rossmickey(at)comcast.net Guest
Posted: Thu Jul 09, 2015 8:01 am Post subject: SL-15 Unswitched Audio Connection |
I have a SL-15 Audio Selector Panel that has two “unswitched” audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere.
My three options seem to be:
Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra)
Take out the connector that is in there for a speaker I am not using and use it. (Suggestions on how to remove the connector without buying the specified tool please)
Hook the EFIS audio line with the AOA audio line which may not work at all if one is loading the wire all the time.
Thanks so much,
Ross Mickey
N9PT
ARGOLDMAN(at)aol.com Guest
Posted: Thu Jul 09, 2015 8:35 am Post subject: SL-15 Unswitched Audio Connection |
the Molex 08-05-0301 itself is not a connector but refers to the finger spring contacts. They are , I believe gold plated and indeed are not available. Newark lists the following substitutes.
- 39X7518 - Product Range:6838 Series; For Use With:KK 6442, 41695 Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Tin; Contact Termination Type:Crimp ;RoHS Compliant: Yes
- 20H0074 - Product Range:6838 Series; For Use With:KK 6442, 41695 Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Tin; Contact Termination Type:Crimp ;RoHS Compliant: Yes
- 01E9145 - Product Range:KK Series; For Use With:KK Series Crimp Terminal Housings; Contact Gender:Socket; Contact Material:Brass; Contact Plating:Gold; Contact Termination Type:Crimp; Wire Size AWG Min:24AWG ;RoHS Compliant: Yes
The connector body , itself is also available and are listed with the above.
Since they are not gold plated (with the exception of the 01E9145, if the housing is not appropriate, I would use a slight smear of an anti oxidation grease on the connector. The connector body is readily available. If you look up the below numbers at digikey, I believe when you look at one of the selections, the bottom of the description will list what connector bodies are appropriate for that contact. You just have to do a little detective work.
In a message dated 7/9/2015 11:02:34 A.M. Central Daylight Time, rossmickey(at)comcast.net writes:
Posted: Thu Jul 09, 2015 8:51 am Post subject: SL-15 Unswitched Audio Connection |
If I recall correctly, the SL-15 is equivalent to the PS Engineering PMA7000 series (I have one of those).
I'll look to see if I have any additional/spare connectors as I wired mine. I recall they were on a metal tape and I simply cut off the ones I needed.....
Posted: Thu Jul 09, 2015 9:04 am Post subject: SL-15 Unswitched Audio Connection |
Yes, that is the one. Thanks.
ceengland7(at)gmail.com Guest
Posted: Thu Jul 09, 2015 10:15 am Post subject: SL-15 Unswitched Audio Connection |
On 7/9/2015 10:59 AM, Ross Home wrote:
| Quote: | <![endif]--> <![endif]-->
Thanks so much,
Ross Mickey
N9PT
| Is this it?
[img]cid:part1.02020807.03010906(at)gmail.com[/img]
If so, and I owned it, I'd solder wires to the edge connector to make a 'pigtail' connector using a dSub connector, with a strain relief to protect the wires. Those things are perfect examples of 'Aviation Quality'.
If you have that spare that can be moved, there's usually a little tab on the back side that prevents it from backing out. If you have something thin and narrow enough, you should be able to slide it in from the 'front' (non-wire) end and push the tab away from it's mating lock point in the shell.
6.09 KB |
4959 Time(s) |
billp(at)wwpc.com Guest
Posted: Thu Jul 09, 2015 11:14 am Post subject: SL-15 Unswitched Audio Connection |
Posted: Sun Jul 12, 2015 8:35 am Post subject: SL-15 Unswitched Audio Connection |
At 10:59 AM 7/9/2015, you wrote:
| Quote: | I have a SL-15 Audio Selector Panel that has two “unswitched” audio connections. One is hooked up to my AOA warning. I would like to use the other for the audio of the Advanced Flight System 5600 EFIS I am installing. The SL-15 uses Molex 08-05-0301 connectors which are discontinued and I cannot find them anywhere.
Find someone who has a connector I can purchase (failed so far but maybe one of you has an extra) |
How many pins are in these connectors?
That style of connector was received with considerable
excitement at Cessna . . . waaayyyy back when. For
a few years, we made up our own audio switching and
signal routing junction box utilizing the .156 spaced,
card edge connectors. They were the "Amp Leaf" from
Amp-Inc.
http://tinyurl.com/qbqndka
http://tinyurl.com/p2dfvfs
Later, others jumped in with their own offerings
. . . one of which was the KK series from Molex
http://tinyurl.com/7t6jjsc
Cessna got out of that activity after a few
years in favor of exploiting off-the-shelf
devices . . . that first experiment into
rudimentary avionics manufacturing had some
reliability issues. I wasn't directly involved
in the engineering gyrations . . . but I got
to observe it and write about it. There proved
to be other form-factors for bringing wires
off pc boards that were a quantum jump in
reliability for black-boxes on airplanes.
Nonetheless, King radio, Narco and others
produced a goodly number of devices with this
technology. The .156" card-edge has been
'not recommended for new design' for a very
long time.
This poses problems for exploiting the utility
of these venerable devices. Quite often, extending
the air-worthiness of these devices goes beyond
finding pins for adding features. What's a OBAM'er
to do when the existing connector has degraded to
one step above trash . . . or worse.
I've stroked new service life into several devices
by replacing the crimped pin connector with solder
flag connectors. Like this . . .
http://tinyurl.com/nbuab2a
Unfortunately, not ALL sizes are available but
with some creative application of time/effort and
JB weld, you can fabricate a connector of any desired
size that offers you all new pins. Check out all
the images in the third link above.
Bob . . . [quote][b]
Posted: Sun Jul 12, 2015 8:45 am Post subject: SL-15 Unswitched Audio Connection |
| Quote: | | If you have that spare that can be moved, there's usually a little tab on the back side that prevents it from backing out. If you have something thin and narrow enough, you should be able to slide it in from the 'front' (non-wire) end and push the tab away from it's mating lock point in the shell. |
Here's a DIY extraction tool
for the leaf-style card edge
connector pins.
http://tinyurl.com/nknv4bk
Made this from a pocket screwdriver
sacrificed to the task while on a
field-trip . . . A little creating
grinding will get you the right dimensions
for your target connector.
