juliandib(at)hotmail.com Guest
Posted: Sat Jul 01, 2006 9:08 pm Post subject: cht |
please, if somebody can give mi some information about this, i have a rocket
with a engine io-540 the temperature cht number 4 indicates up to 700°,the
egt is normal the spark plug and the comprssion is ok, it can be the
indicator the one that is wrong? or wath i nead to do?
tanks julian from mexico
| Quote: | From: Rocket-List Digest Server <rocket-list(at)matronics.com>
Reply-To: rocket-list(at)matronics.com
To: Rocket-List Digest List <rocket-list-digest(at)matronics.com>
Subject: Rocket-List Digest: 0 Msgs - 06/29/06
Date: Thu, 29 Jun 2006 23:57:32 -0700
Today's complete Rocket-List Digest can also be found in either of the
of the Rocket-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/rocket-list/Digest.Rocket-List.2006-06-29.html
Text Version:
http://www.matronics.com/digest/rocket-list/Digest.Rocket-List.2006-06-29.txt
Rocket-List Digest Archive
Total Messages Posted Thu 06/29/06: 0
Today's Message Index:
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
richard(at)riley.net Guest
Posted: Sat Jul 01, 2006 9:15 pm Post subject: cht |
Switch it with the #2 or #6 probe, see if the
high temperature reading stays with #4 or moves with the probe.
Alternatively, dip the probe in boiling water and see if you get 212 degrees.
At 10:04 PM 7/1/2006, you wrote:
about this, i have a rocket with a engine io-540
700°,the egt is normal the spark plug and the
comprssion is ok, it can be the indicator the
>HTML Version:
>Text Version:
Checked by AVG Anti-Virus.
Posted: Sun Jul 02, 2006 3:41 am Post subject: cht |
gracias amigo for this tip
julian
| Quote: | From: Richard Riley <richard(at)riley.net>
Subject: Re: cht
Date: Sat, 01 Jul 2006 22:14:42 -0700
Switch it with the #2 or #6 probe, see if the high temperature reading
degrees.
>rocket with a engine io-540 the temperature cht number 4 indicates up to
>700°,the egt is normal the spark plug and the comprssion is ok, it can be
>the indicator the one that is wrong? or wath i nead to do?
>>HTML Version:
>>Text Version:
>No virus found in this incoming message.
http://wiki.matronics.com
Posted: Sun Jul 02, 2006 4:37 pm Post subject: cht |
I should have added this. If you switch the
probe to a different cylinder, run it on the
ground to see if the high temperature follows the
probe. If your cyl head is really getting to 700
degrees you have a SERIOUS engine problem, and I
wouldn't fly the airplane again until you have figured this problem out.
It's probably the probe, if it was real the
engine probably would have died before this. But
strange things can happen - a Cont. 550 blew the
cyl off the case and caught on fire, but the
pilot said it kept running smoothly (It didn't end well).
At 04:38 AM 7/2/2006, you wrote:
julian
>Subject: Re: cht
>>information about this, i have a rocket with a
>>indicates up to 700°,the egt is normal the
>>>HTML Version:
>>>Text Version:
