727gs(at)att.net Guest
Posted: Mon Nov 09, 2015 2:11 pm Post subject: Another CJ Question |
The last couple of times I started it, the prop would occasionally kick backwards during the start. Today I noticed a rough idle after start the went away above about 1500 rpm which I attributed to a fouled plug. After the next start it idled smoothly but after the last, it idled roughly again, despite leaning on the ground.Magnetos?Thanks in advance,Steve near Chicago
dantpayne(at)icloud.com Guest
Posted: Mon Nov 09, 2015 2:22 pm Post subject: Another CJ Question |
How bout the primer being left to the full left (manual fuel pump selection)
Or perhaps an internal (primer / wobble pump) leak? Would explain the fuel leaking out of the manifold drain upon shutdown and your excessive rich condition fouling the plug...
PS - if you fouled a plug, that would not make the engine run faster.
On Nov 9, 2015, at 5:08 PM, Stephen Jones <727gs(at)att.net (727gs(at)att.net)> wrote:
| Quote: | The last couple of times I started it, the prop would occasionally kick backwards during the start. Today I noticed a rough idle after start the went away above about 1500 rpm which I attributed to a fouled plug. After the next start it idled smoothly but after the last, it idled roughly again, despite leaning on the ground.
Magnetos?
Thanks in advance,
Steve near Chicago
Posted: Mon Nov 09, 2015 5:17 pm Post subject: Another CJ Question |
The checklist I use has me run the engine to 1900 RPM for 10-15 seconds as lean as it will run, pull back the throttle and mixture to low idle and shut down the mags. Steve near Chicago
To: jblake207(at)comcast.net <jblake207(at)comcast.net>;
Subject: Re: Yak-List: Another CJ Question
Sent: Tue, Nov 10, 2015 12:59:15 AM
On Monday, November 9, 2015 4:46 PM, "jblake207(at)comcast.net" <jblake207(at)comcast.net> wrote:
The rough idle could be from two things... fouled plug as you surmised or these round motors don't run very smooth when cold. My H6 motor will often run a little rough until it gets a little warm and the blower is then distributing fuel/air mixture to cylinders that are symmetrically warm. That's my theory anyway.
From: "Stephen Jones" <727gs(at)att.net>To: "Yak-List" <yak-list(at)matronics.com>Sent: Monday, November 9, 2015 4:08:01 PMSubject: Another CJ Question
Magnetos?
