Forum -
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
zeprep251(at)aol.com Guest
Posted: Mon Feb 29, 2016 2:56 pm Post subject: Hydraulic brakes? |
If it's that rough your tires aren't on the ground either.
| Quote: | On Feb 29, 2016, at 12:45 PM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
the time.
handy, no regrets.
>> West1m
>> Hastings, MN
>> br> fts!)
Admin.
>> FORUMS -
>> b Site -
Admin.
are intolerant.
West1m
Hastings, MN
Lists This Month --
Raiser. Click on
more about
Gifts provided
-Matt
Dralle, List Admin.
Forum -
-Matt
Dralle, List Admin.
GeoB
Posted: Tue Mar 01, 2016 11:43 am Post subject: Hydraulic brakes? |
| Quote: | I used 2 brake handles on the control stick and I can activate either
side or both at the same time with just my fingers.
Thanks for your post and idea! I have been wondering if I should use
separate levers on my conversion. I have mtn bike disc brakes mounted, but
the caliper mounts are not done.
I was thinking about putting one brake lever on the left of the seat and
one on the stick. But as I read your post I visualized both on the stick,
maybe reversed so the handle ends are adjacent to each other. Dunno, maybe
it would work. How are yours mounted?
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
neilsenrm(at)gmail.com Guest
Posted: Tue Mar 01, 2016 12:15 pm Post subject: Hydraulic brakes? |
I can't imagine having to worry about my feet bouncing off the rudder pedals or brakes. I like heal brake pedals because they don't stress the rudder cables and you aren't near as likely to inadvertently apply the brakes. Hand brakes????
I have Matco brakes I like the design but mine are a bit low on braking power. Kolb's old demonstrator, Fat Albert had Matco brakes and it had four times the braking power. I had to be very careful using them because I'm so used to standing on mine.
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Feb 29, 2016 at 12:45 PM, Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
| Quote: | --> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Bill Berle
byoungplumbing(at)gmail.c Guest
Posted: Tue Mar 01, 2016 12:52 pm Post subject: Hydraulic brakes? |
Rick
do you know why fat Albert's brakes were so much better? did it have the 2 puck calipers. or a better mechanical advantage?
Boyd On Mar 1, 2016 1:24 PM, "Rick Neilsen" <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote: | Quote: | I can't imagine having to worry about my feet bouncing off the rudder pedals or brakes. I like heal brake pedals because they don't stress the rudder cables and you aren't near as likely to inadvertently apply the brakes. Hand brakes????
Rick Neilsen
Bill Berle
lcottrell
Posted: Tue Mar 01, 2016 1:00 pm Post subject: Hydraulic brakes? |
Using my mech brakes I came up with this and it worked very well. I found it much easier to control my plane with these and using the rudders. They at least were always positive, where as I find it difficult sometimes to get my feet where I want them and use the rudders as well. Perhaps I am just clumsy!
I had to do a bit of welding, but it worked just fine.
On Tue, Mar 1, 2016 at 4:33 AM, George Bearden <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)> wrote:
| Quote: | --> Kolb-List message posted by: "George Bearden" <gab16(at)sbcglobal.net (gab16(at)sbcglobal.net)>
br> fts!)
359.56 KB |
25128 Time(s) |
304.5 KB |
25128 Time(s) |
379.3 KB |
25128 Time(s) |
Richard Pike
Posted: Tue Mar 01, 2016 3:30 pm Post subject: Re: Hydraulic brakes? |
Looks like their are all sorts of ways to skin this cat. Here is how we did it in the FSII: instead of pulling back you push down. (Did it this way because it was easier to weld in the brackets and make everything fit. Bleeding the air out is a pain tho...)
http://oh2fly.net/oldpoops/Panel.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
patrickjladd(at)hotmail.c Guest
Posted: Wed Mar 02, 2016 5:07 am Post subject: Hydraulic brakes? |
“feet bouncing off the rudder pedals or brakes. I like heal brake pedals..”
I remember the CFI at my Gliding Club pulling the horn off the rudder of a glider which had heel operated rudder pedals through a rough landing run. The forces involved in a rough run are considerable. I flew with a plaster cast on and punched a hole in the cockpit floor through banging up and down on a rough take off run.
Pat
Sent: Tuesday, March 1, 2016 5:10 PM
Subject: Re: Re: Hydraulic brakes?
Rick Neilsen
Bill Berle
Posted: Wed Mar 02, 2016 7:57 am Post subject: Hydraulic brakes? |
Pat
We are talking about Kolb airplanes. Also not recommended that one is on the brake peddles until after landing.
Rick Neilsen
On Wed, Mar 2, 2016 at 8:06 AM, Patrick Ladd <patrickjladd(at)hotmail.com (patrickjladd(at)hotmail.com)> wrote:
| Quote: | “feet bouncing off the rudder pedals or brakes. I like heal brake pedals..”
Pat
Rick Neilsen
Bill Berle
Posted: Wed Mar 02, 2016 8:15 am Post subject: Hydraulic brakes? |
Boyd
I have asked myself that question many times. No I don't think it had the it had the 2 puck calipers or more mechanical advantage. I think the brake disk is a different material, mine don't rust (likely stainless) or the brake pads are less abrasive.???????
Rick Neilsen
On Tue, Mar 1, 2016 at 3:49 PM, B Young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
Rick
Rick Neilsen
Bill Berle
Thumper
Posted: Thu Mar 03, 2016 7:50 am Post subject: Re: Hydraulic brakes? |
Here is my MT bike brake handles for my Firestar I that I installed before selling. Pull one or the other, or the cable loop for both. worked good for me.
768.24 KB |
25021 Time(s) |
791.52 KB |
25021 Time(s) |
Oakland TN
