Glare-shield painting
trigo(at)mail.telepac.pt
PostPosted: Tue Feb 23, 2016 2:39 pm    Post subject: Glare-shield painting Reply with quote
Guys
Questions for those of you who didn't upholster the glare-shield of your -10:
Which colour did you paint the upper surface of your glare-shield?
And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel?
And by the way, when in the building process did you paint these 2 surfaces?
TIA
Carlos
Enviado do meu iPhone
cooprv7(at)yahoo.com
PostPosted: Tue Feb 23, 2016 3:09 pm    Post subject: Glare-shield painting Reply with quote
Carlos,
I went with flat black, trusty Rust-Oleum if I remember correctly. It’s been 9 1/2 years with no issues whatsoever and no problem with glare either. I painted the bottom white to match my instrument panel. I painted it after installation but before putting the windshield in.
If you are going to put any cooling fans in the glare shield I recommend you make the cutouts before installing, I know it’s a bit of a pain to do them later on Sad One or two computer cooling fans helps with cooling the avionics as well as being a natural defogger.
Have fun,
Marcus
On Feb 23, 2016, at 5:35 PM, Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Guys
TIA
Carlos
flying-nut(at)cfl.rr.com
PostPosted: Tue Feb 23, 2016 3:29 pm    Post subject: Glare-shield painting Reply with quote
On 2/23/2016 5:35 PM, Carlos Trigo wrote:
Guys
Flat black.
I painted mine the same color (colour) as my instrument panel ....
rust-oleum # 7223 sandstone, It's in the 'textured' area. I painted my
tunnel cover and the overhead plenum the same color.
I painted the glareshield before I riveted on the fwd upper fuse, just
before I installed the cabin top and windshield. I painted the aft
underside two weeks ago because my first attempt peeled .... probably
poor prep on my part. Lots of masking tape and paper since the interior
was already painted.
Linn .... painting the FG parts .... white.
TIA
Carlos
Bob Turner
PostPosted: Tue Feb 23, 2016 5:49 pm    Post subject: Re: Glare-shield painting Reply with quote
RustOlium dark brown (I forget the official color), flat, top and underside. Fan holes drilled first. Painted in place but no windscreen, no instrument panel.
Bob Turner
RV-10 QB
dmaib@me.com
PostPosted: Wed Feb 24, 2016 6:42 am    Post subject: Glare-shield painting Reply with quote
Flat black, probably Rustoleum, but don't really remember. Underside same tan as panel. Cut openings for vent fans prior to paint and windshield installation. 850 hours and 7 1/2 years later it is still looking good
David Maib
Guys
TIA
Carlos
David Maib
RV-10 #40559
New Smyrna Beach, FL
rene(at)felker.com
PostPosted: Wed Feb 24, 2016 7:19 am    Post subject: Glare-shield painting Reply with quote
I got some dashboard material from Cleveland and it works great. You just
glue it in. Also got the trim piece from them.
Attached a picture....not a great one. I did this after the wind screen was
in.
Rene'
801-721-6080
 Filesize:  114.57 KB
 Viewed:  7209 Time(s)
arplnplt(at)gmail.com
PostPosted: Wed Feb 24, 2016 1:15 pm    Post subject: Glare-shield painting Reply with quote
I used a spray on, black bed liner product from a local auto parts store.Put on several coats till the can was gone. Zero glare or windscreen reflection as well as non-slip. Tough as nails.Dave LeikamN89DA
[quote]On Feb 24, 2016, at 9:16 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
I got some dashboard material from Cleveland and it works great. You justglue it in. Also got the trim piece from them.Attached a picture....not a great one. I did this after the wind screen wasin.Rene'801-721-6080--
PostPosted: Wed Feb 24, 2016 2:23 pm    Post subject: Glare-shield painting Reply with quote
Sorry for the multiple posts!I was getting a delivery error.
Dave Leikam
[quote]On Feb 24, 2016, at 3:09 PM, David Leikam <arplnplt(at)gmail.com (arplnplt(at)gmail.com)> wrote:
