speedy11
Joined: 29 Jun 2015 Posts: 62 Location: Port Orange, FL
Posted: Sun Dec 13, 2015 8:22 am Post subject: Pitot Static |
Jorgen,
I believe your analysis is correct. I suspect the selector valve is the problem. We have a replacement on the way.
In summary,
1. Accomplished a ground pitot-static check. Right side was normal with no leak. Left side had no indications. Indications in both cockpits were the same.
2. Flew the jet using the right side system and got airspeed and altimeter indications slow to respond. Indications in both cockpits were the same.
3. Did another ground pitot-static check with same results as before.
4. Flew the jet with same results described above.
5. Disconnected lines from pitot boom and from water trap in wheel well and blew air through the lines to confirm no restrictions. The boom on each side was clear and the lines to the water trap were clear.
So, we are narrowed to the lines between the water trap and the selector valve or the valve itself.
I am not familiar with how the selector valve functions, but Bill Culberson told me the selector is usually the problem.
Looking at the amount of throw available on the valve I suspect it is not a ball valve, but rather a simple diverter valve.
You mentioned a poor bypass job. What is a bypass job? Is that a repair to the valve?
Thanks for your help.
Stan
| Quote: | Hi Stan
Ok all noted.
There must be a restriction in the lines somewhere. You have already elimin
ated the possibility of leaks, and there is no blockage from the pitot tube t
o the fuselage.
In the standard configuration, the lines from both sides are fed to the sele
ctor valve in the front cockpit, i was hoping to narrow the search for the r
estriction by checking the response from the left pitot system, i.e. Slow re
sponse from the left side as well would indicate a restriction downstream o
f the selector, normal operation would have indicated a restriction between t
he selector and the wing....
With that not possible, and in light of the left side being inoperative, i w
ould start the search for a restriction around the selector. Presumably bot
h front and rear cockpits are slow to indicate. If so, the fault ls before t
he lines are divided between the 2 cockpits and instruments. , which brings u
s back to the selector valve , or the tubing between the selector valve and t
he water traps in the root of the wing.
You say you found no restrictions from the pitot tube to the fuselage, presu
mably you mean up to the water traps? That would be the easy, accessible pl
ace to check.
My gut feeling says its the selector valve...either not fully in position th
erefore restricting the lines, or a bad bypass job.
Keep us updated...i have family here for christmas but will try check the di
agrams later...
Regards Jorgen |
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
jorgen.nielsen(at)mweb.co Guest
Posted: Sun Dec 13, 2015 10:26 pm Post subject: Pitot Static |
Hi Stan
OK all sounds good. By bypass job, what I meant was that perhaps the previous owners had a problem with the left standby pitot / static system and decided to bypass the selector valve system.
Which is also an option for you now. If you are not going to fix the left side pitot system and get it serviceable, there is no point having the selector valve. Therefore you could remove and bypass the selector. It will eliminate one potential failure point.
It is nice to have though, but ensure the selector is operational. The last time we did a ground check, we checked both sides and all was well. However, some time later I had a pitot system failure in flight and had the ASI under-read horribly. On take off on a hot day, I thought she was sluggish as it took longer to get to flying speed, then my airspeed would not come up. At first I suspected an engine power problem, but realised through control response and then GPS ground speed that I had a faulty ASI. In flight, I then attempted to switch to the standby left side, but could not move that selector switch! It was jammed solid. So I returned to base and landed minus the ASI. On the ground I then managed using both hands to operate the valve. The fault turned out to be a split pipe close to the water trap.
I have the MGL EFIS in the front cockpit, and re-arranged the old instruments to provide a backup / partial panel type setup, so I still have an analogue ASI, altimeter etc. I have thought if I ever need to work on the panel / air system again, I will remove the selector switch (or just bypass it), and feed the right side pitot static system to the EFIS, and the left side system to the backup instruments. That way I have full time redundancy, which in my mind is better than the original design.
I just mention that in case it triggers any thoughts in your mind, seeing as how you are working on the system. Let us know how it goes.
Regards Jorgen
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of speedy11(at)aol.com
Sent: Sunday, 13 December 2015 18:22
To: l29-list(at)matronics.com
Subject: Re: Pitot Static
Jorgen,
In summary,
Stan
Hi Stan
Ok all noted.
o the fuselage.
ace to check.
agrams later...
Regards Jorgen |
