NowackLinden(at)gmx.de Guest
Posted: Sat Jul 04, 2015 3:32 am Post subject: 4th of July in Germany! |
Good Morning, Group, especially to all US Lightning friends and owners!
This morning, 5.00AM EST, July 4th, when America was still asleep , with
beer and firework rockets still cold, a different 4th of July
celebration took place at Luetzellinden airfield.
The proved and tested team mounted the wings to my D-EGFL today , the
same team as in Jan 2012. Then we had slightly above freezing temps,
today it was 95°F !
The first pic shows wife Uli banging away at the spar bolt heads.
Successfully! See also friend Paul.
At this time I had the fuel lines already connected, so after bolting
the AOI bolts in I filled 20l / 5USG into the left tank, then we pulled
D-EGFL, which is also known as the "White Lightning" ( at least until I
decide to put some more foil design on) into the Hessian summer in
front of the hangar.
Fuel pressure was achieved with Main Fuel Pump and the assistance of
friend Paul who sat on the right wing in order to raise the left wing
and the initial fuel flow. After double checking the spark plug cables
leading to the right cylinders I climbed into the cockpit, switched fuel
pump and ECU on and - after taking a deep breath - pushed the starter
button. The ULPower390iS engine fired almost immediately and ran nicely.
A little coarse at first, but soon quite smooth - much smoother than
the late D-ELIY`s 4 cyl engine! All kept tight and well, the Fireworks
were exclusively internal and invisible !
So Uli and I will have a good reason to celebrate the 4th of July here.
Another important step - or even two steps on one day! - on the way to
the completion of my second Lightning.
You all have a great Independance Day!!
Gerd
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
vettin74(at)yahoo.com Guest
Posted: Sat Jul 04, 2015 7:08 am Post subject: 4th of July in Germany! |
Looking good! Let us all know how that CS prop works!
Nick
Arion
Quote: | On Jul 4, 2015, at 6:31 AM, Gerd + Uli Nowack <NowackLinden(at)gmx.de> wrote:
This morning, 5.00AM EST, July 4th, when America was still asleep , with beer and firework rockets still cold, a different 4th of July celebration took place at Luetzellinden airfield.
The proved and tested team mounted the wings to my D-EGFL today , the same team as in Jan 2012. Then we had slightly above freezing temps, today it was 95°F !
The first pic shows wife Uli banging away at the spar bolt heads. Successfully! See also friend Paul.
At this time I had the fuel lines already connected, so after bolting the AOI bolts in I filled 20l / 5USG into the left tank, then we pulled D-EGFL, which is also known as the "White Lightning" ( at least until I decide to put some more foil design on) into the Hessian summer in front of the hangar.
Fuel pressure was achieved with Main Fuel Pump and the assistance of friend Paul who sat on the right wing in order to raise the left wing and the initial fuel flow. After double checking the spark plug cables leading to the right cylinders I climbed into the cockpit, switched fuel pump and ECU on and - after taking a deep breath - pushed the starter button. The ULPower390iS engine fired almost immediately and ran nicely. A little coarse at first, but soon quite smooth - much smoother than the late D-ELIY`s 4 cyl engine! All kept tight and well, the Fireworks were exclusively internal and invisible !
So Uli and I will have a good reason to celebrate the 4th of July here. Another important step - or even two steps on one day! - on the way to the completion of my second Lightning.
Gerd
<4th of July in Germany 2.jpg>
<4th of July in Germany.jpg>
N1BZRich(at)AOL.COM Guest
Posted: Sat Jul 04, 2015 7:13 am Post subject: 4th of July in Germany! |
Looking great, Gerd. Congratulations on two major building milestones.
Hope to see you at Oshkosh.
Blue Skies,
Buz
In a message dated 7/4/2015 7:33:14 A.M. Eastern Daylight Time, NowackLinden(at)gmx.de writes:
Quote: | Good Morning, Group, especially to all US Lightning friends and owners!
today it was 95°F !
Gerd
n5pb(at)AOL.COM Guest
Posted: Sat Jul 04, 2015 10:21 am Post subject: 4th of July in Germany! |
Gerd,
Yes, we will celebrate with you today! So happy to hear you had a successful engine start. Thanks for the update and pics.
EGFL....mmmmm does this mean "Exceptionally Great Flying Lightning" ???
all the best to you and Uli.
Bear
dwwilt
Posted: Sat Jul 04, 2015 4:12 pm Post subject: 4th of July in Germany! |
Gerd,
Thanks for the update. Donna and I are on the road (if you can call the airways "the road". Congratulations on getting the wings installed.
Dennis
Quote: | On Jul 4, 2015, at 4:31 AM, Gerd + Uli Nowack <NowackLinden(at)gmx.de> wrote:
Gerd
_________________ Dennis |
