Ben-PA
Posted: Wed Jul 05, 2006 11:07 am Post subject: made it! |
I bought a Grand Rapids Sport EFIS in May and started the installation in my Model 5. I finally finished it June 27th after changing some things around, making a new panel, and scratching my head a lot.
As I was doing final assembly, I was asked how much longer it was going to take as the Susquehanna River was going to flood the airport (N13) again! Crest was expected Thursday afternoon.
I was ready to go by 6 PM (Tues.), but it was pouring. I woke up at 3 AM to sounds of a downpour and wondered what to do if I couldn't fly out. I was even concerned about the plane starting at all since I replaced the keyed ignition switch with a push button and had all the rocker switches apart twice while I made a new panel. In addition, I wired the EFIS to shared terminals.
I couldn't sleep, so (at) 5 I turned on the TV and the radar showed clearing by 7. I was at the airport by then, but was fogged in. The water was over part of the runway, the airport access road, and was coming up through the storm drain on the ramp. Flood stage is 19 ft. and 23 ft. floods the storm drain. 24 ft. puts water in my hangar. Crest was expected (at) 30.
Finally at 8:30 AM, after an hour and a half delay, I pushed my plane through 8 inches of water with about half of the 2800 foot runway under water. The engine actually fired, the EFIS worked, and I made the 15 minute flight through the scud at about 400 ft. ATR (above the river) following it to Danville. It sure looks different barreling down the runway toward a lake!
I only have 12 solo hours and this was my first experience flying through fog.
Only a Cub got out after me. Many planes were stuck there and parked on high ground to avoid the water.
Are Kitfoxes always this much fun!!!??
Ben
47.13 KB |
193 Time(s) |
49.93 KB |
228 Time(s) |
_________________ Sign up on the Kitfox Frappr Map:
http://www.frappr.com/kitfox
You can see where fellow Kitfoxers live and pictures of their planes. Be sure to post some pictures of you, your plane, or share the scenery of the Kitfox world. |
spaghettiohead(at)hotmail Guest
Posted: Wed Jul 05, 2006 11:56 am Post subject: made it! |
What an adventure! Sounds like the stars aligned for you LoL. I remember
cruising down the Susquehanna at 300 feet in an Ultralight ferry-job...even
had to put the plane down in a field and push her into a gas station to
refuel about a mile from the northern bank Best of luck with your
retrofitted 'Fox!
Andrew
| Quote: | From: "Ben Baltrusaitis" <ben(at)gmpexpress.net>
Subject: made it!
Date: Wed, 5 Jul 2006 15:04:47 -0400
terminals.
lake!
fog.
Ben
