jodymorgan(at)earthlink.n Guest
Posted: Thu Jun 04, 2015 7:21 am Post subject: Need measurement on M3X with 912 |
Hey All,
I'm building a M3X planning to mount a Suzuki 4 cyl engine on it.
I need the distance from the center of the prop hub to the top of the main boom tube to see what I have to do to get the prop at the same height as the 912.
Hope that makes sense.
Jody
colin.scott.hudson(at)gma Guest
Posted: Thu Jun 04, 2015 11:46 am Post subject: Need measurement on M3X with 912 |
Jody I have a factory built M3X with a Jabiru 2200 in it. It's 38 1/4".
Scott Hudson
N424AL
On Jun 4, 2015, at 10:21 AM, jody morgan <jodymorgan(at)earthlink.net (jodymorgan(at)earthlink.net)> wrote:
[quote]Hey All,
Jody
Posted: Mon Jun 08, 2015 4:01 pm Post subject: Need measurement on M3X with 912 |
Hey All,Big Question?
Does the 912 need a prop hub extension when mounted to the M3C or M3X?
Wanting to mount the Suzuki 1.3 with Raven Redrive on the M3X I'm building, but the Raven Redrive will not accept a prop hub extension.
Trying to match the distance from the 912 to the prop without an extension to match the distance for the Suzuki, so if the 912 requires a prop hub extension when mounted to the M3X it would change my whole set up calculations or maybe eliminate the Suzuki with that Redrive.
Tried to look it up in the archives but haven't got that figured out yet.
If it does require a prop hub extension, how long of one does it need?
Thanks in advance for any help.
Jody
On Thu, Jun 4, 2015 at 8:21 AM, jody morgan <jodymorgan(at)earthlink.net (jodymorgan(at)earthlink.net)> wrote:
[quote]Hey All,
Jody
tp://forums.matronics.com
| [b]
Flylawnchairs
Posted: Tue Jul 07, 2015 7:30 am Post subject: Re: Need measurement on M3X with 912 |
Hi Jody, I'm building an mx3 also but am in the early stages. Can you tell me the location of your horizontal stab leading edge tube in relation to where it is mounted on the boom tube ? There seems to be a discrepancy in my construction manual ( 2004 ) to newer models. Thanks for any help you can give.
Gene Wilson
