Flylawnchairs
Posted: Tue Jan 26, 2016 3:49 pm Post subject: Gap seals |
Hi all, I've bee slowly and intermittently working on my mk3xtra and have wondered about using the aluminum hinge that attaches the flaperon to the trailing edge of the wing going the the whole distance from inboard to outboard. Does anyone think this would eliminate the need for the 3m tape supplied in the kit ?
rickofudall
Posted: Tue Jan 26, 2016 4:17 pm Post subject: Gap seals |
It's your experiment, but either fabric or tape gap seals are less expensive than all that hinge (which is NOT intended to attach control surfaces by the way) and decreases the number of holes in the rear wing spars and the leading edge of the control surfaces. My two cents.
Rick Girard
Before someone starts in, look up the specs for MS20257 rolled hinge and MS20001 Extruded (structural) Hinge. Just sayin'
On Tue, Jan 26, 2016 at 5:49 PM, Flylawnchairs <Flylawnchairs(at)gmail.com (Flylawnchairs(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Flylawnchairs" <Flylawnchairs(at)gmail.com (Flylawnchairs(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=452324#452324
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Posted: Tue Jan 26, 2016 5:05 pm Post subject: Gap seals |
Doesn't take much hinge to hang an aileron and flap.
Piano hinges may not have been designed for control surface hinges, but they have served us, in the Kolb world, well.
The trailing edge of the wing and the leading edge of the flap and aileron flex quite a bit in flight. Never tried to see if I could actually see them flex in flight, but it can be done on the ground.
Full span hinges will begin binding as soon as they begin getting out of column. Would it be a problem? I don't know. Is there enough flex in the wing and control surfaces to bind up a full span hinge? I don't know that either.
Best go by the plans on size and number of hinges, in my humble opinion.
I have Polyester Dacron fabric seals that were installed on my MKIII in 1992. They are still serviceable after 24 years and 3,300+ hours. Takes a little longer and is a little more difficult to go this route, but the end result produces the best gap seal.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Tuesday, January 26, 2016 6:17 PM
Subject: Re: Gap seals
Rick Girard
br> fts!)
FORUMS -
b Site -
-- “Blessed are the cracked, for they shall let in the light.” Groucho Marx
_________________ John Hauck
Titus, Alabama |
ceengland7(at)gmail.com Guest
Posted: Tue Jan 26, 2016 7:56 pm Post subject: Gap seals |
Rick mentions a question worth asking about extra holes in the spar. Having said that, the 2 seat RV's use full length piano hinge for the flaps. IIRC, some of the Zenith products use them for aileron hinges.
FWIW,
Charlie
On 1/26/2016 7:04 PM, John Hauck wrote:
| Quote: | <![endif]--> <![endif]-->
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Richard Girard
Rick Girard
--> Kolb-List message posted by: "Flylawnchairs" <[url=mailto:Flylawnchairs(at)gmail.com]Flylawnchairs(at)gmail.com (Flylawnchairs(at)gmail.com)[/url]>
byoungplumbing(at)gmail.c Guest
Posted: Tue Jan 26, 2016 10:03 pm Post subject: Gap seals |
I think that if I were to use full length hinges, I would install them in such a way that they never go straight even at full deflection of the control surfaces. that way they can't lock up on you.
Boyd Young
Flylawnchairs
Posted: Wed Jan 27, 2016 9:03 am Post subject: Re: Gap seals |
Thanks for the input guys, think I'll just use the required amount of hinge and call it good. Even though all that flexing really bothers me, I think John has a point about it working fine for 3300 hours.
Cheers, Gene Wilson
Posted: Wed Jan 27, 2016 11:12 am Post subject: Gap seals |
Probably didn't make myself clear, as usual.
Any flexing is not noticeable. My description would have fit a Challenger
wing much better than Homer Kolb's wing. Do not let the minute flex bother
you.
Titus, Alabama |
Richard Pike
Posted: Wed Jan 27, 2016 5:47 pm Post subject: Re: Gap seals |
I think all the Kolbs have a solid hinge at the root, and piano hinges along the rest of the wing, and typically the tips have a bit of flex from the piano hinges. If you want the aileron tip end to be solid with no flex: you know those stainless L hinges that are used to secure the leading edge of the horizontal stab? Buy 8 extra stainless L hinges and use them as tip aileron hinges and the flex will go away. Not that I think it matters; but if it matters to you...
http://oh2fly.net/oldpoops/pg8.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
mojavjoe
Posted: Wed Jan 27, 2016 8:03 pm Post subject: Gap seals |
While my Firestar doesn't have flaps, my ailerons have hinge the length of the aileron, not however from the inside edge of the aileron to the wing root and I think this a very good gap seal.
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Tuesday, January 26, 2016 6:49:20 PM
Subject: Gap seals
--> Kolb-List message posted by: "Flylawnchairs" <Flylawnchairs(at)gmail.com>
