Door gap size?
digidocs
PostPosted: Thu Jul 16, 2015 9:11 am    Post subject: Door gap size? Reply with quote
Hey list,
I'm mentally preparing for the great door edge fill/sand and I'm curious what size gap you'd recommend around the edge of the door---0.020", 0.040", 0.060"?
David
jeff(at)westcottpress.com
PostPosted: Thu Jul 16, 2015 10:32 am    Post subject: Door gap size? Reply with quote
finger nail...
[img]cid:6B4E747F-50A9-4A2C-B2EF-5EA23DDFBF4E[/img]
Jeff Carpenter
40304
On Jul 16, 2015, at 10:11 AM, digidocs wrote:
--> RV10-List message posted by: "digidocs" <junk(at)dcarr.org (junk(at)dcarr.org)>
Hey list,
David
http://forums.matronics.com/viewtopic.php?p=444824#444824
- The RV10-List -->   - MATRONICS WEB FORUMS -
http://www.matronics.com/co=================
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
 Filesize:  17.89 KB
 Viewed:  7583 Time(s)
carl.froehlich(at)verizon
PostPosted: Thu Jul 16, 2015 10:46 am    Post subject: Door gap size? Reply with quote
David,
Just walked down and measured mine - about 0.050.
For the last step in this I put a thin layer of mico over the entire door
and cabin top gap (door shut and locked). After it set up a little I took a
razor and cut along the gap. It needs to set up enough so it is like
cutting clay. After the mico cures then do a final sand. This provided a
means to have a very uniform and level fit.
This is also a good process to have a perfect oil door fit.
After all that - you then get to chase pin holes for a few weeks.
Carl
john(at)trollingers.com
PostPosted: Thu Jul 16, 2015 10:58 am    Post subject: Door gap size? Reply with quote
wow, that is great, mine is not near that...
On Thu, Jul 16, 2015 at 2:29 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
finger nail...
Jeff Carpenter
40304
Hey list,
David
Westcott Press
1121 Isabel Street
Burbank, CA 91506
[url=tel:818-861-7300]818-861-7300[/url]
 Filesize:  17.89 KB
 Viewed:  7582 Time(s)
civengpe
PostPosted: Thu Jul 16, 2015 11:06 am    Post subject: Door gap size? Reply with quote
You guys have some amazing fiberglass skills.  I think mine is +- .25"!
Shannon
On Thu, Jul 16, 2015 at 1:55 PM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
finger nail...
Jeff Carpenter
40304
Hey list,
David
Westcott Press
1121 Isabel Street
Burbank, CA 91506
 Filesize:  17.89 KB
 Viewed:  7581 Time(s)
speckter(at)comcast.net
PostPosted: Thu Jul 16, 2015 1:32 pm    Post subject: Door gap size? Reply with quote
digidocs
PostPosted: Thu Jul 16, 2015 9:06 pm    Post subject: Re: Door gap size? Reply with quote
Lot's of great information and quality work here! I think I'll shoot for .040" or so and see where it ends up.
David
rv10flyer
PostPosted: Fri Jul 17, 2015 7:23 pm    Post subject: Re: Door gap size? Reply with quote
I think mine is about .050-.060". Paint will close the gap some and you'll want some expansion room.
Wayne G.
