AcroGimp
Joined: 11 Jun 2013 Posts: 45 Location: San Diego, CA USA
cpayne(at)joimail.com Guest
Posted: Sun Sep 27, 2015 7:35 am Post subject: Spinner Question |
Mounting the back plate is a slow and agonizing process, there is no way around it, only different recovery techniques. An easy chair and cold beer is often the reward after each nut is put on. Did I mention that it was a slow process?
I use safety wire around each nut to position and start with a long handled screw driver and a deft touch . Also a simple wrench made of .063" 0r .090" aluminum, backed by a thin strip on the back can snug each nut. Final tightening will be by a steel open-end, ground down to fit.
Removing the 2-piece back plate is not something to do often. Mounting the first half is not so bad as the second half plate.
Craig Payne
pilotdog57(at)aol.com Guest
Posted: Sun Sep 27, 2015 9:28 am Post subject: Spinner Question |
Sounds to me like the best and most reasonable approach to an unreasonable task!
The thin aluminum wrench is a great idea- I once used a bicycle cone wrench similarly.
Doug Z
| Quote: | On Sep 27, 2015, at 8:31 AM, Cpayne <cpayne(at)joimail.com> wrote:
Craig Payne
AcroGimp
AcroGimp
Posted: Tue Sep 29, 2015 6:36 am Post subject: Re: Spinner Question |
| cpayne(at)joimail.com wrote: | Mounting the back plate is a slow and agonizing process, there is no way around it, only different recovery techniques. An easy chair and cold beer is often the reward after each nut is put on. Did I mention that it was a slow process?
Craig Payne | Craig, can you explain a little more about your safetywire technique?
I pulled the prop forward on the hub a little to provide more room for the lockwashers and nuts (keeping the 3 nuts on the other side secure but with room to move the prop around).
I am imagining a couple loops around the nut to allow you to maneuver it into position, and then trying to start it with the tip of a screwdriver?
Spent 1.5 hrs yesterday and could not get even one started, very frustrating.
'Gimp
_________________ Owner/Pilot N6209F 1987 Yak-52
COMM/ASEL/IFR/HP-Complex/TW |
aerostar6
Posted: Sat Oct 03, 2015 1:52 am Post subject: Re: Spinner Question |
Hey John.
I have done this process 4 times in the last 6 months when my overhauled engine had to be removed for the second time.
My mechanic came up with a perfect solution. Take a long, stiff strip of metal, around 9" long (an old hacksaw blade is perfect) and weld onto the end a stud made up of a bolt end the same size as the prop stud, with maybe three full threads remaining.
Now spin on your nut and you should have enough room to offer the whole assembly up to the prop stud. Then carefully nudge the nut off your 'tool' and onto the stud.
You will probably fail to engage the thread and drop the nut one time in three, but this method should see success in a much shorter time than any other I have used.
Sorry I don't have a pic, but am not back at the airfield for a few days.
Hope to see your new spinner on at Gillespie when I am next in town later this month!
AcroGimp
Posted: Mon Oct 05, 2015 9:55 am Post subject: Re: Spinner Question |
| aerostar6 wrote: | Hey John.
Hope to see your new spinner on at Gillespie when I am next in town later this month! | Brilliant solution Mark, we got it on and it all balanced out to 0.05 IPS, smooth like butter, getting it all put back together with new cockpit, landing/taxi and nav/pos/strobe LED's, should test fly later this week.
See in a few weeks.
'Gimp
1.62 MB |
14768 Time(s) |
ronpenrose
Joined: 16 Jul 2014 Posts: 15 Location: Kansas City Metro (KLXT)
Posted: Fri Oct 23, 2015 9:02 am Post subject: Re: Spinner Question |
I just finished installing a Whirlwind spinner and this is the tool I finally made that helped immensely - similar to Mark's post. Dennis Savarese suggested this to me and it worked great. Of course I did drop the nut several times before getting to thread.
_________________ Ron Penrose
YAK-52 N352BW |
ronpenrose
Posted: Fri Oct 23, 2015 9:17 am Post subject: Re: Spinner Question |
The image did not post because too big. Here it is now.
180.08 KB |
14670 Time(s) |
YAK-52 N352BW |
