FiascoDave
Joined: 06 Dec 2014 Posts: 5 Location: southern Oregon
Posted: Tue Feb 16, 2016 9:09 am Post subject: Fuel tank options Mk3 |
I've got a mk3 with three 5 gal plastic tanks side-by-side mount on shelf above boom.
Problem? Having to refill 3 tanks...very near and above electrical components, battery...inside of fuselage.
Does anyone have a single tank solution? Fiberglass, steel or aluminum?
Or a single manifold for refueling over the wing?
Thanx,
Dave -southern Oregon
_________________ Ciao,
FiascoDave |
Richard Pike
Posted: Tue Feb 16, 2016 9:56 am Post subject: Re: Fuel tank options Mk3 |
Made this arrangement out of Epoxy and glass cloth, has worked good for many years. Don't put ethanol into it, or you'll get to make it twice.
http://oh2fly.net/oldpoops/pg1.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Tue Feb 16, 2016 10:47 am Post subject: Fuel tank options Mk3 |
Got a 25 gal 5052 aluminum fuel tank secured in what is the normal open area
behind the cockpit. One of a kind. Fuel through the center section. Opens
up the area below, which is normally filled up with two 5 gal tanks, for
cargo compartment.
Built an 18 gal 5052 aluminum fuel tank for my Firestar (Original). Same
configuration as my MKIII. Tank up top and cargo compartment below.
_________________ John Hauck
Titus, Alabama |
Mark K
Joined: 17 Aug 2014 Posts: 32 Location: Great Bend, PA
Posted: Tue Feb 16, 2016 11:47 am Post subject: Re: Fuel tank options Mk3 |
I was able to come across a used dune buggy fuel tank, but the owner put me onto this site for his original purchase.
http://www.pacificcustoms.com/round_poly_fuel_tanks.html
Seems like they have all the fixin's
92.9 KB |
15798 Time(s) |
_________________ Mark
Twinstar MKII
Great Bend, PA |
neilsenrm(at)gmail.com Guest
Posted: Tue Feb 16, 2016 8:40 pm Post subject: Fuel tank options Mk3 |
Dave
I have a single manifold (boat fuel filler/cap) under the wing on the side of the fuselage just behind the doors of my MKIIIC that I use to fill my two 5 gallon fuel tanks.
Also, ANY software don't install a early version. Installed Windows 10 on three of my computers works great.
Rick Neilsen
Redrive VW powered MKIIIC
On Tue, Feb 16, 2016 at 12:09 PM, FiascoDave <FiascoDave(at)gmail.com (FiascoDave(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "FiascoDave" <FiascoDave(at)gmail.com (FiascoDave(at)gmail.com)>
Thanx,
Ciao,
FiascoDave
http://forums.matronics.com/viewtopic.php?p=452902#452902
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
mojaveclimber
Posted: Sun Jul 24, 2016 1:32 am Post subject: Re: Fuel tank options Mk3 |
I carry a 5 foot length of very light weight convoluted hose, think shop
vacuum hose or swimming pool filter hose, to extend the fuel fill port away from the wing when refueling at airport pumps.
Insert one end into the fuel tank and the pump nozzle the other, fill tank,
repeat for tank 2, stow hose behind seat for next refuel.
Very light and space efficient.
mojaveclimber
Posted: Sun Jul 24, 2016 1:33 am Post subject: Re: Fuel tank options Mk3 |
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Sun Jul 24, 2016 10:37 am Post subject: Re: Fuel tank options Mk3 |
I fabricated an aluminum tank that holds a little over 18 gal. Had a vendor that I worked with at the time do the TIG welding. Probably heaver than plastic though. See attached pics.
Rex Rodebush
Posted: Sun Jul 24, 2016 10:41 am Post subject: Re: Fuel tank options Mk3 |
Try again on the pictures
147.75 KB |
15559 Time(s) |
Rex Rodebush
Posted: Sun Jul 24, 2016 10:44 am Post subject: Re: Fuel tank options Mk3 |
one more time
179.07 KB |
15555 Time(s) |
