amekler
Posted: Fri Aug 07, 2015 8:38 am Post subject: removing seat |
I need to remove my front seat back for a upholstery repair
Can the seat back be removed or must I remove the whole seat?
What is easiest?
Alan
ps does anyone have a schematic of the seat?
Alan
N668G
330 hrs
Bob Turner
Posted: Fri Aug 07, 2015 9:08 am Post subject: Re: removing seat |
I imagine it can be done either way, but I'd remove the whole seat. With a small modification (shorten the rail, or bevel the front slide on the seat) you can remove the seat without removing the flap cover.
_________________ Bob Turner
RV-10 QB |
Posted: Fri Aug 07, 2015 9:21 am Post subject: removing seat |
Don't even try to remove the seat back. Take the whole seat out.
Carl
aerosport1
Posted: Fri Aug 07, 2015 9:52 am Post subject: removing seat |
You can remove the upper back pretty easy. Roll your seat cover up about 6-8
inches and then there are 4 1/4-28 screws with
Lock nuts remove these. Very easy. See photo They might be a little harder
to get to while in the aircraft
Geoff Combs
485.37 KB |
13475 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Fri Aug 07, 2015 11:33 am Post subject: removing seat |
I beveled the fwd upper part of the nylon insert back about 1/2" all the
way across (real thin at the fwd end) so the rear of the seat can be
lifted to clear the flap cover. No need to shorten the rail. I tapped
the mounting holes in the seat lock and used bolts to hold it in place.
Lift the seat cushion up and a ratchet makes quick work of the bolts.
You have to either remove the stop or the lock .....
Linn
On 8/7/2015 1:08 PM, Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=445672#445672
Checked by AVG - www.avg.com
amekler
Posted: Sat Aug 08, 2015 6:28 am Post subject: removing seat |
Does the seat remove forward or rear?
Alan
| Quote: | On Aug 7, 2015, at 1:08 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
Posted: Sat Aug 08, 2015 6:50 am Post subject: removing seat |
Rear.
You need to remove the seat stop spring pin for the seat to slide out.
You need to unscrew and move the flap operator cover below the rear seat to
get enough room for the seat to slide out of the rail.
Carl
Posted: Sat Aug 08, 2015 7:12 am Post subject: removing seat |
From a previous answer .....
On 8/8/2015 10:47 AM, Carl Froehlich wrote:
Rear.
I tapped the mounting holes in the seat lock bracket and used bolts to
hold it in place. Lift the seat cushion up and a ratchet makes quick
work of the bolts.
| Quote: | You need to unscrew and move the flap operator cover below the rear seat to
way across (real thin at the fwd end) so the rear of the seat rail can
be lifted to clear the flap cover.
Linn
Carl
amekler
Posted: Thu Aug 13, 2015 8:48 am Post subject: removing seat |
I took the seat out today
Could not get a socket wrench in so had to use an open end which made it tedious .
Any one come across a small socket set that would fit?
Alan
[quote] On Aug 7, 2015, at 1:18 PM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Carl
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Thu Aug 13, 2015 9:03 am Post subject: removing seat |
Would one of these fit?
On Thu, Aug 13, 2015 at 11:31 AM, Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
[quote]--> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)>
Alan
> On Aug 7, 2015, at 1:18 PM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
> --> RV10-List message posted by: "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)>
> Carl
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
schmoboy
Posted: Thu Aug 13, 2015 9:07 am Post subject: removing seat |
I ran into that issue also. I believe the carevout for the forward bolt
in the seat rail stop is too small to get a standard wall socket in
there. If I remember correctly, I purchased a set of thin wall sockets
and that did the trick.
-Sean #40303 (bird at the paint shop. pilot has lack of flying withdrawls)
| Quote: | Alan Mekler MD <mailto:amekler(at)metrocast.net>
August 13, 2015 at 11:31 AM
it tedious .
Alan
amekler
Posted: Thu Aug 13, 2015 9:14 am Post subject: removing seat |
I tried one of those the head was too big to fit onto the bolt
Alan
On Aug 13, 2015, at 12:59 PM, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
[quote]Would one of these fit?
Alan
> Carl
cooprv7(at)yahoo.com Guest
Posted: Thu Aug 13, 2015 9:18 am Post subject: removing seat |
I’ve used the ratchet wrenches a lot. I can’t remember if ti will work there, but they really make life easy when applicable. The quality brands are worth the extra $$.
Marcus
[quote] On Aug 14, 2015, at 1:31 AM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
> Carl
Tim Olson
Posted: Thu Aug 13, 2015 9:44 am Post subject: removing seat |
And, don't buy the ones that don't reverse. You can sometimes get stuck not being able to get the Wrench off, if you don't have the reversing ones.
[quote] On Aug 13, 2015, at 12:13 PM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:
Marcus
> Alan
> Sent from my iPhone
>> Carl
davidsoutpost(at)comcast. Guest
Posted: Thu Aug 13, 2015 12:40 pm Post subject: removing seat |
A thin wall 1/4" drive socket works great. I just ground a standard socket down to fit and keep it separated for just that purpose to remove the seat.
[quote] On Aug 13, 2015, at 12:31 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Alan
> Carl
amekler
Posted: Thu Aug 13, 2015 2:43 pm Post subject: removing seat |
sounds like the easiest way.
alan
| Quote: | On Aug 7, 2015, at 12:38 PM, amekler <amekler(at)metrocast.net> wrote:
What is easiest?
Alan
Alan
N668G
330 hrs
http://forums.matronics.com/viewtopic.php?p=445671#445671
Greg McFarlane
Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
Posted: Fri Aug 14, 2015 4:00 am Post subject: Re: removing seat |
RV10 Front Seat removal has been a topic that's generated a lot of interest Alan. FlyingNuts solution is the way I went with minor adjustments after others had worked it out. That is, cut 3/8inch off the top forward nylon runners, extend the two holes in the seat rail stops through the seat floor F1067A then fit two nut plates per seat under the seat floor for the seat stop bolts (need to be a little longer than originals) Now only two easy accessed bolts to remove the seat stop allows the seat to be removed rearward without the removal of T handles, Cushions or flap cover. JFYI there is a thread on VAF RV10 forum started in 2010 to 2015 that has been viewed about 5000 times and to date has generated 42 replies with pretty much everything known to man about RV10 front seat removal fleshed out. If interested search VAF RV10 forum "looking for seat rail mod" my post is number 36. Cheers from Western Australia
