Tiger Lift
Discover
PostPosted: Fri Aug 28, 2015 11:39 am    Post subject: Tiger Lift Reply with quote
I'm not sure if the honeycomb floor is really designed to support the entire weight of a Tiger. If it is then I think I'd like to get a lift table. I found this lift that has a high enough weight rating for 4 placers and wondered what you guru's might think about it? And about whether it's ok to use it?
Seems like a lift table would make wheel work easy....
http://www.boltontool.com/hydraulic/Lift-Tables/Cart-Style-Lift-Truck/TF100D
Less expensive version:
http://www.boltontool.com/TF100
Ned
dvonruden(at)generalequip
PostPosted: Fri Aug 28, 2015 1:32 pm    Post subject: Tiger Lift Reply with quote
We use a similar table design in our Assembly Department. From my perspective, they lack the quality and inherent stability necessary even if the honeycomb floor is capable of properly sustaining the weight.
Dennis Von Ruden
[img]cid:GECLSig.jpg[/img]
Dennis Von Ruden President p 800.533.0524 | 507.451.5510 620 Alexander Drive S.W. Owatonna, Minnesota 55060 www.generalequip.com
 [img]cid:facebook.png[/img] [img]cid:youtube.png[/img] [img]cid:linkedin.png[/img] [img]cid:twitter.png[/img] [img]cid:blogger.png[/img]    Manufacturers of Light Construction Equipment
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of 923te(at)att.net
Sent: Friday, August 28, 2015 2:39 PM
To: Team Grumman <teamgrumman-list(at)matronics.com>
Subject: TeamGrumman-List: Tiger Lift
Ned
  _-============================================================_-=          - The TeamGrumman-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-=   --> http://www.matronics.com/Navigator?TeamGrumman-List
 Filesize:  29.35 KB
 Viewed:  6771 Time(s)
 Filesize:  1.69 KB
 Filesize:  1.84 KB
 Filesize:  1.77 KB
 Filesize:  1.72 KB
 Filesize:  1.72 KB
BARRY CHECK 6
PostPosted: Fri Aug 28, 2015 1:42 pm    Post subject: Tiger Lift Reply with quote
Ned,
The lift point is at the firewall port to starboard.
Use a simple floor jack, a 4x4 x width of plane and a couple of cinder blocks.
I don't think the lift table will work because of:
Bolts on the belly and
Possible Antennas
The lift point is also determined with the wheels on the ground.  The wheels support much of the weight because they are vey close to the CG.
Barry
Ned
st" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
tp://forums.matronics.com
Sent from Gmail Mobile
allenc3(at)bellsouth.net
PostPosted: Fri Aug 28, 2015 3:27 pm    Post subject: Tiger Lift Reply with quote
I like that. My problem is I might put the tail threw the rafters in my hanger.
Claude from my iPhone 6 plus
On Aug 28, 2015, at 15:38, 923te(at)att.net (923te(at)att.net) wrote:
[quote]I'm not sure if the honeycomb floor is really designed to support the entire weight of a Tiger. If it is then I think I'd like to get a lift table. I found this lift that has a high enough weight rating for 4 placers and wondered what you guru's might think about it? And about whether it's ok to use it?
Ned
rumman-List"">http://www.matronics.com/Navigator?TeamGrumman-List
