nigel(at)yakdisplay.com Guest
Posted: Wed Jul 22, 2015 9:39 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
Asking the fount of all yak knowledge....
Pre-take off checks prop cycle check all fine (70% down to 53% three times).
On take-off, prop went to 110% and stayed there.
Moving the prop lever to full course made no difference to RPM.
Reduced power to bring RPM under control, abbreviated circuit and landed.
Have changed to governor - but appears to still be a problem.
Have had the prop off - and checked blades move freely, and oil is returned when blades are rotated.
Drive to governor appears to be ok (rotates when prop is turned).
Problem obviously appears to be when the prop is under load.
Can anyone shed any light, experience of happening before?
Clarification of my understanding would also be useful re what does what - i.e. oil pressure causes fine pitch, weights cause course pitch? In that case, is it a governor drive problem when under load? IS there a weak link in the drive system like the compressor?
Any ideas?
Nigel Willson
Flying Instructor/Examiner and Display Pilot
_________________________________________________
email: nigel(at)yakdisplay.com
mobile: (+44) 7809 116676
web: http://yakdisplay.com
GeorgeCoy
Posted: Wed Jul 22, 2015 9:50 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
check the clamps that secure the cable housing.
jan.mevis(at)informavia.b Guest
Posted: Wed Jul 22, 2015 10:10 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
That's a very good advise George. We had recently some RPM problems on our
Yak 52 because of that.
Jan
On 22/07/15 19:47, "George S. Coy" <owner-yak-list-server(at)matronics.com on
Posted: Wed Jul 22, 2015 10:19 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
Yup, done that. All secure....
Nigel Willson
GeorgeCoy
Posted: Wed Jul 22, 2015 10:48 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
When we had prop problems we could not figure out, I tapped into the oil line on the nose case and ran a 1/4 in hose to a pressure gauge and taped it to the cowl so I could see what was really happening with the oil pressure during flight. This was years ago when we were messing around with Hoffman props.
George
On Wed, Jul 22, 2015 at 2:07 PM, Jan Mevis <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)> wrote:
[quote]--> Yak-List message posted by: Jan Mevis <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)>
Jan
On 22/07/15 19:47, "George S. Coy" <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) on
behalf of george.coy(at)gmail.com (george.coy(at)gmail.com)> wrote:
>--> Yak-List message posted by: "George S. Coy" <george.coy(at)gmail.com (george.coy(at)gmail.com)>
trond.sorgard(at)gmail.co Guest
Posted: Mon Jul 27, 2015 4:23 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
Hello George
I have had also some problems with my propeller cycling earlier, Moving the prop lever to full course made no difference to RPM with me aswell.Â
But this was on the ground testing under run up.Â
I also has tapped into my cowl to check oil pressure in certain RPM handle positions. I had 220PSI with RPM handle fully foward.
And 0 PSI approx. when handle in full Course(aft). As it should be.
When the oil gets warm... real warm, then its able to cycle.
After i changed oil it became much better, but still im not happy.the oil needs to be real warm to cycle on ground run up.
And in aerobatic flights its not hundred prosent able to maintain RPM, lets say in a loop.
Â
George, what was the problem in your case? did you find it out?
Â
I have a Hoffman Prop also. I bought my Yak-52W from you and Cliff, from a former airline pilot in Washington. And you shipped it to me in Norway.
Any suggestion and thoughts?
Regards Trond Sørgård
Bergen, Norway.
2015-07-22 20:46 GMT+02:00 George Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)>:
[quote]When we had prop problems we could not figure out, I tapped into the oil line on the nose case and ran a 1/4 in hose to a pressure gauge and taped it to the cowl so I could see what was really happening with the oil pressure during flight. This was years ago when we were messing around with Hoffman props.
George
Jan
Posted: Mon Jul 27, 2015 4:25 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
Im might add, I have cheked the wire clamp, seems ok, and the governor is changed to a new one, as i thought that might be it.
Trond
richard.goode(at)russiana Guest
Posted: Mon Jul 27, 2015 5:20 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
The Russian  V-530 propeller needs 15 bar – pretty much your 220 PSI. However, the MT propeller needs 22 bar – around 330 PSI to change pitch quickly. You achieve this with stronger pressure control springs in the governor. I suspect that the same is true of the Hoffman.
Also, have you checked the oil filter going into the governor – if this is partially blocked, you will inevitably have pitch change problems.
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Trond Sørgård
Sent: Monday, July 27, 2015 5:49 PM
To: yak-list(at)matronics.com
Subject: Re: Yak52 - Prop/Governor problem - help/advice needed
Hello George
Bergen, Norway.
George
Jan
[quote]--> Yak-List message posted by: "George S. Coy" <george.coy(at)gmail.com (george.coy(at)gmail.com)>
Many times I have seen where the prop governor armis improperly
positioned. Not the stops. The position of the arm in relation to the
rotating shaft is critical. If the preload position of the rotating
shaft is incorrect (where the arm is attached along with the serrated
sleeve), it willcause the prop blades not to move to either full fine or
full coarse pitch. Proper adjustment procedure is in the M14 maintenance
manual.
Attached is the applicable task card.
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Description: |
 Download |
Filename: |
M14_Prop_Governor_Adjustment_on-engine.pdf |
Filesize: |
16.16 KB |
Downloaded: |
355 Time(s) |
Posted: Mon Jul 27, 2015 5:58 am Post subject: Yak52 - Prop/Governor problem - help/advice needed |
Turned out to be a slipping gasket blocking the oil return hole to the gallery.....
Nigel Willson
Flying Instructor / Examiner
Display Pilot
Tel. 07809 116676
Web. yakdisplay.com
Sent from my HTC One mini 2
----- Reply message -----
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Subject: Yak52 - Prop/Governor problem - help/advice needed
Date: Mon, Jul 27, 2015 14:35
manual.
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
> Im might add,
> Trond
> http://www.matronics.com/contribution
