Aileron Gap Seals
Mark K
PostPosted: Mon Aug 31, 2015 8:32 am    Post subject: Aileron Gap Seals Reply with quote
Starting to plan ahead for sealing the aileron gaps and was hoping a few of my fellow Kolbers might be able and willing to share some photos of gap sealing methods. Preferably ones that work the best for them.
Mark
Twinstar MKII
Great Bend, PA
Rex Rodebush
PostPosted: Mon Aug 31, 2015 9:03 am    Post subject: Re: Aileron Gap Seals Reply with quote
Use the search engine and find a post by Ray Baker in December of 2000. It gives a detailed procedure that I found works well. You'll need a buddy to help. Its almost impossible for one person to work with the sticky tape and do a nice job. (for me anyway)
Herbgh(at)nctc.com
PostPosted: Mon Aug 31, 2015 9:15 am    Post subject: Aileron Gap Seals Reply with quote
book binding tape ....works well and can be done by one person...though
two work better... think I am on a book binding tape trip this
morning..Herb
http://forums.matronics.com/viewtopic.php?p=446621#446621
Signature text; This the byline area?
mojavjoe
PostPosted: Mon Aug 31, 2015 12:24 pm    Post subject: Aileron Gap Seals Reply with quote
On my firestar I use piano hinge (in two pieces side by side) the length of the aileron.
mojavjoe
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Monday, August 31, 2015 12:32:17 PM
Subject: Aileron Gap Seals
--> Kolb-List message posted by: "Shadow94" <seanote(at)echoes.net>
Mark
Twinstar MKII
Great Bend, PA
http://forums.matronics.com/viewtopic.php?p=446620#446620
bsp; -================
PostPosted: Tue Sep 01, 2015 12:59 pm    Post subject: Aileron Gap Seals Reply with quote
The best method for durability is the same procedure
outlined in old Kolb Aircraft instruction manuals. Tape is
temporary.
I have an aileron gap seal that is 23 years old and 3,300.0+
hours. Another that is 15 years old and I don't know how
many hours on that one. Both are showing some age, but
still serviceable.
This system is more work intensive than tape, but looks and
performs the best, in my humble opinion.
Omak, WA
Richard Pike
PostPosted: Tue Sep 01, 2015 2:12 pm    Post subject: Re: Aileron Gap Seals Reply with quote
What John said. Here is what Stits fabric gap seals look like after 20 years. The area within the prop arc is starting to crack on one aileron, will be a simple repair. This winter. Not a priority. Everything else is still OK.
 Filesize:  37.14 KB
 Viewed:  20926 Time(s)
 Filesize:  36.94 KB
 Filesize:  38.87 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Mark K
PostPosted: Thu Sep 03, 2015 8:48 am    Post subject: Re: Aileron Gap Seals Reply with quote
Richard,
Thanks for the photos. I appears that the gap seals are attached to the bottom of both the wing and the aileron with a bit of slack to account for aileron movement.
I assume the are constructed out of the same covering as the wing and aileron.
thanks again for the input.
Mark
Twinstar MKII
Great Bend, PA
PostPosted: Thu Sep 03, 2015 10:08 am    Post subject: Aileron Gap Seals Reply with quote
Realize the post was addressed to Richard only. Hope it
will be permissible to share a response.
Unless I am badly mistaken, 3" finishing tape is used for
the gap seals.
The original Kolb Aircraft construction manuals have some
very good information (tricks of the trade) for installing
and finishing gap seals.
I'm not at home or I would attach those instructions to this
post.
Wenatchee, WA
Mark K
PostPosted: Fri Sep 04, 2015 3:04 am    Post subject: Re: Aileron Gap Seals Reply with quote
John, no permission needed great input and help is always welcome. I will review my build manual and details but when you are able if you would forward your info that would be much appreciated.
I can't wait to post some progress photos.
Mark
Twinstar MKII
Great Bend, PA
PostPosted: Fri Sep 04, 2015 7:21 am    Post subject: Aileron Gap Seals Reply with quote
Remind me when I get home next month.
Wenatchee, WA
Richard Pike
PostPosted: Sat Sep 05, 2015 7:50 am    Post subject: Re: Aileron Gap Seals Reply with quote
John; your memory serves you well. It was in the Firestar book, and since we still have 10 minutes before dove season opens, I went ahead and scanned it and saved you the trouble.
 Filesize:  107.75 KB
 Viewed:  20834 Time(s)
 Filesize:  108.32 KB
Richard Pike
Kingsport, TN 3TN0
crankpot
PostPosted: Thu Sep 17, 2015 11:03 am    Post subject: Re: Aileron Gap Seals Reply with quote
I've used book binding tape on both my firestar and now the ultrastar. Yes, its temporary but so am I. It lasts a good long time and looks way better than the stits tape IMHO
1984 kolb ultrstar
Former 1997 kolb firestat
herbgh(at)nctc.com
PostPosted: Thu Sep 17, 2015 11:49 am    Post subject: Aileron Gap Seals Reply with quote
That is the way I will proceed...I am done with the Firefly save for the
aileron gap seals.. Office depot sold me a roll back when...
I did the stits proceedure with the MkIII but someone at Kolb or on
this list sold me on the tape..
May have said this before...but need a three blade IVO prop...UL
version...Have a three blade Mid range IVO to trade... Blades for
blades...I do not have the quick adjust hub...but I make my own...very
simple with a lathe...Herb
Pics of the finished Firefly...as one can see..the Puppies are real
excited about it...! Smile
1984 kolb ultrstar
http://forums.matronics.com/viewtopic.php?p=447166#447166
 Filesize:  1.8 MB
 Viewed:  20757 Time(s)
Dennis Kirby
PostPosted: Fri Sep 18, 2015 5:55 am    Post subject: Aileron Gap Seals Reply with quote
"crankpot" wrote: << I've used book binding tape on both my firestar and now the ultrastar. Yes, its temporary but so am I. It lasts a good long time and looks way better than the
stits tape IMHO. >>
All -
Crankpot is right - the clear 3M book binding tape lasts about six years. Then it starts cracking and breaking off. When this happened to me, I replaced the gap seal tape with dacron sail repair tape. Now I have the best of both methods!
The sail repair tape comes in a 2-inch wide roll, just like the clear 3M book tape. Comes in various colors. I used white. And it's very sticky. You install it exactly as you would the clear tape, with the same sticky-side-to-sticky-side overlap of a half-inch. But now you have the benefit of a dacron fabric gap seal, which is stronger and should last a bunch longer than the clear tape.
Looks good, too.
Dennis Kirby
Mark-3c / 912ul
Sandia Park, NM
williamtsullivan(at)att.n
PostPosted: Fri Sep 18, 2015 6:19 am    Post subject: Aileron Gap Seals Reply with quote
Dennis- Where do you find sail repair tape?
Bill Sullivan
On Fri, 9/18/15, KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS <dennis.kirby.3(at)us.af.mil> wrote:
Subject: Re: Aileron Gap Seals
To: "kolb-list(at)matronics.com" <kolb-list(at)matronics.com>
Date: Friday, September 18, 2015, 9:54 AM
"KIRBY, DENNIS T GS-13 USAF AFMC AFNWC/EZS" <dennis.kirby.3(at)us.af.mil>
way better than the
stits tape IMHO. >>
All -
of both methods!
tape.
Looks good, too.
Dennis Kirby
Mark-3c / 912ul
Sandia Park, NM
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
