Finishing kit mods
Goto page 1, 2  Next
ogdenk
PostPosted: Wed Dec 30, 2015 1:44 pm    Post subject: Finishing kit mods Reply with quote
Hi all,
As I am progressing on my fuselage I want to get my finishing kit ordered. I know there had been some issues with axle extensions, wheels etc. and I am looking for advice on what parts maybe should be omitted with plans on buying better/more appropriate parts.
I had Vans send me the parts list so I could customize prior to ordering, here are some of the landing gear parts that I was wondering about:
2.00 U 15X6.0-6   MAIN TIRE 6 PLY RV-10
2.00 U 15X6.0-6IT   INNER TUBE MAIN RV-10
1.00 U 5:00X5-6  6 PLY TIRE MAIN GEAR
1.00 U 5:00X5-6IT TUBE FOR 5:005-6
1.00 U-00011     GROVE WHL&BRK 6X6.00
1.00 U NW501.25   NOSE WHEEL W/BEARINGS
I don't see any axle extensions (U-1004B) listed as mentioned on Tim Olson's page here:
http://www.myrv10.com/N104CD/upgrades/20070118/index.html
although the U-1004A axle nuts are listed.
I am interested in upgrading the brakes (also mentioned on Tim Olson's site) but I don't know anything about the interchangeability of these parts, so advice there would be welcomed. There is a brake mount:
2.00 U-1003-PC   BRAKE MOUNT
and I wonder if this would work with other (Matco?) brakes.
Scanning the finishing kit list, I didn't see anything else that was obvious that I would want to omit, but if there are any other suggestions I would be happy to hear them.
Thanks.
Kent Ogden
#40710 (ultra-slow build option)
johngoodman
PostPosted: Wed Dec 30, 2015 2:02 pm    Post subject: Re: Finishing kit mods Reply with quote
It looks like you're thinking about a brake modification. A friend of mine who also owns an RV-10 just did his this Fall. He went with the Matco mod:
http://www.matcomfg.com/WHLBRKWI600225KftlbenergyeXtraTorqueRV10CONFIG-idv-3814-4.html
I flew it one time and it does feel like there is more brake there. Your mileage may vary....
Kelly McMullen
PostPosted: Wed Dec 30, 2015 7:06 pm    Post subject: Finishing kit mods Reply with quote
While some have had issues with the original Cleveland brakes the -10 was designed with, I've not heard any issues with the Grove brakes. Quite frankly, I believe every -10 I have flown had the Clevelands, and they seemed plenty adequate.
Not sure I see the benefit of being able to flat spot the tires faster. More brakes won't help on gravel or grass. Very few paved runways are that marginal for the -10.
I would definitely do the nose wheel change to the proper Matco. I think Tim had a list of the proper tires and tubes. I chose to buy all retreads from Desser, because they seem to last a lot longer on the hot runways of Aridzona. Leakguard or Air Stop tubes are desirable.  Some have pointed out that the much more common and cheaper 6:00X6 tire will fit the wheel pants, and has the same load rating for given number of plies as the Vans choice of 15X6:00X6 tire.
-sent from the microchip implanted in my forearm
On Wed, Dec 30, 2015 at 3:02 PM, johngoodman <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)> wrote:
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
http://forums.matronics.com/viewtopic.php?p=451533#451533
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Bob Turner
PostPosted: Wed Dec 30, 2015 7:49 pm    Post subject: Re: Finishing kit mods Reply with quote
IIRC, The stock axle extensions are just cut from hex-cross section stock. They are too small in diameter, the larger diameter after-market replacements are very desirable - I'd say necessary.
Bob Turner
RV-10 QB
jesse(at)saintaviation.co
PostPosted: Wed Dec 30, 2015 7:59 pm    Post subject: Finishing kit mods Reply with quote
If you fit the wheel pants to 6.00x6 tires they will fit. If you fit them per the plans with 15/6.00x6 tires then change to 6.00x6, they will hit the top of the wheel pant, or at least the nutplates, or at the very least the screws. Ask me how I know.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Dec 30, 2015, at 10:03 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
br> fts!)
Bob Turner
PostPosted: Wed Dec 30, 2015 8:23 pm    Post subject: Re: Finishing kit mods Reply with quote
BTW, the talk about the Cleveland wheels and brakes is mostly academic; current -10 kits don't have them.
Bob Turner
RV-10 QB
Kelly McMullen
PostPosted: Thu Dec 31, 2015 5:37 am    Post subject: Finishing kit mods Reply with quote
Yes, except the Clevelands were what prompted builders to look for alternatives.
The question then becomes whether the Groves are in anyway deficient to where one needs to deviate from plans and substitute Matco. Each modification costs money and more significantly extra build time. BTDT.
On Wed, Dec 30, 2015 at 9:23 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=451544#451544
br> fts!)
Kelly McMullen
KCHD
partner14
PostPosted: Thu Dec 31, 2015 6:05 am    Post subject: Finishing kit mods Reply with quote
As far as I'm concerned the stock axle extensions are not adequate.
I made about 30 sets. Attached is a pic (mod vs. stock).
Don McDonald
Sent: Wednesday, December 30, 2015 3:41 PM
Subject: RV10-List: Finishing kit mods
Hi all,
Thanks.
Kent Ogden
 Filesize:  80.58 KB
 Viewed:  21874 Time(s)
Don A. McDonald
40636
carl.froehlich(at)verizon
PostPosted: Thu Dec 31, 2015 7:20 am    Post subject: Finishing kit mods Reply with quote
I skipped the Van’s main gear wheel pants and used the James Aircraft pants: http://www.jamesaircraft.com/?page_id=47
While I like the much tighter fit, I would estimate these to be a little more work to fit than the stock Van’s pants.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Thursday, December 31, 2015 9:02 AM
To: rv10-list(at)matronics.com; Kent Ogden
Subject: Re: Finishing kit mods
Don McDonald
From: Kent Ogden <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)>
Subject: Finishing kit mods
Hi all,
Thanks.
Kent Ogden
ogdenk
PostPosted: Thu Dec 31, 2015 7:58 am    Post subject: Finishing kit mods Reply with quote
John,
My motivation there is that we are looking to retire out west (eventually) and some of the places we like are at pretty high elevation.  A good example is Flagstaff AZ at around 7,000'. Touchdown speeds will be pretty high with a lot of energy to dissipate at that altitude and beefier brakes seem like a good idea. Having said that, it sounds like the current brakes are better than the original Clevelands and there may be no reason to spend the extra money on the Matco mod.
Kent
>> "johngoodman" <johngoodman(at)earthlink.net> 12/30/2015 5:02 PM >>>
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
rjones560xl@gmail.com
PostPosted: Thu Dec 31, 2015 8:16 am    Post subject: Finishing kit mods Reply with quote
I bought the wheels and brakes from Matco. They have a complete set a wheels and brakes set up for the RV10. Their front axle is way better than Van's. Bearing preload is set with a separate nut instead using the axle bolt. The axle can't turn on the bolt because it is kept from turning by an off center cap screw on one end. Their brakes have 3 piston calipers and the linings have twice the brake energy limits as the original Van's supplied brakes. The two piston Grove brakes currently supplied by Van's are better than the original, but not as good as Matco's. I bought Goodyear Flight Custom III tires and but buteral tubes (the no leak type).
Robert Jones
On Dec 31, 2015, at 07:55, Kent Ogden <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)> wrote:
John,
Kent
>> "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)> 12/30/2015 5:02 PM >>>
Robert J Jones
702-521-1840
flying-nut(at)cfl.rr.com
PostPosted: Thu Dec 31, 2015 8:29 am    Post subject: Finishing kit mods Reply with quote
FWIW, those high elevation runways are longer ..... FLG is 8800' ..... which is huge compared to my 4000' SL airport ...  X59.
I'm used to steep approaches with full flaps which shortens the energy vector down the runway.  It does take some finesse in the flare and I've yet to land a -10 Razz  .    I'd compare the -10 to a Grumman AA-5X ..... fast, sleek etc. but I'd like to hear from pilots that have flown both.
Linn .... Pitts S-1E, Grumman AA-1B, Traumahawk .... painting the -10
On 12/31/2015 10:55 AM, Kent Ogden wrote:
John,
Kent
>>> "johngoodman" <johngoodman(at)earthlink.net> (johngoodman(at)earthlink.net) 12/30/2015 5:02 PM >>>
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net> (johngoodman(at)earthlink.net)
Kellym
Most airports at higher elevations have plenty of runway to deal with
the higher true airspeed touchdown, Flagstaff included. Mostly runway
length is dictated by takeoff needs for the D/A, not landing roll.
I have landed at plenty of high D/A airports (7000+ elev) with my
Mooney, which has same approach speeds, stall speed within a knot or two
and same typical wts. Empty wt within 5 lbs of each other. It is
equipped with early '60s vintage Cleveland brakes. Braking is not an
issue. Staying on speed for approach, adjusted for actual wt is the key.
If you have an AOA installed, that should be very easy.
IMHO, YMMV.
The book landing distance for the Mooney at gross 2575 lbs is 1550 sea
level, 1795 at 7500 D/A at standard temps. Obviously that will go up
with summer temps perhaps 20 above standard. FLG runway length is 8800.
On 12/31/2015 8:55 AM, Kent Ogden wrote:
John,
Kent
Matco mod:
Kelly McMullen
KCHD
bcondrey
PostPosted: Thu Dec 31, 2015 9:12 am    Post subject: Finishing kit mods Reply with quote
While the upgraded (Matco) mains/brakes are nice, I've taken off and landed my first RV-10 with Cleavelands at KFLY several times, once with a DA of 11,200!  As has been said, high altitude runways are typically much longer than normal.  Combine that with the fact that RV-10s can get into and out of short strips with ease, you won't have a problem even with the original Cleavelands.
Where you would have an issue with the Cleavelands is in an aborted takeoff scenario.  If youre taking off on a short runway at gross weight and have to abort at the last sec before flying.  Getting on the brakes hard with that much built up energy, you'll like experience some brake "fade" from the heat build up.  My recollection is that the Cleavelands are rated for a 3000 pound gross so a loaded 10 is getting close to that.  The Matcos are much heavier duty  with dual calipers so that won't be an issue.
On Thursday, December 31, 2015, Kent Ogden <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)> wrote:
John,
Kent
>> "johngoodman" <[url=javascript:_e(%7B%7D,'cvml','johngoodman(at)earthlink.net');]johngoodman(at)earthlink.net[/url]> 12/30/2015 5:02 PM >>>
--> RV10-List message posted by: "johngoodman" <[url=javascript:_e(%7B%7D,'cvml','johngoodman(at)earthlink.net');]johngoodman(at)earthlink.net[/url]>
jmjones2000(at)mindspring
PostPosted: Thu Dec 31, 2015 9:37 am    Post subject: Finishing kit mods Reply with quote
If you must use Cleaveland Brakes, the best part number to use is the 30-52N. These are the double puck brakes that have the "blisters" on the caliper and use the thicker rotors. Airframes Alaska is a pma manufacturer and uses these brakes exclusively on their installs of 31" and 35" Alaska Bushwheels. These can be installed on a C185 and stop the 3300lb airplane from 65 kias with no problems. This setup absorbs a great deal of energy from a large spinning mass and heavy weights. This is by far the most proliferated brake setup on wheeled planes in Alaska. Anyone here using them on the -10?
I am however, a bigger fan of the Matco products. Far less expensive, and I have yet to meet a single owner who doesn't love them and swear they outperform the Cleaveland wheels.
On Dec 31, 2015, at 21:09, Bob Condrey <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
John,
Kent
>> "johngoodman" <[url=javascript:_e(%7B%7D,\'cvml\',\'johngoodman(at)earthlink.net\');]johngoodman(at)earthlink.net[/url]> 12/30/2015 5:02 PM >>>
--> RV10-List message posted by: "johngoodman" <[url=javascript:_e(%7B%7D,\'cvml\',\'johngoodman(at)earthlink.net\');]johngoodman(at)earthlink.net[/url]>
flysrv10(at)gmail.com
PostPosted: Thu Dec 31, 2015 2:48 pm    Post subject: Finishing kit mods Reply with quote
I have the original axel extension and fly out of grass strip. 1100+ hours and no issues.
Do not archive.
Rob Kermanj
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=451540#451540
PostPosted: Thu Dec 31, 2015 3:34 pm    Post subject: Finishing kit mods Reply with quote
An RV-10 based at a 1900' strip at 5000msl in Mexico installed the Matco Brakes after the Cleveland Brakes didn't stop the plane on a hot landing. He feels much better landing with the Matco's.
Jesse Saint
352-427-0285
On Dec 31, 2015, at 12:33 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
John,
Kent
Mauledriver(at)nc.rr.com
PostPosted: Sat Jan 02, 2016 6:52 am    Post subject: Finishing kit mods Reply with quote
The aftermarket extension was the very first accessory I bought for my
'10 back in 1996. It finally flew late in 2011 when I put the pants on
after engine break-in. A little over 500 hours and approximately 150
operations off of a grass strip, one of the extension ends stripped and
had to be replaced.
I like the aftermarket part - it looks good and appropriate to the
task. My guess is that the original axle extension works just fine as
well though it doesn't quite look up the stresses and strains I imagine
the part enduring. Key words here are 'like', 'guess', 'look' and
'imagine'. I don't recall anyone here actually having a bad experience
with the original part or design (?).
If I were building again I think I'd use the original part and if it
failed, replace it with the aftermarket one.
Do not archive.
Rob Kermanj
> Bob Turner
> RV-10 QB
partner14
PostPosted: Sat Jan 02, 2016 8:00 am    Post subject: Finishing kit mods Reply with quote
Here's the reason I made the extensions.... I thought the originals were wimpy. So after making 1 set for my plane, a friend of mine, with a 10 already flying, stopped by and saw them on my plane. Thought they looked a lot better.... well not 3 weeks later he came by and asked if I could make him a pair because one of his broke. At that point, I gave him mine and made up a bunch of them.
That's my story, and I'm sticking to it. Really wouldn't want to be 1,000 miles from home with a broken one.
Don McDonald
Sent: Saturday, January 2, 2016 8:48 AM
Subject: Re: Re: Finishing kit mods
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
had to be replaced.
--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Do not archive.
Rob Kermanj
> On Dec 30, 2015, at 9:49 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
&gt://www.matronics.com/contribution" target="_blank">http://www.matronics.cbsp; -Matt Dralle, List Adsp; --> http://forums.matronics.comhttp://www.matronics.com/contribution</a=============
Don A. McDonald
40636
PostPosted: Sat Jan 02, 2016 9:49 am    Post subject: Finishing kit mods Reply with quote
I had the original parts on a plane and one side broke, taking the wheel pant with it. The bolt holding the rod to the axle nut is what broke. I won't use the stock part. If a plane comes into my shop with them, I replace them with the aftermarket parts.
Jesse Saint
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Jan 2, 2016, at 9:48 AM, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
The aftermarket extension was the very first accessory I bought for my '10 back in 1996. It finally flew late in 2011 when I put the pants on after engine break-in. A little over 500 hours and approximately 150 operations off of a grass strip, one of the extension ends stripped and had to be replaced.
I like the aftermarket part - it looks good and appropriate to the task. My guess is that the original axle extension works just fine as well though it doesn't quite look up the stresses and strains I imagine the part enduring. Key words here are 'like', 'guess', 'look' and 'imagine'. I don't recall anyone here actually having a bad experience with the original part or design (?).
If I were building again I think I'd use the original part and if it failed, replace it with the aftermarket one.
> Do not archive.
> Rob Kermanj
> Sent from my iPad
>> Bob Turner
>> RV-10 QB
Goto page 1, 2  Next
Page 1 of 2
