Slick Mag 1100 hrs.
flysrv10(at)gmail.com
PostPosted: Sun Dec 06, 2015 12:20 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
On my last flight, I felt a miss on climb out so I decided to pull the mags and take a look.
As soon as I pulled the mags, I noticed that pieces of Mag Drive Cushions were missing on both mags and I could not find them in the mag hole.
So I drained the oil and pull the Oil Suction Screen out and to my pleasant surprise, both pieces were found in the strainer.
The part no. for the cushions is LW13641. I recommend that they are replaced every time the mags are pulled out. The new parts feel soft and the old parts were brittle, I assume due to heat.
The cushions are held in place temporarily with fuel lube during the mag installation so you want to be sure they do not fall out while you are inserting the mag into the drive.
The mag components all checked out and everything looked good. I cleaned all the parts and replaced one rotor and the engine runs very smooth now. Not sure if the cushions had anything to do with the engine miss or not.
DO NOT ARCHIVE.
[img]cid:5E5F43BF-481A-4149-B595-9C1EA22F89EF(at)flbb.net[/img] Rob Kermanj
[img]cid:FA72B4DA-6575-49EF-89BA-C679997922E0(at)flbb.net[/img]
 Filesize:  70.25 KB
 Viewed:  9441 Time(s)
 Filesize:  62.78 KB
jmjones2000(at)mindspring
PostPosted: Sun Dec 06, 2015 2:22 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
Sounds like the perfect excuse to switch to electronic ignition!
DO NOT ARCHIVE
On Dec 6, 2015, at 12:16, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
DO NOT ARCHIVE.
<IMG_1922.jpeg>
 Filesize:  70.25 KB
 Viewed:  9437 Time(s)
PostPosted: Sun Dec 06, 2015 2:40 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
Sure does. Just talked to my neighbor that just installed dual electronic. Has not started the engine yet.
Do not archive.
On Dec 6, 2015, at 5:19 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1922.jpeg>
 Filesize:  70.25 KB
 Viewed:  9435 Time(s)
jump2(at)sbcglobal.net
PostPosted: Sun Dec 06, 2015 2:56 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
Please don't start that again you already lost.
On Dec 6, 2015, at 4:19 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1918.jpeg> Rob Kermanj
<IMG_1922.jpeg>
PostPosted: Sun Dec 06, 2015 3:00 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
I have been running the EFII system and couldn’t be happier! Just cover the mag holes altogether. What a great system!
On Dec 6, 2015, at 1:37 PM, Flysrv10 <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Do not archive. Sent from my iPhone
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1922.jpeg>
Albert Gardner
PostPosted: Sun Dec 06, 2015 4:28 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
Has anyone installed the 6 cylinder P Mags now that they are finally available?
Albert Gardner
N991RV
Yuma, AZ
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Justin Jones
Sent: Sunday, December 06, 2015 3:57 PM
Subject: Re: Slick Mag 1100 hrs.
Do not archive.
DO NOT ARCHIVE
DO NOT ARCHIVE.
<IMG_1918.jpeg>
Rob Kermanj
<IMG_1922.jpeg>
RV-9A N872RV
RV-10 N991RV
Dave Saylor
PostPosted: Sun Dec 06, 2015 5:32 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
I installed two Slicks on a newer Lycoming at work the other day.  The drive pads were a different design with tabs that engaged slots in the drive gears.  It was pretty easy to feel the pads snap into place, and once engaged they stayed in place really well.
I know in the past (my own plane in particular) I've battled trying to keep the pads in place while wresting the mags into the holes.  The new design makes it pretty easy.
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
DO NOT ARCHIVE.
Rob Kermanj
 Filesize:  62.78 KB
 Viewed:  9430 Time(s)
 Filesize:  70.25 KB
--Dave
KWVI
Kellym
PostPosted: Sun Dec 06, 2015 6:40 pm    Post subject: Slick Mag 1100 hrs. Reply with quote
Think through your backup plan very carefully. A friend with one P mag
and one E mag had both damaged by a faulty VR, which allowed system
voltage around 20V. Both quit sparking at the same time. He had to make
the impossible turn, and luckily made it back to the runway.
> Do not archive.
> Sent from my iPhone
>> DO NOT ARCHIVE
>>> mag hole.
>>> DO NOT ARCHIVE.
>>> <IMG_1918.jpeg>
>>> Rob Kermanj
>>> <IMG_1922.jpeg>
Kelly McMullen
KCHD
Tim Olson
You don't happen to have the info on the p/n or manufacturer and compatibility with our IO-540's do you?
I've had mine out a couple times but have not replaced them and they're almost 1200 hours old so I figured I'd order 2 or 3 pairs, since I'll have 2 airplanes to care for.
On Dec 6, 2015, at 7:29 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave
DO NOT ARCHIVE.
Rob Kermanj
<IMG_1922.jpeg>
 Filesize:  70.25 KB
 Viewed:  9429 Time(s)
PostPosted: Mon Dec 07, 2015 4:48 am    Post subject: Slick Mag 1100 hrs. Reply with quote
Tim,
Although having a fool-proof part is the way to go, the fuel lube solution works well but needs care to install.
If you can't fit the redesigned cushions in your installation, I would not hesitate to use fuel lube.
Do not archive.
On Dec 6, 2015, at 9:37 PM, Tim Olson <Tim(at)MyRV10.com (Tim(at)myrv10.com)> wrote:
--Dave
DO NOT ARCHIVE.
<IMG_1918.jpeg>
Rob Kermanj
<IMG_1922.jpeg>
 Filesize:  70.25 KB
 Viewed:  9411 Time(s)
Dave Saylor
PostPosted: Mon Dec 07, 2015 7:57 am    Post subject: Slick Mag 1100 hrs. Reply with quote
I poked around and found Lyc Service Instruction 1299B. It has p/ns, pictures, applicability, yada yada. I'm not sure if they work on all Lycomings but the SI gives SN ranges. --D
On Sunday, December 6, 2015, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
On Dec 6, 2015, at 7:29 PM, David Saylor <[url=javascript:_e(%7B%7D,'cvml','saylor.dave(at)gmail.com');]saylor.dave(at)gmail.com[/url]> wrote:
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <[url=javascript:_e(%7B%7D,'cvml','flysrv10(at)gmail.com');]flysrv10(at)gmail.com[/url]> wrote:
DO NOT ARCHIVE.
Rob Kermanj
<IMG_1922.jpeg>
 Filesize:  70.25 KB
 Viewed:  9410 Time(s)
--Dave
KWVI
PostPosted: Tue Dec 08, 2015 3:54 am    Post subject: Slick Mag 1100 hrs. Reply with quote
Just a clarification: The SB shows a new cushion design and a new mag drive as a matched set that prevents the cushions falling into the case during installation. The issue of the cushions getting brittle, breaking and falling into the case remains.
On Dec 7, 2015, at 10:52 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
I poked around and found Lyc Service Instruction 1299B. It has p/ns, pictures, applicability, yada yada. I'm not sure if they work on all Lycomings but the SI gives SN ranges. --DOn Sunday, December 6, 2015, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
On Dec 6, 2015, at 7:29 PM, David Saylor <[url=javascript:_e(%7B%7D,\'cvml\',\'saylor.dave(at)gmail.com\');]saylor.dave(at)gmail.com[/url]> wrote:
--Dave
On Sun, Dec 6, 2015 at 12:16 PM, Rob Kermanj <[url=javascript:_e(%7B%7D,\'cvml\',\'flysrv10(at)gmail.com\');]flysrv10(at)gmail.com[/url]> wrote:
DO NOT ARCHIVE.
<IMG_1922.jpeg>
