bob88
Posted: Fri Jun 19, 2015 11:00 am Post subject: More on the red cube... |
Has anyone with experience mounting the red cube between the servo and spider hanging free inline (no bracket, just suspended in the hose line)? This looks like it will take 45 deg fittings on the cube and it will hang at about a 45 deg uphill flow position. Seems like this is simplest way to go...
Posted: Fri Jun 19, 2015 11:21 am Post subject: More on the red cube... |
I'd be worried about engine vibration on an unsupported hose assembly
making the readings inaccurate.
Just thinking out loud.
Linn
On 6/19/2015 3:00 PM, bob88 wrote:
http://forums.matronics.com/viewtopic.php?p=443816#443816
Checked by AVG - www.avg.com
Dave Saylor
Posted: Fri Jun 19, 2015 1:19 pm Post subject: More on the red cube... |
I initially had mine like you're describing. Accuracy was fine but after a premature failure (400 hrs?) I mounted it to a bracket and it's been good for 1000+. I believe there's a note about orienting the wires upwards, not sure if that means straight up or mainly up.
FWIW, EI replaced my cube no questions asked.
- D
On Friday, June 19, 2015, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <[url=javascript:;]marty.crooks(at)comcast.net[/url]>
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
_________________ --Dave
KWVI |
rv10rob(at)gmail.com Guest
Posted: Fri Jun 19, 2015 2:16 pm Post subject: More on the red cube... |
The simplest way to go is to mount it in the tunnel, per plans. Perfectly accurate there (at least with my IO-540 w/ a standard FI system).
-Rob
On Fri, Jun 19, 2015 at 12:00 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
| Quote: | --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
kdb.rv10(at)gmail.com Guest
Posted: Fri Jun 19, 2015 2:21 pm Post subject: More on the red cube... |
I did that with a Floscan sensor. Put a 45 degree fitting in the fuel servo and wrapped the sensor and fuel line with fire sleeve. Works great. It should stay cooler than if mounted to the engine.
Kevin Belue
On Jun 19, 2015, at 2:00 PM, "bob88" <marty.crooks(at)comcast.net> wrote:
Kelly McMullen
Posted: Fri Jun 19, 2015 3:34 pm Post subject: More on the red cube... |
Remaining cool is not an issue with fuel flow sending units. The negative to mounting in the tunnel is that you are between fuel pumps, and with the boost pump off, the fuel is being sucked under negative pressure to the mechanical pump. The sending units are designed to operate under positive pressure. Best locations are either between mechanical pump and servo or between servo and spider. The former is required by the STC for type certificated aircraft, the latter most common on experimental. The unit is best suspended on a bracket attached to the engine, so that vibrations are in sync with the engine. If you are concerned about heat, mount it under the intake manifold, and cover it with fireshield.
On Fri, Jun 19, 2015 at 3:12 PM, Kevin Belue <kdb.rv10(at)gmail.com (kdb.rv10(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: Kevin Belue <kdb.rv10(at)gmail.com (kdb.rv10(at)gmail.com)>
Kevin Belue
On Jun 19, 2015, at 2:00 PM, "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
rv10flyer
Posted: Fri Jun 19, 2015 6:18 pm Post subject: Re: More on the red cube... |
Same here Rob, have not been off more than .5 gallon.
[quote="rv10rob(at)gmail.com"]The simplest way to go is to mount it in the tunnel, per plans. Perfectly accurate there (at least with my IO-540 w/ a standard FI system).
-Rob
On Fri, Jun 19, 2015 at 12:00 PM, bob88 <marty> wrote:
| Quote: | --> RV10-List message posted by: "bob88" <marty>
Rob Kochman
Woodinville, WA
_________________ Wayne G. |
Albert Gardner
Posted: Sat Jun 20, 2015 5:48 am Post subject: More on the red cube... |
I have the unit mounted in the tunnel as per Vans. No problems with accuracy
although variations in filling the tanks
can cause variations between calculated and actual amounts. In any case I'm
well satisfied with that location. I have a bottom cover into the tunnel
so I can quickly inspect the tunnel for leaks as well as clean the filter.
980 hours.
Albert Gardner
RV-10 N991RV
Yuma, AZ
(Little warm here but it's a dry heat)
_________________ RV-9A N872RV
RV-10 N991RV |
larkrv10(at)gmail.com Guest
Posted: Sat Jun 20, 2015 5:50 pm Post subject: More on the red cube... |
Bob88, I mounted mine on a piece of .050" thick SS plate just above the fuel servo. I copied Ivan Kristensen's example.
Rick
#40956
Southampton, Ont
On Fri, Jun 19, 2015 at 3:00 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List
_blank" rel="noreferrer">http://forums.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
chazking
Posted: Sun Jun 28, 2015 5:48 am Post subject: Red Cube - Floscan |
Initially, the floscan was in the tunnel & I was experiencing FF flucuations of 0.5 GPH, which made injector tuning "impossible!" After removing the floscan and replacing it with a red cube between the servo & distributor those fluctuations stopped & a good nozzle tune ensued!
1.86 MB |
22379 Time(s) |
1.86 MB |
22379 Time(s) |
Lenny Iszak
Posted: Mon Jun 29, 2015 2:18 pm Post subject: Re: More on the red cube... |
Does anyone have the lengths of the two hoses required to move the redcube between the servo and spider?
Lenny
Kelly McMullen
Posted: Mon Jun 29, 2015 5:00 pm Post subject: More on the red cube... |
I used about 4.5 inches and maybe 24", with the cube mounted to a fab'd bracket under the #1 intake tube.
On Mon, Jun 29, 2015 at 3:18 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
[quote]--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny
http://forums.matronics.com/viewtopic.php?p=444195#444195
KCHD |
Posted: Mon Jun 29, 2015 7:41 pm Post subject: More on the red cube... |
Lenny, Steve from Aircraft Specialty made all my oil and fuel hoses (great to deal with btw), my servo to red cube hose is 12", the red cube to spider is 21". Of course it kind of depends on the location of the flow transducer. Mine is on a SS bracket just under the case, almost identical to what Ivan Kristensen did.
Rick
On Mon, Jun 29, 2015 at 6:18 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
Lenny
TimRVator(at)comcast.net Guest
Posted: Tue Jun 30, 2015 5:03 am Post subject: More on the red cube... |
I recently moved mine to that location to improve fuel flow accuracy and
to try to improve a hot idle issue. AFP recommended the location
(suspended in the fuel line, not attached to engine). EI (the red cube
manufacturer) shows that mounting method (straight fittings, between
servo and spider, not attached directly to engine) on page 20 of the
install manual, buy-ei.com/wp-content/uploads/2013/06/*II*-*FP*-*5*.*pdf
I like the improved flow accuracy at the new location.
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 650 hrs
bob88 wrote on 6/19/2015 3:00 PM:
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Tue Jun 30, 2015 5:46 am Post subject: More on the red cube... |
Lenny,
I just marked where on that fuel line I wanted the RedCube and sent the original line to TSFlightLines. Tom put the fittings I needed on the original line. It fits great, and it was pretty cheap too. The only downside is that you're obviously not going to be flying when he has your fuel line!
Ed
On Mon, Jun 29, 2015 at 10:36 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote]Lenny, Steve from Aircraft Specialty made all my oil and fuel hoses (great to deal with btw), my servo to red cube hose is 12", the red cube to spider is 21". Of course it kind of depends on the location of the flow transducer. Mine is on a SS bracket just under the case, almost identical to what Ivan Kristensen did.
Rick
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
kearney
Posted: Tue Jun 30, 2015 6:48 am Post subject: More on the red cube... |
Hi
It is very easy to make your own fuel lines (braided steel) and put on fire sleeve. You can get all the kit you need at a local speed shop.
Cheers
Les
On Jun 30, 2015, at 07:43, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
[quote]Lenny,
Ed
| Quote: | Lenny, Steve from Aircraft Specialty made all my oil and fuel hoses (great to deal with btw), my servo to red cube hose is 12", the red cube to spider is 21". Of course it kind of depends on the location of the flow transducer. Mine is on a SS bracket just under the case, almost identical to what Ivan Kristensen did.
Rick
List"">http://www.matronics.com/Navigator?RV10-List
Lenny Iszak
Posted: Thu Jul 02, 2015 12:25 pm Post subject: Re: More on the red cube... |
Thanks for the lengths. Saves me from pulling my fancy plenum to take measurements...
I have the floscan in the tunnel and it's pretty accurate for calculating the fuel used, but it's bouncing around a lot for precise LOP adjustments.
Lenny
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
