Comm antenna on top
rvdave
PostPosted: Sun Jun 14, 2015 3:13 pm    Post subject: Comm antenna on top Reply with quote
I've noticed some have straight/angled antenna on top near vert stab, is this off centered or drilled through top stringer? Not sure how to go about that?
If directly centered and 1/2" hole for bnc does that compromise strength of stringer ( maybe not)? Also how to install a doubler in that area?
Dave Ford
Cadillac, MI
Kellym
PostPosted: Sun Jun 14, 2015 3:56 pm    Post subject: Comm antenna on top Reply with quote
Recommend that you not try to center it, but use the stiffener already
present with a doubler or add stiffener to doubler. No one will notice
that you are a 1/4" off center.
On the other hand I have had good performance from belly antennas, even
when on the ground.
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=443532#443532
Kelly McMullen
KCHD
carl.froehlich(at)verizon
PostPosted: Sun Jun 14, 2015 3:57 pm    Post subject: Comm antenna on top Reply with quote
Why would you want to do this?
Two bent whip comm antennas on the bottom is much less of an eyesore.
Carl
rvdave
PostPosted: Sun Jun 14, 2015 4:21 pm    Post subject: Re: Comm antenna on top Reply with quote
I know from my 6 with two belly antennae I get marginal coverage on the ground but great air coverage; also I'm considering future belly pod.
Dave Ford
Cadillac, MI
philperry9
PostPosted: Sun Jun 14, 2015 11:17 pm    Post subject: Comm antenna on top Reply with quote
As Kelly said, they can be offset to miss the stringer and still installed parallel with the airflow for minimal drag.
I built mine that way using a doubler on the inside of the skin and picking up the rivets on the stringer to strengthen the doubler.
I had to put a joggle in the doubler to do it, but there are other ways to pickup those rivets too. Just have to get a bit creative.
Phil
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=443538#443538
bill.peyton
PostPosted: Mon Jun 15, 2015 5:08 am    Post subject: Re: Comm antenna on top Reply with quote
At my airport the tower is far enough away that a bottom mounted antenna just would not cut it. I have a top mount and bottom mount.
Here is a photo of the doubler I constructed spanning the two stringers. What is missing in this photo is the tapered wedge that goes between the skin and the doubler. The antenna mounting bolts go through the skin, the tapered wedge, and the doubler.
The skin is not flat at this point and if you attach a doubler directly to the skin it will flatten the curved area of the skin.
 Filesize:  77.23 KB
 Viewed:  10624 Time(s)
WA0SYV
Aviation Partners, LLC
john(at)trollingers.com
PostPosted: Mon Jun 15, 2015 5:28 am    Post subject: Comm antenna on top Reply with quote
I have both my antennas on the belly of my 10 and have never had a problem reaching anyone on the ground.  They do stick out a little on each side as I have them back behind the steps.
On Mon, Jun 15, 2015 at 9:08 AM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
[quote]--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
WA0SYV
http://forums.matronics.com/viewtopic.php?p=443558#443558
http://forums.matronics.com//files/img_1263_169.jpg
PostPosted: Mon Jun 15, 2015 7:41 am    Post subject: Comm antenna on top Reply with quote
Not to argue the point as one can build as they wish.  For the others reading this thread and perhaps now worry about bottom mounted antenna performance, my experience is the same as John’s.  I’ve never had an issue with the bottom mounted bent whip communication antennas.  A specific data point was picking up my IFR clearance on the ground at KSET from St. Louis Approach located well off field.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Trollinger
Sent: Monday, June 15, 2015 9:25 AM
Subject: Re: Re: Comm antenna on top
WA0SYV
rene(at)felker.com
PostPosted: Mon Jun 15, 2015 7:52 am    Post subject: Comm antenna on top Reply with quote
I had problems at KSLC on 118.3.  I ended up moving one of my comm antennas to the top.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Monday, June 15, 2015 9:38 AM
Subject: RE: Re: Comm antenna on top
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Trollinger
WA0SYV
 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
bcondrey
PostPosted: Mon Jun 15, 2015 8:06 am    Post subject: Comm antenna on top Reply with quote
This is a recurring theme that pops its head up every few months.  Most have no issues at all with a pair of bent whips on the bottom, however most is not all.  It is usually also pointed in somewhere in the recurring thread that in those rare instances where there's an issue you can just use a cell phone.  That said, I have personally experienced the issue and one of the things I'm doing different on this plane (2nd RV-10) is putting one on top and one on bottom.  To each their own.
On Mon, Jun 15, 2015 at 10:38 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
Carl
WA0SYV
rv10flyer
PostPosted: Fri Jun 19, 2015 6:17 pm    Post subject: Re: Comm antenna on top Reply with quote
One on top of our fiberglass cabin cover and one under the tunnel. When I have reception issues with one, I switch to the other. I'd do it all the same again.
Wayne G.
