Removing bolt from elevator control mechanism
Mcabbage
PostPosted: Wed Jun 03, 2015 3:49 pm    Post subject: Removing bolt from elevator control mechanism Reply with quote
Hi All
Just starting a rebuild of a new to me FS2 and I am in the process of disassembly.
I am trying to remove the bolt holding the elevator control mechanism to the elevator it is rusted stuck in place to the bolt and was wondering if i could cut the tubing and bolt and just replace the tubing that appears to be inserted threw the tubing attached to the elevator?
Are they supposed to sliding on each other? Mine are rusted together.
Rust never sleeps!
Thank you Mike
 Filesize:  1.32 MB
 Viewed:  11116 Time(s)
ceengland7(at)gmail.com
PostPosted: Wed Jun 03, 2015 4:42 pm    Post subject: Removing bolt from elevator control mechanism Reply with quote
On 6/3/2015 6:49 PM, Mcabbage wrote:
Hi All
Rust never sleeps!
Thank you Mike
Have you tried some of the more powerful rust dissolvers? (50-50 mix of
acetone and automatic transmission fluid works amazingly well.) If it
were mine, I'd also at least try a 2 jaw gear puller to see if it could
push the bolt out (after the home-built rust cutter treatment).
stuart(at)harnerfarm.net
PostPosted: Wed Jun 03, 2015 5:08 pm    Post subject: Removing bolt from elevator control mechanism Reply with quote
Yes, acetone/ATF is a fantastic mix. It takes time to soak through.
Also heat it with a torch and then cool it off. Heat/cool cycles work to
break the rust loose. Alternating the heat/cool, soak routine and be
patient, it will come loose!
Stuart
Mcabbage
PostPosted: Wed Jun 03, 2015 5:31 pm    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
Thanks will give it a try!
2007 Firestar 2 503 N203SD
Moster 185 Flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike & Northwing Stratus XP
Mcabbage
PostPosted: Thu Jun 04, 2015 4:51 pm    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
I finally cut them off with a die grinder after talking with Bryan
at Kolb. The tubing is just spacers so easily replaced.
However the remaining bolt is frozen inside the elevators so bad
I can't twist out the bolts even with vice grips! So I'm soaking in
the Acetone mix tonight hopefully I don't have to remake the elevators.
Thanks guys I appreciate the suggestions.
 Filesize:  1.29 MB
 Viewed:  11054 Time(s)
Richard Pike
PostPosted: Thu Jun 04, 2015 7:24 pm    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
https://imageresizer.codeplex.com/
http://windows.microsoft.com/en-us/windows-xp/help/digitalphotography/resize-digital-pictures
http://microsoft-powertoys-image-resizer.en.softonic.com/
Sigh...
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Mcabbage
PostPosted: Fri Jun 05, 2015 3:43 am    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
Thanks Richard.
Sorry guys pics easy to resize in windows not quite used to the android experience.
will resize in the future
Mcabbage
PostPosted: Fri Jun 05, 2015 4:33 am    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
Thanks Richard.
Sorry guys pics pretty easy for me to resize in windows not quite used to the android cellphone experience.
will resize in the future.
Mcabbage
PostPosted: Fri Jun 05, 2015 4:38 am    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
Testing I think I got it?
 Filesize:  83.73 KB
 Viewed:  11000 Time(s)
williamtsullivan(at)att.n
PostPosted: Fri Jun 05, 2015 4:43 am    Post subject: Removing bolt from elevator control mechanism Reply with quote
Looks good to me. When in doubt, or testing, put "do not archive" somewhere in your message. That way it won't tie up Matt's computer space.
Bill Sullivan
Windsor Locks, Ct.
FS 447
On Fri, 6/5/15, Mcabbage <Mc(at)americanbuilding.com> wrote:
Subject: Re: Removing bolt from elevator control mechanism
Date: Friday, June 5, 2015, 8:38 AM
"Mcabbage" <Mc(at)americanbuilding.com>
Moster 185 flattop PPG/Sky K2 Paraglider
Trike Buggy Soaring Trike &amp; Northwing Stratus XP
http://forums.matronics.com/viewtopic.php?p=443071#443071
http://forums.matronics.com//files/20150605_082838_751.jpg
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
Mcabbage
PostPosted: Sat Jun 13, 2015 9:04 am    Post subject: Re: Removing bolt from elevator control mechanism Reply with quote
Success! I tried a 5 inch bench vise but it was still not budging so I got a harbor freight bearing press and that did the trick.
thank you
