altman51
Posted: Fri Aug 14, 2015 3:44 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
I recently started the engine on my CJ6 intending to fly but noticed that the oil pressure had dropped to zero. The engine was shut down and the aircraft secured. 6 days later my mx guy (Jason Berman) and I (Jason mostly) explored the problem. We determine that the oil pump was putting out pressure but the oil was not getting out of the reservoir. Oil was returning but not getting out.
Long story short we found after drawing all the oil out that a plastic oil cap from a quart oil container had somehow gotten into the reservoir and made its way to the oil outlet and blocked it. It had probably been there for along time and just happened to make its way to block the oil outlet. We had to remove the oil reservoir in order to extract the oil cap. I would guess that most people when they change the oil do not inspect the inside of the reservoir. It would probably be a good idea to start doing such an inspection.
Ernie
Posted: Fri Aug 14, 2015 3:56 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
This is not the first time I've heard of this. Search the archives, I'm sure you'll find several examples.
Hope no damage was done.
Ernie
On Friday, August 14, 2015, altman51 <waltman51(at)comcast.net (waltman51(at)comcast.net)> wrote:
[quote]--> Yak-List message posted by: "altman51" <[url=javascript:;]waltman51(at)comcast.net[/url]>
http://forums.matronics.com/viewtopic.php?p=445943#445943
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
kingcj6(at)aol.com Guest
Posted: Fri Aug 14, 2015 4:22 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
A plastic magnet usually helps.
byronmfox(at)gmail.com Guest
Posted: Fri Aug 14, 2015 4:27 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
I so distrust myself that I remove the cap from a quart of oil and drop it on the ground before even nearing the airplane. Murphy and I are well acquainted.
Blitz Fox415-307-2405
On Aug 14, 2015, at 4:53 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]This is not the first time I've heard of this. Search the archives, I'm sure you'll find several examples.
Ernie
| Quote: | --> Yak-List message posted by: "altman51" <[url=javascript:;]waltman51(at)comcast.net[/url]>
ist"">http://www.matronics.com/Navigator?Yak-List
Viperdoc
Posted: Fri Aug 14, 2015 7:47 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
Another idea. Take the cap off of you oil bottle and leave the cap on the wing root while you are pouring the oil in the tank.
Doc
| Quote: | On Aug 14, 2015, at 6:44 PM, altman51 <waltman51(at)comcast.net> wrote:
_________________ Viperdoc |
Viperdoc
Posted: Fri Aug 14, 2015 7:48 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
Yep. Know the gentleman quite well.
Doc
On Aug 14, 2015, at 7:23 PM, Byron Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
[quote]I so distrust myself that I remove the cap from a quart of oil and drop it on the ground before even nearing the airplane. Murphy and I are well acquainted.
| Quote: | This is not the first time I've heard of this. Search the archives, I'm sure you'll find several examples.
Ernie
draftsjust417(at)gmail.co Guest
Posted: Fri Aug 14, 2015 8:09 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
Great idea on reservoir inspection, I'll add that to my annual insp list, thanks-
Justin Drafts
N280NC
On Fri, Aug 14, 2015 at 3:44 PM, altman51 <waltman51(at)comcast.net (waltman51(at)comcast.net)> wrote:
[quote]--> Yak-List message posted by: "altman51" <waltman51(at)comcast.net (waltman51(at)comcast.net)>
List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Yak-List
_blank" rel="noreferrer">http://forums.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
richard.goode(at)russiana Guest
Posted: Fri Aug 14, 2015 9:36 pm Post subject: Foreign Object in CJ6 Oil Reservoir |
We had a customer with oil pressure problems in a Yak 18T, and after some
investigation found no less than 17 oil caps or their retaining rings in the
oil tank!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is
+94 779 132 160.
Posted: Sat Aug 15, 2015 2:30 am Post subject: Foreign Object in CJ6 Oil Reservoir |
That's incredible!
Keeping a pair of long, mechanical fingers in your tool box for that "just in case" situation helps in removing the caps and rings instead of the possibility of having to remove the oil tank. How do I know this works? Anyone want to guess? ) http://www.lowes.com/pd_79041-56005-70396_1z0x3hu__?productId=3139045&pl=1
Dennis
From: Richard Goode <richard.goode(at)russianaeros.com>
To: yak-list(at)matronics.com
Sent: Saturday, August 15, 2015 12:32 AM
Subject: RE: Yak-List: Foreign Object in CJ6 Oil Reservoir
--> Yak-List message posted by: "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
oil tank!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
+94 779 132 160.
altman51
Etienne Verhellen
Posted: Sat Aug 15, 2015 6:11 am Post subject: Mistakes while flying Yaks (Yak-52 and Yak-50) ... |
Have been there ... done that ...
Think I have done most mistakes one can do when flying Yaks !
But I 'm sure there is still room for 'improvement' !
Was hoping to get there today with a friend's Yak-52 :
http://flyin.dac.be/
But the weather is not playing ball today (
It's raining cats and dogs here !
Have a great WE.
1014.33 KB |
13424 Time(s) |
2.74 MB |
13424 Time(s) |
2.55 MB |
13424 Time(s) |
2.51 MB |
13424 Time(s) |
199.77 KB |
13424 Time(s) |
_________________ Yak-50 Display Pilot - Airshows - Яковлев Як-50
Yak-52 training anywhere - FI(A) Aerobatic Instructor - Specialised Yak-52.
https://www.yakoteam.com/
https://www.yakovlevs.com/the-team/pilots-and-crew/ |
