Tow Bar
Kelly McMullen
PostPosted: Mon Feb 01, 2016 10:15 pm    Post subject: Tow Bar Reply with quote
I have the Bogart Tow bar. My nose gear is a Matco wheel with Matco axle.
When I put the tow bar on the axle bolt and nut, the tow bar slips off very easily, making turning and pushing almost impossible Is thee a way to lock the tow bar onto the axle?-sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
aerosport1
PostPosted: Tue Feb 02, 2016 4:59 am    Post subject: Tow Bar Reply with quote
You do not use the wheel axle bolt for the tow bar. You use the forward tow bar attach
Bolts That hold the front of the wheel pant bracket.
Geoff
Geoff Combs
Aerosport
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Kelly McMullen
PostPosted: Tue Feb 02, 2016 5:12 am    Post subject: Tow Bar Reply with quote
That explains a lot...haven't gotten around to mounting those brackets yet.  Thanks Geoff.
On Tue, Feb 2, 2016 at 5:55 AM, Geoff Combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
--> RV10-List message posted by: Geoff Combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
Geoff
Geoff Combs
Aerosport
> On Jan 31, 2016, at 11:56 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Kelly McMullen
KCHD
Mauledriver(at)nc.rr.com
PostPosted: Tue Feb 02, 2016 10:45 am    Post subject: Tow Bar Reply with quote
Geoff answered the question but you might give this some thought as work
on the brackets....
As I recall, the original design has the 'forward tow bar attach bolts'
setup so they are recessed inside of the wheel pant for a nice
streamlined appearance/performance. I copied a number of other builders
in lengthening the bolts so that stainless cap head bolts sit external
to the wheel pant. There was a bit more to it but it's been awhile and
I'm not looking at anything. The mods were fully discussed and
documented here on the forum.
As I go into 5 years of operation, the external tow points have worked
great with the Bogert tow bar. More importantly they have eased
operations at visiting airports because the tow points are obvious,
easily used by common commercial tow bars, and because of some
protective washers they minimize damage to the wheel pant from line
folks. And it still looks pretty good though not all neat and recessed.
There may be other and better solutions out there now but that mod has
been good to me and I recommend it.
The Bogie Bar has also be come my control lock - it can work without
modification but the addition of some tabs to lock into the rudder
pedals makes it fool proof.
davidsoutpost(at)comcast.
PostPosted: Tue Feb 02, 2016 11:37 am    Post subject: Tow Bar Reply with quote
I lengthened my tow bar attach points by buying longer socket head cap screws and machining longer aluminum spacers.  The attach points are just flush almost with the fairings. They do not stick out and provide about 3/4" attach points for positive tow bar connections.
Sent from my Verizon Wireless 4G LTE smartphone
-------- Original message --------
Date: 02/02/2016 1:41 PM (GMT-05:00)
Subject: Re: RV10-List: Tow Bar
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
on the brackets....
_-============================================================
_-=
_-=       -- Please Support Your Lists This Month --
_-=           (And Get Some AWESOME FREE Gifts!)
_-=
_-=   November is the Annual List Fund Raiser.  Click on
_-=   the Contribution link below to find out more about
_-=   this year's Terrific Free Incentive Gifts provided
_-=   by:
_-=
_-=     * The Builder's Bookstore www.buildersbooks.com
_-=
_-=   List Contribution Web Site:
_-=
_-=   --> http://www.matronics.com/contribution
_-=
_-=   Thank you for your generous support!
_-=
_-=                              -Matt Dralle, List Admin.
_-=
_-=          - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?RV10-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=             - List Contribution Web Site -
kearney
PostPosted: Tue Feb 02, 2016 12:41 pm    Post subject: Re: Tow Bar Reply with quote
HI
A few years ago there was a bolt / helicoil / tap kit that was making its way from builder to builder.
The intent was to use heilcoils in the bolt holes as the raw aluminum would eventually give way. The bolts were longer so that the head protruded out of the pants. A large washer was placed under the head so the tow bar never was inside the wheel pant. This prevents wheel pant damage if the tow bar slips off. AT least only paint gets scratched and the F/G doesn't get This up.
Cheers
Les
PostPosted: Tue Feb 02, 2016 8:11 pm    Post subject: Tow Bar Reply with quote
Thanks Les - it was long enough ago I forgot most of the details but
that's what I did. The heli-coil touch was good engineering. Without
it, I'm sure things would have stripped.
Extending to just below the surface is the showplane approach - very
nice. The extension with large washer approach is the 'ham handed tow
bar handling' approach. Both better than stock I'd guess.
On 2/2/2016 3:41 PM, kearney wrote:
HI
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=452533#452533
rv10free2fly(at)yahoo.com
PostPosted: Tue Feb 02, 2016 11:44 pm    Post subject: Tow Bar Reply with quote
Do you have any pictures of this setup please Les?
Warm regards
Patrick
On 3 Feb 2016, at 07:11, kearney <kearney(at)shaw.ca> wrote:
HI
Cheers
Les
bill.peyton
PostPosted: Wed Feb 03, 2016 4:19 am    Post subject: Re: Tow Bar Reply with quote
Here is a photo of how I extended the tow pins and used chrome hex bolts. I also used a helicoil for the attachment threads
 Filesize:  56.89 KB
 Viewed:  12229 Time(s)
 Filesize:  56.89 KB
WA0SYV
Aviation Partners, LLC
partner14
PostPosted: Wed Feb 03, 2016 6:33 am    Post subject: Tow Bar Reply with quote
I took the Bogart tow bar, cut off the female pickup ends, and welded on pin tabs that would go inside the allen bolts. That way no other tow bar will work. Disadvantage = no other tow bar will work. Advantage = the holes required in the wheel pants are smaller, and no one else will try and use their tow bar to move my plane. If I trust them to move it, I will leave mine with the plane. 6.5 years, 800 hours, no problem.
Don Mc
Sent: Wednesday, February 3, 2016 1:40 AM
Subject: Re: Re: Tow Bar
--> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Warm regards
Patrick
On 3 Feb 2016, at 07:11, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
HI
Cheers
Les
&gtttp://www.matronics.com/contribution" target="_blank">http://www.matronic -Matt Dralle, List --> http://forums.matronics.com</ -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
Don A. McDonald
40636
