Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Sun Jan 03, 2016 9:08 am Post subject: Aileron trim |
I have a slightly heavy right wing. Probably engine torque but who knows. I want to try aileron trim and wonder if it would be best to put the trim tab up on the right aileron or down on the left aileron; or does it really matter.
Any thoughts appreciated.
rickofudall
Posted: Sun Jan 03, 2016 3:05 pm Post subject: Aileron trim |
Rex, I started off thinking it to be six of one, half a dozen of another as far as a trim tab. Then I got to thinking about it some more. If you deflect an aileron down with a tab, you create lift to raise the wing but also drag to pull it backward (the origins of adverse yaw) so you'll have to add a little rudder to center the ball or yaw string. If you deflect the opposite side up you lose a little lift and a little drag which should level the wings and create less yaw. Or so it appears to me.Do you have any idea what is causing it. Doubtful it is caused by torque, at least no Kolb I've ever flown has had the tendency. Is it a new problem? Anything changed that might have caused it?I'm sorry I don't remember what you fly. With a Mark III you can use the flaps to trim out an imbalance.\
Good luck and Happy New Year
Rick Girard
On Sun, Jan 3, 2016 at 11:08 AM, Rex Rodebush <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Rex Rodebush" <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=451661#451661
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
“Blessed are the cracked, for they shall let in the light.�   Groucho Marx
Richard Pike
Posted: Sun Jan 03, 2016 9:32 pm Post subject: Re: Aileron trim |
If I were you, I would put something like this trim tab on the left wing aileron, with the tab down, to push the aileron up, hopefully to get the wings to trim out evenly and level up.
If the wings then level up, but the ball is not in the center, then you would have to adjust it out with a trim tab on the rudder.
For planning purposes: attach your trim tabs in the most unobtrusive way possible, so that if you end up having to rearrange things, you have not painted yourself into a corner.
http://oh2fly.net/oldpoops/pg6.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
patrickjladd(at)hotmail.c Guest
Posted: Mon Jan 04, 2016 4:19 am Post subject: Aileron trim |
Rex,
I had trouble with one wing with a tendency to drop on my Extra.. Finally solved it by adjusting AOA of the wing. The Xtra has a choice of attachment points, cant remember if it raised or lowered the leading or trailing edges. If you have that facility try that first, it is simple to do. Go on to trim tabs next. Good luck. Pat
Sent: Sunday, January 03, 2016 5:11 PM
Subject: Kolb-List: Aileron trim
--> Kolb-List message posted by: "Rex Rodebush" <jrrodebush(at)gmail.com>
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-=
_-= * The Builder's Bookstore www.buildersbooks.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - List Contribution Web Site -
Watkinsdw
Joined: 15 Mar 2009 Posts: 138 Location: Deerfield Beach, FL
Posted: Mon Jan 04, 2016 5:07 am Post subject: Re: Aileron trim |
I find that my 2001 Mk III requires a little more or less left stick pressure depending on whether I'm flying solo or with a passenger. To adjust for this, I change the configuration of spacer washers in my left universal joint. It's been awhile, and I'm not at the hangar right now, but here goes- I have three washers, in the "U" joint. When I fly solo, I think I put two washers above and one below the wing connection, and when I fly with a passenger, I fly solo, I put two below and one above. I think that's right. The adjustment raises or lowers the trailing edge of the whole wing slightly and trims the roll nicely. Obviously, if I'm just flying occasionally with a passenger, I just suck it up and fly with the washers in the solo position, getting a little more exercise on my right arm. I also have a pretty substantial trim tab on my tail. In either case, I don't seem to have noticeable adverse yaw.
Dave Watkins
Pompano Beach
Mk III Classic
Richard Pike
Posted: Mon Jan 04, 2016 7:07 am Post subject: Re: Aileron trim |
| Watkinsdw wrote: | I find that my 2001 Mk III requires a little more or less left stick pressure depending on whether I'm flying solo or with a passenger. To adjust for this, I change the configuration of spacer washers in my left universal joint. It's been awhile, and I'm not at the hangar right now, but here goes- I have three washers, in the "U" joint. When I fly solo, I think I put two washers above and one below the wing connection, and when I fly with a passenger, I fly solo, I put two below and one above. I think that's right. The adjustment raises or lowers the trailing edge of the whole wing slightly and trims the roll nicely. Obviously, if I'm just flying occasionally with a passenger, I just suck it up and fly with the washers in the solo position, getting a little more exercise on my right arm. I also have a pretty substantial trim tab on my tail. In either case, I don't seem to have noticeable adverse yaw.
Dave Watkins
Pompano Beach
Mk III Classic |
That seems like a lot of work compared to the 20 seconds it takes to reset an adjustable trim tab.
For a more permanent adjustment on an airplane where the wings have a different angle of attack, Kolb makes and sells an offset U-joint bracket. I don't know what they charge for them, but I have one I don't need. Be glad to sell it for the cost of shipping. It is for a MKIII/FSII, don't know if it will fit the Xtra. PM me.
127.75 KB |
14185 Time(s) |
Kingsport, TN 3TN0
Watkinsdw
Posted: Mon Jan 04, 2016 7:15 am Post subject: Re: Aileron trim |
Good looking solution, Richard. You would still need to pull the bolt and flip the u-joint, but not have to fiddle with the washers. Sounds like the Extra has an even simpler solution.
Thanks for the input.
Dave
Rex Rodebush
Posted: Tue Jan 05, 2016 2:58 pm Post subject: Re: Aileron trim |
Thanks to all who responded, on and off line. I'm going to try a flap adjustment first and then aileron trim if the flap trim is not successful. If that causes more problems I'll probably just live with it. Solo the required stick pressure is just a few ounces by my estimation. With a 220# passenger it is much more noticeable. I will keep the washer/wing angle as a possibility for the future. I'll post the results when known.
Posted: Tue Jan 05, 2016 5:34 pm Post subject: Aileron trim |
Rex/Gang:
I use a small piece of bungee cord from the aileron torque tube to the
control stick. Each end is looped around the tube and secured with a small
1/4" wide hose clamp.
Will work on dual controls and single center stick. On a single center
stick find a place to secure the stationary end of the bungee.
Adjustment is infinite. When the moving end on the stick is at its lowest
point there is neutral forced trim. Moving the loop up the stick increases
trim force.
I have used this system on my MKIII for 23 years. In fact, I recently
changed out the original piece of bungee. My bungee looks like it may be
1/2" in diameter.
This is a simple way to get the job done effectively without drill holes,
popping rivets, hanging sheet metal and Lexan on an aileron, changing out
wing mounts, etc.
Be glad to post photos next time I go over to Gantt International Airport,
when the temps get above freezing.
_________________ John Hauck
Titus, Alabama |
ceengland7(at)gmail.com Guest
Posted: Tue Jan 05, 2016 6:49 pm Post subject: Aileron trim |
I like John's method. I've never owned/flown a Kolb, but the 'standard'
aileron trim for the 2 seat RV-x's is very similar to John's method. The
RV's use a lever that has its pivot on the control stick, and springs
from the lever to convenient solid points on either side of the stick.
moving the lever increases tension on one spring; decreases it on the
other. This supplies a bias to the stick just like what John is
describing. Very effective on the RVs, it's cheap, and weighs almost
nothing. In flight, you can't tell it's there, and RV's have pretty
light controls.
On 1/5/2016 7:34 PM, John Hauck wrote:
Rex/Gang:
trim force.
1/2" in diameter.
wing mounts, etc.
Posted: Wed Jan 06, 2016 2:50 am Post subject: Aileron trim |
I had quite forgotten Johns patent elastic trim. John described it on the list years ago and I fitted it straight away. Foolproof, maintenance free, cheap, easily inspected. What could be better? I fitted mine to my Xtra after I had balanced the wings with the AOA adjustment. The infinitely adjustable bungee took care of the fine tuning by sliding the loop around the stick higher or lower, and the fact that I almost always flew alone and my weight was therefore always left of the centreline. I did not use bungee cord but a complete bungee with hooks from a supermarket. I think that I hooked one end of the bungee to the underside of the passenger seat somewhere, round the stick twice and back under the seat. Of course this does not trim the plane aerodynamically, merely takes the weight off the stick.
Well worth doing nevertheless.
Pat
Sent: Wednesday, January 06, 2016 1:37 AM
Subject: RE: Kolb-List: Re: Aileron trim
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
Rex/Gang:
trim force.
1/2" in diameter.
wing mounts, etc.
-----Original Message-----
[mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Rex Rodebush
Sent: Tuesday, January 05, 2016 4:58 PM
Subject: Kolb-List: Re: Aileron trim
http://forums.matronics.com/viewtopic.php?p=451779#451779
_-=
_-=
_-= by:
_-=
_-=
_-=
_-=
_-=
_-=
_-=
_-=
_-=
_-=
Posted: Sun Jan 10, 2016 11:46 am Post subject: Aileron trim |
Date: Jan 03, 2016
< Doubtful it is caused by torque, at least no Kolb I've ever flown
has had the tendency. >
If you have an engine on an aircraft there will always be a torque
component in play as long as the engine is operating under load.
For example, a Rotax 912 81 hp engine generates 75.9 ft-lb torque at
4800 rpm. Add a 2.43:1 gear box and the torque at the propeller goes
to 184 ft-lb. This means it will take about an 18 lb vertical force
at the wing tip to keep the wings level.
Jack B. Hart FF004
Winchester, IN
