Rudder Pedal Extensions
carl.froehlich(at)verizon
PostPosted: Mon Sep 07, 2015 2:28 pm    Post subject: Rudder Pedal Extensions Reply with quote
All,
My son and son-in-law are both Naval Aviators. As is easy to do, both have a tendency to drag the brakes. A good friend of mine, Tom Doran, made these extension on his milling machine from 1” Delron. He even made me one out of steel for me to use as a drilling gig. I used a couple of hose clamps to attached the gig and drill the #19 holes.
While I did this to help the son and son-in-law I confess I found them to be much better than just the stock set up.
Carl
 Filesize:  63.36 KB
 Viewed:  6473 Time(s)
 Filesize:  142.42 KB
Plummit
PostPosted: Tue Sep 15, 2015 8:22 am    Post subject: Re: Rudder Pedal Extensions Reply with quote
Any chance he'll make another set for me? I need something to help me stay off the brakes when taxiing.
regards
~Marc
PostPosted: Tue Sep 15, 2015 8:40 am    Post subject: Rudder Pedal Extensions Reply with quote
I suspect he will. I'll forward your note to him.
Carl
dmaib@me.com
PostPosted: Tue Sep 15, 2015 9:44 am    Post subject: Rudder Pedal Extensions Reply with quote
mlskunkworks sells these. I put them on my RV-10 and they are great. I have flown RV’s without them and am very glad I have them.
David Maib
40559
On Sep 15, 2015, at 12:22 PM, Plummit <marcwhis(at)gmail.com (marcwhis(at)gmail.com)> wrote:
--> RV10-List message posted by: "Plummit" <marcwhis(at)gmail.com (marcwhis(at)gmail.com)>Any chance he'll make another set for me? I need something to help me stay off the brakes when taxiing.regards~MarcRead this topic online here:http://forums.matronics.com/viewtopic.php?p=447086#447086
David Maib
dmaib(at)me.com (dmaib(at)me.com)
[img]cid:C506A6D9-552A-42EF-98F5-5A5F1D2C74BC[/img]
 Filesize:  23.27 KB
 Viewed:  6408 Time(s)
David Maib
RV-10 #40559
New Smyrna Beach, FL
n223rv(at)wolflakeairport
PostPosted: Wed Sep 16, 2015 3:50 am    Post subject: Rudder Pedal Extensions Reply with quote
bill.peyton
PostPosted: Fri Sep 18, 2015 4:27 am    Post subject: Re: Rudder Pedal Extensions Reply with quote
Here is what I purchased
http://www.jdair.com/rudder-pedal-extensions-for-vans-rv-aircraft-rv-4-rv-6-rv-7-rv-9-rv-10/
WA0SYV
Aviation Partners, LLC
