Heat Shrink Tubing Labeler?
billp(at)wwpc.com
PostPosted: Wed May 27, 2015 8:36 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
What are people using these days to label wires?
I use to print out labels on a spreadsheet, cut them out and slide them
under clear heat shrink tubing. That worked great. The tubing protected
the label from all sorts of bad things like water and other liquids one
finds around an airplane. I'm doing some major renovation and I'm
looking for an easier way but I still want to keep track of the wire ends.
I see now that there are tubing labelers that print on the outside of
the tubing. I'm wondering if anyone has had experience using these? Does
stuff like hydraulic fluid, oil, avgas or water mess up the label? What
size tubing to order for 18-22 AWG and 2x22 shielded?
Is there any wire list software that works with any of the labelers that
will print labels from the wire list without having to type it back in
again?
Thanks, Bill
ARGOLDMAN(at)aol.com
PostPosted: Wed May 27, 2015 8:48 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
Bill, I have one. It is a KROY. Prints on heat shrinkable tubing of various types.
I don't know if I would say that the markings are really permanent, however as I see some scuffing. I don't know how it would last with various fluids. I used it extensively in the beginning. Since I ran out of the relatively expensive tubing and am too lazy to reorder it, I have been labeling with hand written labels with a scotch tape overlay. The clear tubing seems to make more sense and be more permanent.
Rich
In a message dated 5/27/2015 11:37:46 A.M. Central Daylight Time, billp(at)wwpc.com writes:
--> AeroElectric-List message posted by: Bill Putney <billp(at)wwpc.com>
again?
Thanks, ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
Dave Saylor
PostPosted: Wed May 27, 2015 9:06 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
I've used two types of shrink-tube labelers.  One was a stand-alone device like a label printer, built-in keyboard, etc.  It was somewhat limited in what you can print but certainly got the point across.
The other was attached to a laptop and had basic word processing and graphics abilities, and the requisite learning curve.
Durability was never an issue although I haven't tested gas and oil.
Like printers, they both seem to rely more on media sales than hardware for their profit.  That was frustrating for a tightwad like me, and the fact that a lot of the tube got wasted as leader and trailer made it worse.
I found I can get satisfactory results using a fine Sharpie on other-than-black tube.
--Dave
On Wed, May 27, 2015 at 9:34 AM, Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
[quote]--> AeroElectric-List message posted by: Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)>
I use to print out labels on a spreadsheet, cut them out and slide them under clear heat shrink tubing. That worked great. The tubing protected the label from all sorts of bad things like water and other liquids one finds around an airplane. I'm doing some major renovation and I'm looking for an easier way but I still want to keep track of the wire ends.
I see now that there are tubing labelers that print on the outside of the tubing. I'm wondering if anyone has had experience using these? Does stuff like hydraulic fluid, oil, avgas or water mess up the label? What size tubing to order for 18-22 AWG and 2x22 shielded?
Is there any wire list software that works with any of the labelers that will print labels from the wire list without having to type it back in again?
Thanks, Bill
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
--Dave
KWVI
Dave Saylor
PostPosted: Wed May 27, 2015 9:08 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
PS-its a lot easier to write on if you get rolls of tubing that's ironed flat to begin with. --D
Thanks, Bill
--Dave
KWVI
tim2542(at)sbcglobal.net
PostPosted: Wed May 27, 2015 9:26 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
I have a K-sun Bee-3. It's done 4 planes now and still works fine.
The shrink tube prints just fine and has lasted 3 years now and I haven't notice any coming off or fading. I paid around a $100 IIRC. The cartridges are rather spendy, $35 or so each and you may need 2-3 to do a plane.
The trick is to print several labels at a time and then manually cut them, otherwise it spools off too much tubing between prints.
Thanks, Bill
Jim Berry
PostPosted: Wed May 27, 2015 9:31 am    Post subject: Re: Heat Shrink Tubing Labeler? Reply with quote
I used the Dymo Rhino Pro 5000 with their pricey heat shrink tubing. It works very well, and after 7-8 years the labels are holding up well; no evidence of deterioration, including firewall forward. There are ways to cut down on the before- and after- label waste that Dave referred to, but you can't eliminate it entirely.
billp(at)wwpc.com
PostPosted: Wed May 27, 2015 10:05 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
David, what labelers did you try? I've seen some that come with 5' length cartridges. Sounds like an expensive way to buy heat shrink tubing but then I guess my time is worth something...
Thanks, Bill
On 5/27/15 10:04, David Saylor wrote:
[quote] I've used two types of shrink-tube labelers.  One was a stand-alone device like a label printer, built-in keyboard, etc.  It was somewhat limited in what you can print but certainly got the point across.
--Dave
Thanks, Bill
billp(at)wwpc.com
PostPosted: Wed May 27, 2015 10:51 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
Will the 1/4" Rhino tape shrink down enough to be tight on 22 AWG Tefzel?
http://forums.matronics.com/viewtopic.php?p=442608#442608
Jim Berry
PostPosted: Wed May 27, 2015 11:20 am    Post subject: Re: Heat Shrink Tubing Labeler? Reply with quote
Yes, they will.
Dave Saylor
PostPosted: Wed May 27, 2015 11:30 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
Sorry, I don't recall the brands.  I do remember they both spit out a lot of unused tubing.  Like Tim said, if you print in batches the waste is much less.
--Dave
On Wed, May 27, 2015 at 11:04 AM, Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
[quote] David, what labelers did you try? I've seen some that come with 5' length cartridges. Sounds like an expensive way to buy heat shrink tubing but then I guess my time is worth something...
Thanks, Bill
--Dave
Thanks, Bill
--Dave
KWVI
Dave Saylor
PostPosted: Wed May 27, 2015 11:32 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
I don't think so.  I ended up with rolls of 1/4, 3/16, and 1/8 for the Sharpie method.  1/8 will fit all but the smallest wire you would label. --Dave
On Wed, May 27, 2015 at 11:50 AM, Bill Putney <billp(at)wwpc.com (billp(at)wwpc.com)> wrote:
--> AeroElectric-List message posted by: "Jim Berry" <tojimberry(at)gmail.com (tojimberry(at)gmail.com)>
--Dave
KWVI
rene(at)felker.com
PostPosted: Wed May 27, 2015 11:57 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
For the smallest wire you can put a piece of smaller heat shrink on first, then the larger printed one.
I ended up not doing any of that.  My panel was built by Stein so I have all the markings from his work and on my work now I just pay attention to wire color.
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Saylor
Sent: Wednesday, May 27, 2015 1:31 PM
To: aeroelectric-list
Subject: Re: Re: Heat Shrink Tubing Labeler?
enginerdy(at)gmail.com
The tricky thing about the dymo shrink tube size is that it is given as the FLAT width, AKA the printable size, rather than diameter. So 1/4” tube WILL NOT fit over 3/16” wire.
I think a formula that should work is
Diameter = (2/PI)*Width
Amazon claims it shrinks 3:1.
It works great, although the label can be partially rubbed off (lightened) with friction.
jhausch
PostPosted: Thu May 28, 2015 7:25 am    Post subject: Re: Heat Shrink Tubing Labeler? Reply with quote
I work in the industrial automation space. We are a distributor for Phoenix Contact located in WI.
Phoenix has a printing system called the "Marking Box". There are two printers in that kit - one for terminal block markers (cards of tiny tags) and one for roll material. The roll material can be placards, wrap labels, shrink tube, and many other types of labels...
Weblink:
https://www.phoenixcontact.com/online/portal/us?1dmy&urile=wcm%3apath%3a/usen/web/main/products/subcategory_pages/thermal_transfer_printers_p-12-01-04/6d229357-988b-41e3-963d-1411a53fb384
This video short of shows the kit
https://www.youtube.com/watch?v=SrzzS_tIObg
They have a nice "booklet" of sample materials for both printers, but, unfortunately, not a good way to look at all of what is available on their website. I've actually just emailed them and asked if there is a decent online resource showing the roll material available. If I get a reply, I will post that link here, too.
If you can find your local Phoenix distributor, ask them if they print roll material to order (some provide this service or can refer you to a customer of theirs who has the Marking Box). If so, ask for a sample booklet for the roll material and a catalog. You can then usually send them a spreadsheet (or, even better, a file for the printer made in the free SW used with the printers) and they can quote you a price to print the job.
If you are in the Upper Midwest (WI, MN, IA, N. IL, ND, SD, NE), I could provide this service, but let me first figure out if there is an easy way to pick out the right material for the job. Also, what is this worth to you? What's a fair price for you to send me a spreadsheet of desired labels and me to mail back those labels pre-printed..... (think in terms of what would be an acceptable "minimum charge" and what would be an acceptable "max charge per label")
Another major player in the wire labeling world is "Brady". Get friendly with an electrician who owns a handheld Brady labeler and maybe they would lend it out. Those print sticker-style wrap around labels, too.
If you have any friends that work in manufacturing, ask them for the name of their favorite controls integrator and/or panel shop. Those folks usually have the means of printing wire labels, too.
One last comment about sticky wrap around labels: They are available in many sizes and the printers can print very small. The labels usually have a print area and a clear area. When you wrap them on the wire, you start on the printed end so the clear then covers and protects the printed part. These are likely easier and cheaper to use than shrink tubing, but it is important to find the right size (just like with shrink tube) so you don't have a wrap label that is too big.
johnd(at)wlcwyo.com
PostPosted: Thu May 28, 2015 7:52 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
I have a Kroy which I bought used on e-bay. Good machine. I paid $75 including shipping. Heat shrink tubing tape that is used is somewhat pricey. You want to print everything you need a once so as not to have waste. There is quite a bit of space before and after a word is printed. If you have everything printed as a long sentence then the waste is at the beginning and end of that sentence.
Sent: Wednesday, May 27, 2015 1:29 PM
Subject: Re: AeroElectric-List: Heat Shrink Tubing Labeler?
--Dave
Thanks, Bill
--Dave
Thanks, Bill
  ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
donjohnston
PostPosted: Fri May 29, 2015 7:36 am    Post subject: Re: Heat Shrink Tubing Labeler? Reply with quote
I have the Rhino 4200. The heat shrink cartridges are a bit pricey. I pay around $20 for 5' of tubing. As others have mentioned, printing multiple labels on a single run will eliminate most of the waste. The 1/4" tubing will shrink down to 24AWG nicely. I haven't tried any wires smaller than that.
When I started, I created plain English labels.
http://www.velocity-xl.com/blog/wp-content/uploads/2013/10/2013-10-19-IMG_20131019_153845_468a.jpg
But this was going to get expensive. So I created a wire numbering scheme to reduce the length of the labels.
http://www.velocity-xl.com/blog/wp-content/uploads/2013/11/2013-11-06-IMG_20131106_095231_784.jpg
http://www.velocity-xl.com/blog/wp-content/uploads/2013/12/2013-12-13-IMG_20131213_101714_071.jpg
The downside of course is that it requires a key.
BobsV35B(at)aol.com
PostPosted: Sat May 30, 2015 7:05 am    Post subject: Heat Shrink Tubing Labeler? Reply with quote
Good Morning All,
If I may add a comment, the very best way to identify a wire is to print directly on the wire. When I did the wiring for my airplane about ten years ago, there were several shops that would run out the length of wire I specified with whatever numbers or symbols I requested. Not sure if anyone is now providing such a service.
It should be even easier today as the newest equipment has pre loaded reels of various sizes and it is all computer controlled.
The machines are way too expensive for a one off builder or for a small shop, but if you are near a big operator, the new wire marking machines are really nice and the product is well worth the money they charge.
Heat shrink tubing for numbers will add a lot of bulk to the bundle!
Happy Skies,
Old Bob
In a message dated 5/27/2015 2:30:59 P.M. Central Daylight Time, saylor.dave(at)gmail.com writes:
--Dave
Thanks, Bill
--Dave
Thanks, Bill
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
donjohnston
PostPosted: Sun May 31, 2015 6:00 am    Post subject: Re: Heat Shrink Tubing Labeler? Reply with quote
Do you know what these shops would charge for labeling wires?
The additional bulk with heat shrink tubing is minimal and I mitigated that by staggering the heat shrink tubing when I used it in bundles.
