riveteddragon(at)gmail.co Guest
Posted: Mon Nov 23, 2015 2:15 pm Post subject: Securing Conduit |
When running conduit through lightening holes (generally much bigger than the conduit diameter), what have people used to secure it? RTV? Make brackets and clamps? Just leave them free to flop?
Steven DeFord
Posted: Mon Nov 23, 2015 2:35 pm Post subject: Securing Conduit |
I would not let them flop. I used 1/2" Sched. 40 (thin wall) PVC pipe
and plastic 'hangars' made to hold the pipe under a ceiling joist ...
picture the pipe clamp with vertical 'ears'. I riveted the pipe hangar
to the side of the larger lightening hole. The plastic clamp has to be
spread out to fit around the PVC pipe .... I tried the ribbed plastic
conduit and just couldn't make it work for me .... all of it ended up in
the recycle bin ..... and the smooth PVC pipe makes running more wires
really easy.
Linn
On 11/23/2015 5:11 PM, Steven DeFord wrote:
Steven DeFord
cooprv7(at)yahoo.com Guest
Posted: Mon Nov 23, 2015 2:36 pm Post subject: Securing Conduit |
I drilled two opposing holes across the lightening hole and used safety wire to trap the conduit in the center. Just did enough ribs to keep it reasonably secure.
Marcus
On Nov 23, 2015, at 5:11 PM, Steven DeFord <riveteddragon(at)gmail.com> wrote:
Steven DeFord
rleffler
If you use the black conduit from Van's, just enlarge the small hole in the rib to 3/4" and th conduit will stay in place just fine. Much easier than attempting to secure it in the lightening holes.
| Quote: | On Nov 23, 2015, at 5:11 PM, Steven DeFord <riveteddragon(at)gmail.com> wrote:
Steven DeFord
_________________ Bob Leffler
N410BL - Phase I
Posted: Mon Nov 23, 2015 4:00 pm Post subject: Securing Conduit |
If you are talking about the lighting holes in the side fuselage, you can
get a rubber grommet that fits it just right - and the ID provides a good
friction fit for the conduit (I got mine from Stein Air
http://www.steinair.com/store.cfm?tlcatid=14 ). For under the rear floor I
make a strap. For new holes, as Bob says make the hole small enough to be a
friction fit for the conduit. Do not make the turns too tight so you can
use a string to run wires.
I ran three conduits on each side and ended up filling five of them.
Carl
109.05 KB |
3831 Time(s) |
132.54 KB |
3831 Time(s) |
jmjones2000(at)mindspring Guest
Posted: Mon Nov 23, 2015 4:18 pm Post subject: Securing Conduit |
I used a small piece of angle riveted to the rib, then used an Adel clamp to clamp the conduit to the angle.
| Quote: | On Nov 23, 2015, at 14:11, Steven DeFord <riveteddragon(at)gmail.com> wrote:
Steven DeFord
rene(at)felker.com Guest
Posted: Mon Nov 23, 2015 4:33 pm Post subject: Securing Conduit |
I think I got this from Vans.
Small hole in the rib and a wire tie to hold the conduit down.
Rene'
801-721-6080
Posted: Mon Nov 23, 2015 8:49 pm Post subject: Securing Conduit |
Try Googling "cable tie bulkhead hole mount"
Specifically it turned up something called a "Panduit LHMS-xnn-xnn". I
used a couple dozen of something very similar to support both conduit
and insulated wire bundles going thru lightening holes. Very handy item
The challenge is finding someone who sells it in small quantities. I
used to use TerminalTown.com but they seem to have closed up shop.
Steven DeFord
glastar(at)gmx.net Guest
Posted: Mon Nov 23, 2015 11:14 pm Post subject: Securing Conduit |
Steve,
I used some clamps mounted either on an L shaped alu angle or on a strip of scrap alu
[img]cid:part1.01050800.05050504(at)gmx.net[/img]
| Quote: | --> RV10-List message posted by: Steven DeFord <riveteddragon(at)gmail.com> (riveteddragon(at)gmail.com)
2.3 MB |
3819 Time(s) |
