Engine heat
drc(at)wscare.com
PostPosted: Mon Oct 12, 2015 4:47 pm    Post subject: Engine heat Reply with quote
I use E-Z heat pads.  one on oil tank, one on nose case and one on the case.  Made in Chetek.  Nice guys. http://e-zheat.com/store/
All route to a singe 110 plug.  of course I leave the hanger to heat to about 40 in winter so it never drops below zero in the hanger.
THere is oil in the cooler and I have heard anecdotes of warm engie oil and very cold oil in the lines and cooler.  When cranked the preassure rises in the cooler or lines and may lead to cracks.
Dr. Herbert Coussons
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[img]cid:0AEC9E78-9DFD-4F58-A5BE-DA155CD5EC8A[/img]
Green Bay â€¢ Appleton â€¢ Marinette
womens-specialtycare.com
This message is being sent by Dr Herbert Coussons, MD. It is intended exclusively for the individuals and entities to which it is addressed. This communication, including any attachments, may contain information that is proprietary, privileged, confidential, including information that is protected under the HIPAA privacy rules, or otherwise legally exempt from disclosure. If you are not the named addressee, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this message in error, please notify the sender immediately by email and delete all copies of this message. This message is protected by applicable legal privileges and is confidential.
 Filesize:  25.01 KB
 Viewed:  4662 Time(s)
jlpartington(at)reagan.co
PostPosted: Mon Oct 12, 2015 7:09 pm    Post subject: Engine heat Reply with quote
could just move South
 Filesize:  25.01 KB
 Viewed:  4661 Time(s)
KingCJ6(at)aol.com
PostPosted: Mon Oct 12, 2015 7:19 pm    Post subject: Engine heat Reply with quote
Not to worry, Global Warming should soon remedy the situation...
D
In a message dated 10/12/2015 8:09:55 P.M. Pacific Daylight Time, jlpartington(at)reagan.com writes:
-----Original Message-----
Sent: Monday, 12 October, 2015 7:43pm
To: "Rico Jager" <rijaeger(at)wausau.k12.wi.us>, "<yak-list(at)matronics.com>" <yak-list(at)matronics.com>
Subject: Engine heat
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[img]cid:(at)0AEC9E78-9DFD-4F58-A5BE-DA155CD5EC8A[/img]
Green Bay • Appleton • Marinette
 Filesize:  25.01 KB
drc(at)wscare.com
PostPosted: Tue Oct 13, 2015 3:45 am    Post subject: Engine heat Reply with quote
Been there - lived in Louisiana and Texas for about 30 years. Daughter lives in Florida.
Was in Washington State and Idaho for 7 years
Now in Green Bay for 13 years
I prefer the other advantages of the North (much less than 47% dependency rate)
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[quote] On Oct 12, 2015, at 10:05 PM, jlpartington(at)reagan.com (jlpartington(at)reagan.com) wrote:
 Filesize:  25.01 KB
 Viewed:  4652 Time(s)
PostPosted: Tue Oct 13, 2015 3:58 am    Post subject: Engine heat Reply with quote
She needs a visit for the winter, with his CJ/Yak
 Filesize:  25.01 KB
dsavarese0812(at)bellsout
PostPosted: Tue Oct 13, 2015 4:13 am    Post subject: Engine heat Reply with quote
