maintenance tips
dlm34077
PostPosted: Sat Feb 13, 2016 6:20 am    Post subject: maintenance tips Reply with quote
The 360003 fuel pressure sensor has a tendency to start reading erratically high fuel pressure after several hundred hours; an IA friend said the same is true for the PMA stamped part for about 10-15 times the experimental price. I replaced the part at about 400 hours and again at about 800 hours. The new one started the routine a couple of months ago. After thinking about the transducer, I decided to try cleaning the contacts; I have flown several hours since then and the sensor is operating normally. I think that the problem may be the oil residue, etc swirling about under the cowl and causing contact problems. So far so good.
I believe most 10s have the Matco master cylinders supplied by Vans. I spoke with George Happ of Matco about a problem I have seen on a couple of occasions. Given the geometry of the rudder/brake pedals it is possible through inattention to drag a brake slightly. The master cylinder is not fully extended and therefore can not equalize internal pressures due to covered input port; the result is a temporary faulty brake and perhaps erratic steering as a result. It can happen with long taxi, hot weather and dragging a brake ever so slightly. It has happened to me twice in about 1000 hours. It seems as though a brake bleed is necessary but after a short period the situation resolves itself. At the time of occurrence it seems best to remove one’s feet from the brakes for a second or two and reapply.
David McNeill
N46007 TT 1000+
This email has been sent from a virus-free computer protected by Avast. www.avast.com
gengrumpy
PostPosted: Sat Feb 13, 2016 6:51 am    Post subject: maintenance tips Reply with quote
In a prior life with much heavier iron being pushed by a hot air tailpipe, we were taught to only put your feet on the brake pedals when you needed to brake, get on both brakes quickly with equal pressure, and then get totally back off of them. Let the plane accelerate a bit, then do it all over again. A series of slowing down through firm braking, then accelerating until you need to slow it down again.
Constant pressure during taxiing creates heat. Enough heat will cause brake fade and ignite any fluid around the pucks…..
I have used this technique solely since building my -10 nearly 10 years ago, and not only have there been no brake incidents, I replace the pads about every 300 hours (there is still life left in them at that point, I just feel better replacing them…..).
grumpy
On Feb 13, 2016, at 8:16 AM, David <dlm34077(at)cox.net (dlm34077(at)cox.net)> wrote:
David McNeill
N46007 TT 1000+
carl.froehlich(at)verizon
PostPosted: Sat Feb 13, 2016 6:53 am    Post subject: maintenance tips Reply with quote
It is easy to drag a brake. Here is a note I sent out a few months ago on the subject.
My son and son-in-law are Naval Aviators. As is easy to do, both have a tendency to drag the brakes. A good friend of mine, Tom Doran, made these extension on his milling machine from 1” Delron. He even made me one out of steel for me to use as a drilling gig. I used a couple of hose clamps to attached the gig and drill the #19 holes.
While I did this to help the son and son-in-law I confess I found them to be much better than just the stock set up.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David
Sent: Saturday, February 13, 2016 9:17 AM
Subject: maintenance tips
David McNeill
N46007 TT 1000+
www.avast.com
 Filesize:  63.36 KB
 Viewed:  4446 Time(s)
 Filesize:  142.42 KB
flying-nut(at)cfl.rr.com
PostPosted: Sat Feb 13, 2016 7:17 am    Post subject: maintenance tips Reply with quote
Along with 'heel pads' you can put an additional compression spring on the master cylinder shaft to help it relax fully.  The angle of the pedal just naturally makes it easy to drag the brakes.
As John Miller posted, short, hard brake pressure is always preferable to dragging the brakes due to the heat.  Tail-dragger pilots should be used to that already.
AFAIK, the original Matco brake disks are a little thinner than their Cleveland counterparts and don't have as much mass to store a lot of heat.
Linn
On 2/13/2016 9:49 AM, Carl Froehlich wrote:
<![endif]--> <![endif]-->
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David
David McNeill
N46007 TT 1000+
www.avast.com
philperry9
PostPosted: Sat Feb 13, 2016 9:42 am    Post subject: maintenance tips Reply with quote
Here's my setup for return springs to assist the internal spring on the
master cylinders.
On the bottom is a delrin washer to help protect the master cylinder from
the spring.
Then the spring.
Then on top of that is a collar for the spring to press against on the top
and to adjust the tension you feel on the brake pedals.
All hardware purchased in the aviation department of Ace Hardware.
Probably around $7 per master cylinder.
Phil
[image: Inline image 1]
On Sat, Feb 13, 2016 at 9:13 AM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
[quote] Along with 'heel pads' you can put an additional compression spring on the
that already.
