hgmckay
Posted: Tue Nov 17, 2015 12:34 pm Post subject: Throttle Operation |
I have an Allegro 2000 using a Rotax 912 UL engine with 725 hours operation. I am now finding that while flying the airplane the throttle lever return springs (i.e. the springs that are connected to the throttle lever on the carburetors on the engine is pulling my throttle towards the open position. In other words I have to constantly hold the throttle control in the cockpit to keep it from migrating towards the full open position. I understand why there is a spring on the carbs. It is to pull the carbs to full open position in case of a throttle cable break. But in my case, if I am flying and take my hand off the Allegro cockpit throttle control, the springs on both carbs will pull the throttle further in the open position.
I have never had this problem before. It appears that after 700+ hours of operation there is not enough frictional resistance in the throttle cable sheaths to hold the cable in position, or there is not enough frictional resistance in the mechanical throttle arrangement on the Allegro 2000 to hold a set throttle position. Has any one had this problem with the Allegro 2000, 912 UL engine arrangement? Comments and suggestions would be appreciated.
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Allegro 2000, Rotax 912 UL Engine, 725 hours
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
 Download |
| Filename: |
Hugh.vcf |
79 Bytes |
| Downloaded: |
599 Time(s) |
brad(at)vision-technology Guest
Posted: Tue Nov 17, 2015 12:40 pm Post subject: Throttle Operation |
Hi Hugh,
On the rod that connects the throttle handles to each other there is a nylon bushing (between the seats). The metal cap that holds that bushing down may be loose or the bushing is cracked. (mine is cracked and I haven't searched for a replacement yet, but I was able to get plenty of friction by just tightening the bolts a bit).
Brad Kramer
N221FA - Mandan ND
[quote]--
hgmckay
Posted: Tue Nov 17, 2015 1:06 pm Post subject: Throttle Operation |
Thanks Brad. I will check this bushing to see if that is the problem.
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
From: brad(at)vision-technology.com (brad(at)vision-technology.com)
Sent: Tuesday, November 17, 2015 3:40 PM
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Subject: Re: Throttle Operation
Hi Hugh,
Brad Kramer
N221FA - Mandan ND
[quote]--
Posted: Tue Nov 17, 2015 1:17 pm Post subject: Throttle Operation |
If you happen to find a source / part # let me know. I'd think it is a common part.
thanks
[quote]--
hgmckay
Posted: Tue Nov 17, 2015 3:59 pm Post subject: Throttle Operation |
Will do.
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
Sent: Tuesday, November 17, 2015 4:17 PM
thanks
[quote]--
jkgcpa(at)ix.netcom.com Guest
Posted: Tue Nov 17, 2015 4:37 pm Post subject: Throttle Operation |
Hey Hugh,
Is the part available from Doug at Allegro?
Jerry Goldberg
N44456
Covey Trails (X09)
From: owner-allegro-list-server(at)matronics.com [mailto:owner-allegro-list-server(at)matronics.com] On Behalf Of Hugh McKay
Sent: Tuesday, November 17, 2015 5:59 PM
Will do.
Senior Consultant
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
thanks
doug(at)allegrolsa.com Guest
Posted: Wed Nov 18, 2015 6:30 am Post subject: Throttle Operation |
Jerry, Brad, and Hugh,
Yes we do have the bushing available. However, I do not think it is needed. We have an Allegro at the flight school with over 5,000 hours and ONLY needed to occasionally tighten the friction bolts in the middle of the seats where the throttle rod goes through. We mill these to our specs here at the factory. If needed, they are $25.00 each plus shipping. Again, I do not think anything more than tightening the friction lock is needed. If you have questions, please feel free to call. Also, please feel free to put this on the Allegro list.
Thank you,
Doug
Douglas Hempstead
LSA America, Inc.
231 US Hwy 158 East
Littleton, NC 27850
252-586-1200
www.allegrolsa.com
[quote]-------
