leblancds(at)cox.net Guest
Posted: Fri Jun 19, 2015 8:22 am Post subject: Conversion of Mark III to Xtra |
Hello Kolb Pilots, I’m new to Matronics. I have recently acquired a Mark III which I had planned to restore; however I found that the cage was bent beyond reasonable repair. What would it take to convert the Mark III to an Xtra?I assume I can reuse the MkIII boom, wings, tail feathers, new Rotax 582, etc. I’m not sure about the linkages for the ailerons, elevator, rudder, and flaps?? I also understand that the wing angle-of-attack needs to be changed and the lift struts are different in length. Also, not sure if MkIII gear can be reused. Any advice or recommendations will be appreciated.
Thanks, Dee LeBlanc
leblancds(at)cox.net (leblancds(at)cox.net)
The Past is History
The Future is a Mystery
Today is a Gift
That’s Why They Call it the Present
patrickjladd(at)hotmail.c Guest
Posted: Sat Jun 20, 2015 1:34 am Post subject: Conversion of Mark III to Xtra |
Why don`t you talk to the makers. They are nice people to deal with. Good luck Pat
Sent: Friday, June 19, 2015 5:22 PM
Subject: Conversion of Mark III to Xtra
Dee LeBlanc
The Past is History
Today is a Gift
Posted: Sat Jun 20, 2015 5:07 am Post subject: Conversion of Mark III to Xtra |
Thanks Pat, that's an obvious choice and I did that first. Just wanted more information on details and other builder experience.
Thanks again, Dee LeBlanc
The Past is History
Today is a Gift
| Quote: | On Jun 20, 2015, at 4:34 AM, Patrick Ladd <patrickjladd(at)hotmail.com (patrickjladd(at)hotmail.com)> wrote:
Thanks, Dee LeBlanc
The Past is History
Today is a Gift
