Electrical system design critique
Jump4way
PostPosted: Tue Jan 12, 2016 6:03 pm    Post subject: Electrical system design critique Reply with quote
I'm working on my electrical system design. My plan is to install the EFII system using two alternators and one battery. The primary ECU, injector, fuel pump, and ignition will be powered off the always hot battery bus with the secondary set of the above powered off of the main bus.
I've chosen to install a couple of fusible links in areas where the aeroelectric connection book recommends wire runs 6" or less and I was unable to achieve that. I'm not sure if a run of 2-3 ft would require a fusible link... still scratching my head on that. I haven't completed the diagram quite yet as I haven't decided on which alternator/regulator combo to go with so that portion is left mostly out at this point.
Avionics haven't been purchased yet but I'm leaning towards the Garmin G3x suite of instruments.
Any feedback would be very appreciated. I apologize for the quality of the drawing.
 Filesize:  132.75 KB
 Viewed:  29457 Time(s)
PostPosted: Tue Jan 12, 2016 8:23 pm    Post subject: Re: Electrical system design critique Reply with quote
Does the solid state battery contactor conduct in BOTH directions?
Is it rated for starter current?
The 60 amp alternator needs a fuse located close to the contactors.
If the 5 amp alternator field wire shorts out, the 15 amp fuse will likely blow before the circuit breaker trips. I recommend not putting two circuit protection devices in series.
A separate avionics bus is not necessary and introduces unnecessary failure points. Read this thread:
http://forums.matronics.com/viewtopic.php?t=16757246&sid=74d855944e77ced507a5bb87d7f9a72f
and this document:
http://www.aeroelectric.com/articles/avmaster.pdf
Joe Gores
Jump4way
PostPosted: Wed Jan 13, 2016 5:20 am    Post subject: Re: Electrical system design critique Reply with quote
The solid state disconnect is rated at 300 amps with 500 amps for one second. It's not clear to me whether it is rated the same in both directions. Here is a link to the documentation they provide. http://www.waytekwire.com/datasheet/44407.pdf
Good catch on the ANL fuse. I'll put that in.
For the breaker bus feed, would you just leave that 12 gauge wire unprotected from the main bus?
Any comments on the location and usage of the fuse links?
Also, I'm conflicted about the placement of the primary and secondary engine related items. Any recommendation on which bus to locate the primary ECU, ignition, and fuel pump?
Thanks for your time and critique.
jmjones2000(at)mindspring
PostPosted: Wed Jan 13, 2016 6:16 am    Post subject: Electrical system design critique Reply with quote
I can confirm that the solid state contractor does in fact conduct both directions. I'm running this setup already and it works great.
I have an ANL fuse installed by the contractor in the main alternator B lead. I can send pictures if interested. I also have a fuse in the aux alternator b lead.
Andy,
If you wish, I can send you my final diagram on how I wired this exact same setup. I'm very happy with it. I have pictures also.
Justin
http://forums.matronics.com/viewtopic.php?p=451945#451945
PostPosted: Wed Jan 13, 2016 8:59 am    Post subject: Re: Electrical system design critique Reply with quote
The short answer is yes. Ideally every wire should be protected against over current and short circuits. But the consequences of opening a circuit must be considered. In this circuit, over current is not an issue because the circuit breakers protect against that. What about short circuit protection? It depends on the length of the #12 wire and danger of the circuit breaker bus shorting to ground. If good workmanship is used, wires are well supported, and bus is insulated, then I would leave that 15 amp fuse out.
But why even have that bus? Connect the alternator field breaker to the main power bus with a short wire. Move the pitch and roll trim circuits to the essential bus and protect them with fuses, not breakers. If a fuse blows, there is a reason. Wait until safely on the ground to troubleshoot.
Consider replacing the 15 amp avionics fuse with a fusible link.
The DPDT switch, used in series with the diode and used for starter interlock, is unnecessary. If eliminated, it can not break.
Notice on Bob's Z-13/8 that there is a fusible link connected to the top of the endurance bus. That fusible link protects the wire (if shorted) above it from current coming from the main power bus.
Maybe eliminate the fusible link supplying power to the battery bus. If properly installed and insulated, the battery bus will not short to ground. I would rather take a chance on that #12 wire burning open than have the engine quit because the fusible link failed.
Joe Gores
PostPosted: Wed Jan 13, 2016 10:51 am    Post subject: Electrical system design critique Reply with quote
Fusible links are SELDOM needed . . . 99%
of all your branch circuit protection should
be done with fuses/breakers.
Draw up a power distribution diagram . . .
or copy one out of Appenedix Z and
start assigning system loads to the
various busses.
Verbal discussions of design philosophy
and technique is fraught with opportunity
for misunderstanding and error. A drawing
says it all . . . in ANY language.
Jump4way
PostPosted: Wed Jan 13, 2016 6:15 pm    Post subject: Re: Electrical system design critique Reply with quote
First off... thanks to everyone for taking to time to weed through my diagram and offering suggestions.
The idea of having the trim on circuit breakers was to have a means of disconnecting the pitch and roll trim in the rare instance of a runaway trim. I suppose a switch could be used for that regard but I thought circuit breakers would be a better way to kill two birds with one stone. I do not intend to have the need to use the circuit breakers as a switch on any type of regular basis.
I was using this switch as a means to disable to avionics bus during engine start along with a means to disable to starter from the pushbutton on the infinity stick during flight in case it were to be inadvertantly pushed. The switch is rated at 15A which might in itself be a point of failure at some point as you suggest with your link regarding avionics busses.
I added this to my diagram, thanks for point that out.
This was the main fusible link that I was concerned with. I think I'll remove this one as well. The wire run will be well supported and is fairly short.
various busses.
That's what I'm trying to do with the diagram I have uploaded. I know it's not CAD quality but will it not suffice for these discussions and for future reference?
Good advice. I'm trying my best but just as soon as I feel like I am getting the idea, something is said that adds confusion. and example is the following:
As a new builder, I find it challenging to determine where they are recommended and where they are not. Your book does make mention that they should be used primarily in low amerpage circuits so that must be where I am going wrong with some of my decisions. On the other hand, I read things such as using an inline fuse for some of the same situations can be unreliable as fuses blow at a faster rate.
Attached is an updated version of the schematic with a couple of the recommended changes. Any additional advice is appreciated.
Z1320-EFII-5.pdf
 Filename:  Z1320-EFII-5.pdf
 Filesize:  186.86 KB
 Downloaded:  1168 Time(s)
PostPosted: Wed Jan 13, 2016 7:07 pm    Post subject: Re: Electrical system design critique Reply with quote
Having a switch to disable the stick grip start button is a good idea. But disabling the avionics bus is not necessary and introduces a failure point. Notice that none of Bob's diagrams have a switch in series with the diode that feeds the E-Bus.
Did you mean to insert an 18 AWG fuselink, not 20 AWG? If the avionics bus has a few extra fuse slots, the aux input could be back fed through a fuse instead of using a fusible link.
Joe Gores
richard.beebe(at)yale.edu
PostPosted: Thu Jan 14, 2016 7:55 am    Post subject: Electrical system design critique Reply with quote
I never understood the point of installing the starter button on the
stick. It's a button that gets used once per flight so why put it some
place so easy to hit in flight? To me it's kind of like driving with
your hand on the key all the time.
--Rick
Jump4way
PostPosted: Thu Jan 14, 2016 8:01 am    Post subject: Re: Electrical system design critique Reply with quote
Yeah, I guess part of the idea with having an avionics switch was to have to turn something on after engine start which also disables the stick mounted starter switch. I'll do a bit more thinking on that one.
I chose 18 AWG for the fuselink as that was 4 wire sizes smaller from the 14 AWG that I have tying the main bus to the avionics bus. Is that not the correct way of thinking?
As of right now, the avionics bus has a couple of open slots. I was hoping to keep that open for future expansion is possible though.
PostPosted: Thu Jan 14, 2016 9:12 am    Post subject: Re: Electrical system design critique Reply with quote
Yeah, but you put "20" on the latest schematic.
Joe Gores
Jump4way
PostPosted: Thu Jan 14, 2016 11:48 am    Post subject: Re: Electrical system design critique Reply with quote
Oh... That fusible link. I think I might have taken one of Bob's drawing too literally. That's what it shows on the z13/8 in my version of aeroelectric connect. A 20 AWG fusible link for a 14 AWG wire.
 Filesize:  302.35 KB
 Viewed:  29197 Time(s)
N38CW
PostPosted: Thu Jan 14, 2016 1:46 pm    Post subject: Electrical system design critique Reply with quote
HOTAS..... and with VPX it is automatically disabled after engine start so you can hit it all you want in flight.
Sent: Thursday, January 14, 2016 10:52 AM
Subject: Re: AeroElectric-List: Re: Electrical system design critique
--> AeroElectric-List message posted by: Rick Beebe <richard.beebe(at)yale.edu (richard.beebe(at)yale.edu)>
your hand on the key all the time.http://w -Matt Dralle, List =========
Bill Settle
RV-8 Fuselage
Jump4way
PostPosted: Thu Jan 14, 2016 6:51 pm    Post subject: Re: Electrical system design critique Reply with quote
 Filesize:  302.35 KB
 Viewed:  29170 Time(s)
PostPosted: Fri Jan 15, 2016 6:57 am    Post subject: Electrical system design critique Reply with quote
At 08:51 PM 1/14/2016, you wrote:
--> AeroElectric-List message posted by: "Jump4way" <andydelk(at)gmail.com>
In ONE PLACE ONLY . . . the extension of
the main bus to the crowbar OV breaker . . .
and this only in some sense of deference
to design philosophies on TC aircraft.
I may remove all references to fusible links
in Rev 13 . . .
