Charles Heathco
Posted: Mon Nov 23, 2015 5:17 am Post subject: Flt reveiw/ GW/best glide |
Thanks for all the usefull input to my inquiries. I did well on my FR, and we experimented with glide speeds and found 90 to 100 mph pretty much looked the same, yielding 500/600 FPM. Visually it seemed we were covering a lot of ground as well. Re GW, I will leave it alone based on y'alls input. Now I have to get into my radio problem. I started getting static on way bck to Instructors field and when coming in to Fayettville Drake, it got so bad controler said it was nearly unreadable. Rec is ok tho. Chalie.
This email has been sent from a virus-free computer protected by Avast. www.avast.com
n146wb(at)cfu.net Guest
Posted: Mon Nov 23, 2015 5:31 am Post subject: Flt reveiw/ GW/best glide |
I’ve been having an intermittent problem with transmitting. With mine it’s I either transmit or I don’t, not static. When it isn’t working, mine sort of gives me a soft squeal and the transmit light stays off. So far I’ve checked the PTT switch and it’s ground-ok, w/ 1 ohm resistance. I’ve also tried turning off the intercom, which will route the PTT output directly to the nav/com and bypass the intermcom (to eliminate the intercom as the problem). That isn’t the problem either. I haven’t determined what to do next. Intermittent problems are hard to resolve, but it sounds like yours is not intermittent but a real failure, which should be easier to track down. I would be interested in how you resolve the issue.
Warren
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of cheathco(at)cox.net
Sent: Monday, November 23, 2015 7:16 AM
To: RV-List Digest Server <rv-list(at)matronics.com>
Subject: Flt reveiw/ GW/best glide
[img]cid:~WRD000.jpg[/img]
www.avast.com
823 Bytes |
4301 Time(s) |
