shoraiLfxInstallGuide
ward.t(at)xtra.co.nz
PostPosted: Wed Oct 14, 2015 7:57 pm    Post subject: shoraiLfxInstallGuide Reply with quote
Karl,
See attachment.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
shoraiLfxInstallGuide.pdf
 Filename:  shoraiLfxInstallGuide.pdf
 Filesize:  244.73 KB
 Downloaded:  301 Time(s)
kheindl(at)msn.com
PostPosted: Thu Oct 15, 2015 2:15 am    Post subject: shoraiLfxInstallGuide Reply with quote
Tim,
Thank you for the installation guide, but you still did not tell us which battery model you installed.
This only refers to the LFX09A2.
Karl
Subject: Europa-List: shoraiLfxInstallGuide
Date: Thu, 15 Oct 2015 16:56:22 +1300
Karl,See attachment.Tim
Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz Ph 64 3 3515166 Mob 0210640221 [quote]
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
PostPosted: Thu Oct 15, 2015 5:34 pm    Post subject: shoraiLfxInstallGuide Reply with quote
Karl,
That's the one.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 15/10/2015, at 6:14 PM, Karl Heindl <kheindl(at)msn.com (kheindl(at)msn.com)> wrote:
[quote] Tim,
Karl
Subject: shoraiLfxInstallGuide
Tim Ward 12 Waiwetu Street Fendalton, Christchurch, 8052 New Zealand. ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz) Ph 64 3 3515166 Mob 0210640221
kheindl(at)msn.com
PostPosted: Fri Oct 16, 2015 1:13 am    Post subject: shoraiLfxInstallGuide Reply with quote
Many thanks.
Subject: Re: shoraiLfxInstallGuide
Date: Fri, 16 Oct 2015 09:33:01 +0800
Karl,
That's the one.
Fendalton,
Christchurch,  8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
[quote] Tim,
Karl
vigator?Europa-List"" target="_blank">http://www.matronics.com/Navigator?Europa-List
"" target="_blank">http://forums.matronics.com
ntribution"" target="_blank">http://www.matronics.com/contribution
h&jeuropa
PostPosted: Fri Oct 16, 2015 3:34 am    Post subject: Re: shoraiLfxInstallGuide Reply with quote
Karl,
We chose an EarthX LiFePo4 because it has a built in battery management system. Our article is in the Europa Flyer Issue 82. We bought the ETX36C which is very small but works great!
Installed for over a year, it outperforms our old Panasonic battery.
Jim & Heather
N241BW
