aluminium avionics panels
JohnFrance
PostPosted: Mon Aug 10, 2015 8:21 am    Post subject: aluminium avionics panels Reply with quote
Hello, I am looking to upgrade my avionics panel using the aluminium IM04 and IM05! panels. Does anyone have a plan of their profiles in (any format, dxf, solid works or pdf) that I can use to refine the layout please? hole cut-outs, shapes and sizes for all Europa switches, trim indicator etc would also be useful.
While I am at it, my present thinking is to use a Trig TY 91 radio and a Trig TT21 transponder and include a mount for a mini Ipad, but not flush fitting as I find it useful to be able to orientate the screen according to light direction and intensity.
If anyone has experience installing these components, especially where and how to install the electronic boxes for TT21 and TY 91 I would appreciate your feedback.
Europa mono Nr 192
rowlandcarson(at)gmail.co
PostPosted: Mon Aug 10, 2015 8:57 am    Post subject: aluminium avionics panels Reply with quote
John - have a look at:
http://www.rowlandcarson.org.uk/aviation/europa_435/radio_panel_trial_fit_2.php
http://www.rowlandcarson.org.uk/aviation/europa_435/panels_anodized.php
http://www.rowlandcarson.org.uk/aviation/europa_435/conduit_route.php
I used the factory-supplied radio blank panel and had it water-jet cut to my .DXF file, then after anodising had it laser-etched by another firm. More details available on my journal - use the search facility! Or come back to me direct if you can’t find what you’re looking for.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
peterz(at)zutrasoft.com
PostPosted: Mon Aug 10, 2015 9:11 am    Post subject: aluminium avionics panels Reply with quote
I can't help with locating the boxes, but can chime in with a super endorsement of the trig kit..... Awesome solid radios that not even my shaky hummelbird could do damage to. In my tiny bird I mounted them behind my seat bulkHead (the only feasible spot) which had the benefit of very short rf cable runs. I'm always 5x5.
For sure I will add a set (or at least the head units) to my Europa pile of parts getting into formation.
Pete
A239
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=445775#445775
Roland
PostPosted: Mon Aug 10, 2015 8:59 pm    Post subject: Re: aluminium avionics panels Reply with quote
Hi John,
I have made a whole new panel, however it's not "LAA-certified".
I could arrange a new kit (upper GFK-cover and Aluminium-panels/3 sections) for you at the shop in the Netherlands if you are interested.
Roland
PH-ZTI
XS Trigear 914
 Filesize:  1.62 MB
 Viewed:  6415 Time(s)
Rick Moss
PostPosted: Tue Aug 11, 2015 12:35 am    Post subject: Re: aluminium avionics panels Reply with quote
I bought the Europa aluminium blanks, and then cut what I needed out of carbon fibre.
 Filesize:  906.8 KB
 Viewed:  6402 Time(s)
