byoungplumbing(at)gmail.c Guest
Posted: Thu Aug 06, 2015 7:12 am Post subject: Kolb-List Digest: gap seal spring |
At the top of this picture is a side view at the right side there is a spring attach tab.  The spring goes under the 1 inch square tube to hold the gap seal down and back.   Lower in the picture is a top view that shows lateral position.  Â
Boyd Young
323.24 KB |
3863 Time(s) |
Flylawnchairs
Posted: Fri Aug 07, 2015 11:05 am Post subject: Re: Kolb-List Digest: gap seal spring |
Thanks Boyd, is there any way I could get a reprint of your plans or copy them and send them back to you. I would make it worth your while.
I talked with the factory and they say they don't have any plans for the 2004 mk3x.
Posted: Fri Aug 07, 2015 11:13 am Post subject: Kolb-List Digest: gap seal spring |
Boyd- If you are going to copy your plans, make two copies and send on to the factory for their records. I am sure they will appreciate it.
Bill Sullivan
Windsor Locks, Ct.
On Fri, 8/7/15, Flylawnchairs <Flylawnchairs(at)gmail.com> wrote:
Subject: Re: Kolb-List Digest: gap seal spring
Date: Friday, August 7, 2015, 3:05 PM
"Flylawnchairs" <Flylawnchairs(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=445676#445676
Forum -
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
