rv10free2fly(at)yahoo.com Guest
Posted: Mon Jan 04, 2016 12:53 am Post subject: Distance from ground level to wing tiedowns |
I'm looking to purchase two long hydraulic jacks and was wondering if someone could please forward me the measurement from ground level, to the tie down point fitting under the wing.
Is anyone selling fittings that attach to the end of a hydraulic jack and screw into the wing tiedowns?
Warm regards and thanks.
Patrick Pulis
Adelaide, South Australia
RV-10 #40299
Kelly McMullen
Posted: Mon Jan 04, 2016 5:31 am Post subject: Distance from ground level to wing tiedowns |
Don't know the height. Most jacks have indentation in the ram to fit a jack point.
Carriage bolts of the right size have round head that fits that indentation pretty well.
3/8" coarse thread of perhaps 1.5 to 2" works pretty well.
-sent from the microchip implanted in my forearm
On Mon, Jan 4, 2016 at 1:50 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
| Quote: | --> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Patrick Pulis
RV-10 #40299
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Mon Jan 04, 2016 7:19 am Post subject: Distance from ground level to wing tiedowns |
This link has some info on the jacks that you may find useful in estimating the right length jack. Mine are long enough but be sure to factor in that I have steel feet that add a couple inches of length.
These have worked perfectly for years. Just used them this weekend again.
http://www.myrv10.com/tips/generaltips.html#Jacking_the_RV-10
| Quote: | On Jan 4, 2016, at 2:50 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Patrick Pulis
RV-10 #40299
Albert Gardner
Posted: Mon Jan 04, 2016 7:52 am Post subject: Distance from ground level to wing tiedowns |
I use the Harbor Freight long ram jacks. I drilled a hole in the top of the ram and use a threaded stud that screws into the tiedown point and sets in the top of the jack. Can't fall off of the jack this way. When you want to raise the nose wheel just pull down at the tail tiedown.
Albert Gardner
RV-10 N9914RV
Yuma, AZ
52.31 KB |
8607 Time(s) |
41.3 KB |
8607 Time(s) |
_________________ RV-9A N872RV
RV-10 N991RV |
Posted: Mon Jan 04, 2016 8:11 am Post subject: Distance from ground level to wing tiedowns |
I'm curious since there have been a couple of responses that screw into the tiedown and are fixed to the top of the jack. How does the dihedral angle affect insertion into the tiedown ring that's perpendicular to the bottom of the wing?????
Linn painting .... no wings installed
On 1/4/2016 10:48 AM, Albert wrote:
| Quote: | <![endif]--> <![endif]-->
Albert Gardner
RV-10 N9914RV
Yuma, AZ
tomrv4
Posted: Mon Jan 04, 2016 8:53 am Post subject: Distance from ground level to wing tiedowns |
A good question and one I was also concerned about when I built my Harbor Freight jacks.
I used a 1" socket that I screwed a slotted head bolt thru into the tie down. The jack raises into the socket and allows for the wings to rock slightly if necessary. Plus there's no way the plane can fall off the jack...
Tom
On Jan 4, 2016, at 10:07 AM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
| Quote: | I'm curious since there have been a couple of responses that screw into the tiedown and are fixed to the top of the jack. How does the dihedral angle affect insertion into the tiedown ring that's perpendicular to the bottom of the wing?????
Albert Gardner
RV-10 N9914RV
Yuma, AZ
_________________ Tom
San Antonio |
Tim Olson
Posted: Mon Jan 04, 2016 9:32 am Post subject: Distance from ground level to wing tiedowns |
I have and prefer the socket type thing that I did
too, but after looking at Albert's pictures and
reading Linn's email, I think there are just a couple
of comments on that.
I think Albert's idea is workable. The things I don't
like are 1) the dihedral issue that Linn pointed out,
and 2) the use of a completely threaded fastener.
The thing is, if it did rock, the threaded fastener would
have that bending force put on at the top of the jack
and could snap the threaded fastener in half. The problem
would be worse the tighter fit the hole is in the jack
head.
But, in his defense...if you used a big enough hole that
there was some room for the plane to tilt without bending
the bolt in the jack head, there really isn't that much
weight or force on the jack if the plane is kept pretty
level. So there's no reason that idea couldn't be used
if someone wanted to do it that way. I just think
that by using a socket on the upper end, you take away
the risk. If someone really wanted to cobble it together,
I'd say get yourself a metal 1.25" pipe cap and put a bolt
through it with a nut on the back side, then screw that
up into the wing tiedown.
The things I like are then that you can then use a
grade 5 or grade 8 bolt rather than the softer
and weaker carriage bolt or stud.
Anyway, there are many ways to skin the cat. Maybe
less ways to make the cat taste good when you cook it.
On 1/4/2016 10:48 AM, Tom Chapman wrote:
| Quote: | A good question and one I was also concerned about when I built my
the jack...
Tom
>> Albert Gardner
>> RV-10 N9914RV
>> Yuma, AZ
Posted: Mon Jan 04, 2016 10:39 am Post subject: Distance from ground level to wing tiedowns |
The answer is 32" from ground to jack point hole.
My "Harbor Freight" jack had an indentation. I ground it out a bit more to make a solid socket for the head of a carriage bolt as you can see here My 'Harbor Freight' Jack
The jack endured a stability test a few weeks ago when I got stuck in the mud. The big flat ply bottom excelled at sitting on top of the mud as I jacked a wheel at a time up on to some boards and rolled her out. Not damage to pants or anything.
The key to getting out of mud is to get rid of all the willing helpers first - devise a plan then invite back only the person or two you actually need. That wasn't my first rodeo.
On 1/4/2016 8:21 AM, Kelly McMullen wrote:
| Quote: | Don't know the height. Most jacks have indentation in the ram to fit a jack point.
| Quote: | --> RV10-List message posted by: Patrick Pulis <[url=mailto:rv10free2fly(at)yahoo.com.au]rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)[/url]>
Patrick Pulis
RV-10 #40299
br> fts!)
Kellym
Posted: Mon Jan 04, 2016 12:18 pm Post subject: Distance from ground level to wing tiedowns |
Sounds good. What some don't seem to appreciate is that you *need* the
ability of the aircraft to move small amounts while on the jacks. May be
that you are raising nose or tail, may be uneven ground under the jack.
The round head of the carriage bolt works fine. Most retractable
certified planes have jack points that are just more pointy than the
carriage bolt. The risk of the plane slipping off the jack is inversely
proportional to the amount of weight supported by the jack. Highest risk
for the first couple strokes of the jack, much less after that.
On 1/4/2016 11:35 AM, Bill Watson wrote:
| Quote: | The answer is 32" from ground to jack point hole.
<http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=5629&log=108538&row=1>
> jack point.
> <rv10free2fly(at)yahoo.com.au <mailto:rv10free2fly(at)yahoo.com.au>> wrote:
> <<mailto:rv10free2fly(at)yahoo.com.au>rv10free2fly(at)yahoo.com.au>
> Patrick Pulis
> RV-10 #40299
> br> fts!)
> rel="noreferrer" target="_blank">http://www.matronics.com/contribution
> FORUMS -
> eferrer" target="_blank">http://forums.matronics.com
> b Site -
KCHD |
Tim Olson
Posted: Mon Jan 04, 2016 12:34 pm Post subject: Distance from ground level to wing tiedowns |
Yep, and a grade 5 or 8 bolt with a 1.5-2" section of non-threaded area,
with a point ground in where the hex head would be, would
work well with the normal indented top of the jack too. Both
the tip of the bolt, and the dished shape of the jack head, would
prevent it from easily slipping off once the weight of the plane is
on the jack. And you're right, whatever you do, you're not looking
to lock it solidly to the jack at all. It needs to have
movement. My socket that screws into the tiedown is about 1/4"
larger in diameter than the jack head to give it a little wiggle
room of 1/8" on all sides.
On 1/4/2016 2:14 PM, Kelly McMullen wrote:
Posted: Mon Jan 04, 2016 1:37 pm Post subject: Distance from ground level to wing tiedowns |
Many thanks to all.
Warm regards
Patrick
| Quote: | On 5 Jan 2016, at 07:01, Tim Olson <Tim(at)MyRV10.com> wrote:
Yep, and a grade 5 or 8 bolt with a 1.5-2" section of non-threaded area, with a point ground in where the hex head would be, would
