changing tires
pc.king(at)comcast.net
PostPosted: Thu Feb 18, 2016 12:37 pm    Post subject: changing tires Reply with quote
Have you thought of using a mini tire change from Harbor Freight?
$42.99.
http://www.harborfreight.com/mini-tire-changer-61179.html
 Filesize:  77.57 KB
 Viewed:  4043 Time(s)
yellowbird1
PostPosted: Thu Feb 18, 2016 1:36 pm    Post subject: changing tires Reply with quote
No I did not know about this. I will give it a try.
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Thursday, February 18, 2016 1:36:11 PM
Subject: changing tires
$42.99.
Brad Nation,
Albuquerque, NM
MK3 Xtra
PostPosted: Thu Feb 18, 2016 2:27 pm    Post subject: changing tires Reply with quote
Usually, the problem when attempting to break he bead, is that the rim is weaker than the tire bead.
If it was my problem and I had a off road tire on the rim, I'd sacrifice the tire and cut the wire bead.  If not, I'd figure out which cost the most to replace, aircraft tire or MATCO rim.
Good luck with your tire operation.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of nationcap(at)comcast.net
Sent: Thursday, February 18, 2016 3:35 PM
To: kolb-list
Subject: Re: changing tires
From: "pcking" <pc.king(at)comcast.net (pc.king(at)comcast.net)>
To: "kolb-list" <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
$42.99.
