ptt isolation
nodak
PostPosted: Tue Nov 17, 2015 5:36 am    Post subject: ptt isolation Reply with quote
What relays are recommended for pilot copilot ptt isolation on flightline
fl760 transceivers. Thousands of relays are shown on suppliers web sites
making it hard to pick out a suitable one.
Thanks in advance.
Eugene Pilipanko
PostPosted: Tue Nov 17, 2015 4:17 pm    Post subject: Re: ptt isolation Reply with quote
Search Mouser or Digikey for these relay characteristics:
Non-latching, 12VDC nominal coil voltage (13 or 14 OK), SPDT or DPDT, 1 amp contact rating, price less than $5.
A panel mounted switch can be used to disable the copilot PTT. A relay is needed to connect either the pilot or copilot mic. Both mics should not be connected to the radio at the same time.
Joe Gores
ChuckGauthier(at)comcast.
PostPosted: Wed Nov 18, 2015 5:10 am    Post subject: ptt isolation Reply with quote
I had a conversation with the vendor and was told that relays are the only way to have PTT Cutout.
I am putting the FL 760 in my panel and I didn’t want to use relays so I developed a way to avoid using relays and still accomplish the same results.
It requires using DPDT Momentary Push Button Switches for both Pilot and Co-Pilot/Pax. I paid about $20-$25 for each of the switches.
Caveat: Buyer Beware! I have not finished installing it in my panel yet so the circuitry hasn’t been tested and confirmed, however, I took the schematic to an avionics shop for their review and they confirmed that it should work.
I’m attaching the schematics and info on the DPDT switches I used.
Good Luck.
Chuck Gauthier
Cleanex N183SX
(Sonex with a Corvair engine)
Cell:   (360) 901-7934
ChuckGauthier(at)comcast.net (ChuckGauthier(at)comcast.net)
FL760_wiring_with_PTT_-_no_relay_needed.pdf
 Filename:  FL760_wiring_with_PTT_-_no_relay_needed.pdf
 Filesize:  87.04 KB
 Downloaded:  466 Time(s)
DPDT_Momentary_PB,_Staco,_30262-18-C18P_.docx
 Filename:  DPDT_Momentary_PB,_Staco,_30262-18-C18P_.docx
 Filesize:  69.36 KB
 Downloaded:  484 Time(s)
PostPosted: Wed Nov 18, 2015 7:13 am    Post subject: ptt isolation Reply with quote
At 07:36 AM 11/17/2015, you wrote:
--> AeroElectric-List message posted by: "nodak" <epilipanko(at)comcast.net>
Thanks in advance.
Eugene Pilipanko
Joe's advice is solid but I'm curious as to how
these would be used in your system. Can you
share a link to the wiring diagrams that show
the relays?
PostPosted: Wed Nov 18, 2015 12:37 pm    Post subject: ptt isolation Reply with quote
Thanks in advance.Eugene Pilipanko
Gene,
When you say PTT isolation, what functionality
are you seeking? The radio has two microphone
inputs that are simultaneously active. This supports
the intercom functionality.
When you push the pilot's ptt, are you wanting to
quiet the copilot's mic, disable the copilot's
ptt, or both.
When the copilot's ptt is activated, do you want
that source to have priority over the radio . . .
in other words, disable the pilot's ptt, microphone
or both?
Are you intending to use the built in intercom
function?
nodak
PostPosted: Thu Nov 19, 2015 9:17 am    Post subject: Re: ptt isolation Reply with quote
I was wanting to disable the copilots transmit function when the pilots
ptt was activated & disabling the pilots transmit function when the
copilots ptt was activated. What I am trying to accomplish is not have
both mics on when only one ptt is activated. The flightline wiring
diagram lists a isolation relay board which is no longer available.
Thanks for the replies
Eugene Pilipanko
PostPosted: Thu Nov 19, 2015 3:01 pm    Post subject: Re: ptt isolation Reply with quote
Here is a link to a wiring diagram showing how MicroAir uses two relays to connect the mics.
http://tinyurl.com/Microair-PTT
Eugene, are you going to use the intercom function of the radio?
Joe Gores
nodak
PostPosted: Thu Nov 19, 2015 5:53 pm    Post subject: Re: ptt isolation Reply with quote
I was planning on using the intercom feature. I am trying to get some
information on how to wire the unit before I install it. It will be
couple of months before I will do the installation.
Eugene Pilipanko
PostPosted: Fri Nov 20, 2015 5:56 am    Post subject: ptt isolation Reply with quote
Okay, let's talk about it a bit. I'm packing to
go to Wichita today . . . got a garage door
opener to install. We'll pick up this thread
tomorrow.
PostPosted: Fri Nov 20, 2015 5:58 am    Post subject: ptt isolation Reply with quote
I believe Chuck's suggestion earlier this
thread accomplishes a talker-priority access
to the transmitter. You might study that
a bit and see if it's suited to your
planning.
PostPosted: Fri Nov 20, 2015 8:25 am    Post subject: Re: ptt isolation Reply with quote
Attached is a PTT circuit using two DPDT relays. Both mics are normally connected for intercom use. If one pilot presses her PTT switch, the other pilot's mic is disabled. A disadvantage of this circuit is that if both PTT switches are pressed, both mics will be disabled. Of course the pilot will realize this when the side tone goes quiet.
PTT Relays..pdf
 Filename:  PTT Relays..pdf
 Filesize:  16.84 KB
 Downloaded:  424 Time(s)
Joe Gores
wrmaxwell(at)bigpond.com
PostPosted: Fri Nov 20, 2015 12:47 pm    Post subject: ptt isolation Reply with quote
Bt leaves the intercom function to be addressed, methinks...
--> AeroElectric-List message posted by: "nodak" <epilipanko(at)comcast.net> (epilipanko(at)comcast.net)
  planning.
