Yak 55M - Airspeeds for safe opening of canopy
heaysr(at)telus.net
PostPosted: Mon Sep 28, 2015 6:21 pm    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
For the Yak 55M, does anyone have the airspeed below which it is safe to open the canopy without damaging it?
There are two canopy open positions. One around 6 inches open and another fully open for entry and egress to/from the cockpit.
Perhaps there are two airspeeds, one for 6” open and another for fully open?
Does anyone have experience with flying canopy open that they are prepared to share? Comments welcome on cockpit air turbulence, through cockpit airflow and pressure. Did your maps get sucked out, for example?
Royden Heays,
Vancouver, Canada
drc(at)wscare.com
PostPosted: Tue Sep 29, 2015 5:54 am    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
I owned a 55 for several years.  I do not believe there is an airspeed restriction for the canopy.  I have flown at normal cruise speeds with the canopy open and for sure with it at the first notch.  I like the design in many ways as oppoed to the sukhoi design and I also like the vent at the top center - it allows great ventilation without the noise of the open cockpit.  The airflow is not bad with cockpit open - but of course the noise increases which can interfere with transmission on the radio.   Cn’t answer the question about maps etc.  I fly mostly local flight or small handheld GPS.
Fun airplane - alot of airplane for the money.  Have fun and fly safe.
Herb
Dr. Herbert Coussons
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[img]cid:0AEC9E78-9DFD-4F58-A5BE-DA155CD5EC8A[/img]
Green Bay â€˘ Appleton â€˘ Marinette
womens-specialtycare.com
This message is being sent by Dr Herbert Coussons, MD. It is intended exclusively for the individuals and entities to which it is addressed. This communication, including any attachments, may contain information that is proprietary, privileged, confidential, including information that is protected under the HIPAA privacy rules, or otherwise legally exempt from disclosure. If you are not the named addressee, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this message in error, please notify the sender immediately by email and delete all copies of this message. This message is protected by applicable legal privileges and is confidential.
[quote] On Sep 28, 2015, at 9:17 PM, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:
Royden Heays,
Vancouver, Canada
 Filesize:  25.01 KB
 Viewed:  7314 Time(s)
javiercarrascob
PostPosted: Tue Sep 29, 2015 10:34 am    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
I think I recall that open canopy had no restrictions in the original manual.
I do open canopy always when doing formation flight and have done lots of acro with the canopy opened, all of my takeoffs and crack opened for landing
heaysr(at)telus.net
PostPosted: Thu Oct 08, 2015 12:23 pm    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
Many thanks to Tiger Airshows, Dr Herb Coussons and Javier Carrasco for their in depth responses to my questions about open cockpit flying in a Yak 55.
Tried it for the first time last weekend  – what a great new experience!
Royden Heays
Vancouver, BC
Canada
Viperdoc
PostPosted: Thu Oct 08, 2015 7:57 pm    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
Remember to keep your shoulder harness hooked up. 😉
Doc
[quote] On Oct 7, 2015, at 11:30 PM, Royden Heays <heaysr(at)telus.net> wrote:
Viperdoc
sailor2645(at)aol.com
PostPosted: Fri Oct 09, 2015 4:28 am    Post subject: Yak 55M - Airspeeds for safe opening of canopy Reply with quote
Royden,
I am unable to find those airspeeds in the archives. Could you share them with me.
Dan Caldwell
On Oct 8, 2015, at 11:53 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
[quote]Remember to keep your shoulder harness hooked up. 😉
Doc
On Oct 7, 2015, at 11:30 PM, Royden Heays <heaysr(at)telus.net (heaysr(at)telus.net)> wrote:
<![endif]--> <![endif]-->
Royden Heays
Vancouver, BC
Canada
ist"">http://www.matronics.com/Navigator?Yak-List
//forums.matronics.com
