US 240v to power EU 240v machine?
jonlaury
PostPosted: Sun Oct 18, 2015 10:45 am    Post subject: US 240v to power EU 240v machine? Reply with quote
During the lull in aerolectric posts...
What's the simplest way to use US 240v to power a EU 240v (at) 150w machine. The EU machine uses a single hot leg, neutral and ground through the plug in the picture attached.
 Filesize:  45.62 KB
 Viewed:  16185 Time(s)
yellowduckduo(at)gmail.co
PostPosted: Sun Oct 18, 2015 11:12 am    Post subject: US 240v to power EU 240v machine? Reply with quote
For temporary use I use clothes drier or stove receptacles in houses
that have them.
Either a patch cord or just replace the plug on the existing cord.
Not for unattended use as those receptacles are fused 30 to 50 amps.
Ken
JOHN TIPTON
PostPosted: Sun Oct 18, 2015 11:42 am    Post subject: US 240v to power EU 240v machine? Reply with quote
That's not a EU plug, it's our standard 'ring main' plug here in the UK: the plug as you look at it (upside down) has three pins, the longest (at the bottom of the picture) is the earth, first to go into the socket when inserted and last to leave when removed, the pin on the left is the neutral, and the one on the right (as viewed) is the live and is fitted with a fuse up to 13amps ie: 3000watts (maximum load) divide by 240volts equals 12.5 (13amps)
I presume you have similar 'wires' in USA ie: Live, Neutral and Earth
----x--O--x----
http://forums.matronics.com/viewtopic.php?p=448050#448050
http://forums.matronics.com//files/dsc03159_small_173.jpg
JOHN TIPTON
PostPosted: Sun Oct 18, 2015 12:00 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
And just to make it clear:
Earth lead is: green/yellow
Live lead is: Brown
Neutral lead is: Blue
----x--O--x----
On 18 Oct 2015, at 08:41 pm, John Tipton <jmtipton(at)btopenworld.com> wrote:
----x--O--x----
> Thanks,
> John
ceengland7(at)gmail.com
PostPosted: Sun Oct 18, 2015 12:01 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
On October 18, 2015 2:45:19 PM EDT, jonlaury <jonlaury(at)impulse.net> wrote:[quote] rch , which could kill.
Much safer to use a 120-240volt stepup transformer (pricey).
Sent from my Android device with K-9 Mail. Please excuse my brevity. [quote][b]
Bob McC
PostPosted: Sun Oct 18, 2015 12:10 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
The plug you've pictured is actually "British Standard" not EU, but simply
connect your two North American 240 volt hot lines to the "line" and
"neutral" of the British plug and ground to ground of course and you're good
to go. (Ignore/don't connect, the North American neutral.) As someone else
mentioned if this is a permanent conversion, cut off the British plug,
attach a NEMA 6-15 North American plug http://tinyurl.com/nfrrzrx the
matching receptacle such as this http://tinyurl.com/pags86c , and you're
set.
If you don't wish to modify the existing plug, here's the matching British
receptacle. http://tinyurl.com/qcqqd9p
By the way the British plugs are internally fused (at) 13 Amps so the concern
for connecting to a North American dryer or stove circuit is minimal as long
as you retain the existing plug. (you can actually see the fuse in your
photo)
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
peter(at)sportingaero.com
PostPosted: Sun Oct 18, 2015 12:14 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
Assuming you have a UK extension lead, fit a US 240v plug and hook it
up. I lived in Texas for 5 years and did exactly that with several
appliances - all seemed to work OK. Motors will run 20% faster as US
uses 60Hz and UK/Europe uses 50Hz. When looks at the pins of the plug,
hot is on the left (usually brown wire), earth is at the top (usually
green or yellow/green wire) and neutral on the right (blue wire). The
hot pin is usually protected by a fuse within the plug body.
Peter
PS US motors run in Europe can suffer from overheating.
mmoyle
PostPosted: Sun Oct 18, 2015 12:17 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
http://www.amazon.com/STEP-UP-DOWN-TRANSFORMER-WATT/dp/B002RRPTZU/ref=sr_1_78?srs=2530188011&ie=UTF8&qid=1445199307&sr=8-78
billp(at)wwpc.com
PostPosted: Sun Oct 18, 2015 1:23 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
Ouch! So, in the U.S. on single phase services, the usual arrangement is
120V (L1) -neutral-120V (L2) and a separate protective ground that is
tied to neutral at the load panel. A 240V to 240V isolation transformer
can be used to make the connection you need. On the U.S. side, L1 and L2
are connected to the transformer's primary and on the U.K. side connect
one leg of the transformer to neutral and one leg to 240V hot. Pass the
protective ground through.
If you connect the L1 and L2 of the U.S. system together you will make a
lot of sparks and pop the circuit breaker! L1 and L2 are 2 120V legs
180º out of phase. Don't connect them!
For just a 150W device I think you'll find an "International Step-up
Transformer" is probably the simplest solution. Forget the U.S. 240V
circuit all together. For $35 on Amazon I don't think you can buy all
the connectors and stuff you need to build a solution for that price.
http://www.amazon.com/Dynastar-Converter-Transformer-Lifetime-5-Year-Warranty/dp/B00KAJ8KG2/ref=sr_1_6?ie=UTF8&qid=1445203102&sr=8-6&keywords=international+transformer
set.
photo)
Bob McC
Bob McC
PostPosted: Sun Oct 18, 2015 2:55 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
The original question was for the "simplest" way to operate the UK device on
a North American power system. The "Simplest" way is what I described. No
transformer is required. A 240 volt device is a 240 volt device no matter
which side of the ocean it resides on. In the UK (or Europe) 240 volt single
phase devices are connected between a "hot" line and a "neutral" (grounded)
line. In North America that same 240 volt single phase device would be
connected between the two live line connections (L1, L2, as you've
described) and not connected to the "neutral" (grounded) connection. In
either case the actual "ground" (earth) connection would be made as usual.
My original description in no way suggested connecting together the two
"line" connections creating a direct short as you seem to have interpreted.
Maybe I should have said "Connect your two North American 240 volt hot lines
to the "line" and
"neutral" RESPECTIVLY of the British plug and ground to ground of course and
you're good
to go" to make it clearer.
If that British supply cord were cut open you would find a Brown conductor
which you would connect to L1 of the North American system, a blue conductor
which you would connect to L2, and a green/yellow striped conductor which
you would connect to ground. (green or bare in the American system).
The transformer connections you describe are correct and would work, but the
transformer is not necessary. Simply connect directly to the 240 lines plus
ground.
The only slight difference, as someone else pointed out, is frequency, which
in North America is 60 Hertz and most of the rest of the planet 50 hertz.
This will make a difference in the speed of motors which will be faster on
60 and slower on 50. Also depending on the iron content 60 cycle motors may
tend to overheat on 50 cycle.
Respectfully
Bob McC
[quote] --
Bob McC
Falco #908
(just starting)
paul.r.kuntz(at)gmail.com
PostPosted: Sun Oct 18, 2015 5:16 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
Bob McC is correct. I was on assignment to the UK for a few years, and
took a 240V US power tool with me to the UK, then brought a couple of 240V
UK power tools back with me when the assignment ended. The only thing I
had to do at each end of the assignment was cut off the plugs and replace
them. There are also plug adapters available from many sources if you
don't want to replace the plugs. As Bob notes, since they were powered by
synchronous AC motors, they ran faster on 60 Hz US power than they did on
50 Hz electric power. That's almost never a problem, unless the
application is dependent on the motor speed, such as an electric clock.
Paul Kuntz
On Sun, Oct 18, 2015 at 3:53 PM, Bob McCallum <robert.mccallum2(at)sympatico.ca
wrote:
robert.mccallum2(at)sympatico.ca>
on
single
jonlaury
PostPosted: Mon Oct 19, 2015 8:05 am    Post subject: Re: US 240v to power EU 240v machine? Reply with quote
WOW!
From the response to my rather pedestrian dilemma, and with no competing posts, it sounds like there's a bunch of Aerolectric List junkies needing a fix ! Very Happy
Big THANKS! to all.
PostPosted: Mon Oct 19, 2015 12:06 pm    Post subject: US 240v to power EU 240v machine? Reply with quote
> Also depending on the iron content 60 cycle motors may tend to
That's interesting, I bought a large 240v compressor when I lived in the
US. Now trying to run it in the UK it keeps overheating and popping the
thermal cut-out. I guess a new motor is on the cards...
Peter
to the "line" and
you're good
ground.
Respectfully
Bob McC
Bob McC
PostPosted: Tue Oct 20, 2015 5:03 am    Post subject: US 240v to power EU 240v machine? Reply with quote
The higher the frequency the less iron is needed. This is one of the reasons that aircraft AC systems are generally 400 cycle. Due to the lower iron requirement, all else being equal they're lighter. In today's modern efforts for "cheap" construction, the iron content is likely to be the bare minimum. "Old" motors on the other hand may have way more than adequate iron content and may work just fine on the lower European frequency.
Bob McC
[quote] Subject: Re: US 240v to power EU 240v machine?
Date: Mon, 19 Oct 2015 21:04:55 +0100
--> AeroElectric-List message posted by: Peter Pengilly <peter(at)sportingaero.com>
Peter
> --> AeroElectric-List message posted by: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
> to the "line" and
> you're good
> ground.
> Respectfully
> Bob McC
Bob McC
Falco #908
(just starting)
CallumMcLeish
PostPosted: Wed Jul 19, 2023 7:07 am    Post subject: Re: US 240v to power EU 240v machine? Reply with quote
If you need to power a European 240V machine in the US, it is crucial to ensure a safe and efficient voltage conversion. While both regions operate on 240V systems, they utilize different electrical standards, requiring appropriate adjustments. To address this, one can utilize a voltage converter or transformer designed to convert the US 240V to match the EU 240V power requirements. These devices enable seamless compatibility and safeguard the machine from potential damage. For the best industrial machines, one can explore an extensive range of options available at www.haiweimachinery.com/product-category/coil-fed-laser-cutting-machine/ — a reliable source offering top-notch equipment to meet diverse industrial needs.
