glastar(at)gmx.net Guest
Posted: Tue Feb 02, 2016 1:28 am Post subject: Collie Hat Switches |
I would like to pull the lists wisdom and knowledge.
My dad creates the stick grips out of cherry wood (I have already a pair in my Glastar (don't put the mic key on top!)),
[img]cid:part1.05080802.08060807(at)gmx.net[/img]
now for the RV10 you have 2 electric trims, one version would be two switches in the panel, but I like to sit in flying position to trim, so a collie hat would be the ideal scenario for me.
What is the list experience (this will be low amps as no direct drive) with that kind of switches? Any sources for it (found some from Digikey).
Many thanks for your ideas, hints, tips coming....
Cheers Werner
452.51 KB |
2599 Time(s) |
Posted: Tue Feb 02, 2016 3:19 am Post subject: Collie Hat Switches |
Werner
I suppose that the guy who sells the Infinity Stick grip also sells the components, including the Hat switch.
Try http://infinityaerospace.com
Cheers
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner Schneider
Sent: terça-feira, 2 de Fevereiro de 2016 09:27
Subject: Collie Hat Switches
Cheers Werner
Este e-mail foi enviado a partir de um computador sem vírus protegido pela Avast. www.avast.com
452.51 KB |
2599 Time(s) |
ashleysc(at)broadstripe.n Guest
Posted: Tue Feb 02, 2016 6:39 am Post subject: Collie Hat Switches |
Hi Werner;
Beautiful stick grip! Questions:
1. Does your Dad do these commercially (i.e. for sale to others)?
2. Is it an ambidextrous design? (I fly with either hand on the grip.)
3. I would only want a coolie hat on top and a push to talk toggle in front.
4. I need two grips.
If yes to all these questions, perhaps we could take the conversation off-line.
Cheers! Stu.
ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)
Sent: Tuesday, February 2, 2016 1:26:35 AM
Cheers Werner
452.51 KB |
2599 Time(s) |
rv8iator(at)gmail.com Guest
Posted: Wed Feb 03, 2016 8:13 am Post subject: Collie Hat Switches |
Otto switch has many to chose from. Aerospace quality... aerospace price too!
http://www.ottoexcellence.com/products/4-way-mini-trim/
-Chris Stone
RV-8 80802
On Tue, Feb 2, 2016 at 1:26 AM, Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
| Quote: | I would like to pull the lists wisdom and knowledge.
Cheers Werner
452.51 KB |
2584 Time(s) |
