glastar(at)gmx.net Guest
Posted: Thu May 21, 2015 3:31 am Post subject: Transpondertest |
Good morning folks,
I need some help in FAA regulations (being a Swiss).
FAR 43 Appendix F describes some transponder testing in order to be
compliant with FAR 91.413, which in itself redirects to 91.215a and
121.345 as well as 135.143 and there more redirections come into play.
Can someone explain me, if for a VFR only aircraft in the US with
Transponder equipped you need to perform a regular system check to be
compliant with the FAR's according to FAR 43 APP F?
Many thanks for your input on that.
Cheers Werner
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Thu May 21, 2015 4:27 am Post subject: Re: Transpondertest |
The transponder needs to be checked once every two years and an entry made in the aircraft log book. It does not matter if the aircraft is only flown VFR or IFR, the transponder still must be checked.
_________________ Joe Gores |
Kellym
Posted: Thu May 21, 2015 4:46 am Post subject: Transpondertest |
The difference between an IFR certification and VFR is with the
altimeter and transponder encoder checks(Mode C)..how many points they
are checked for tolerance between each other and a reference, certified
altimeter. The transponder and static system altimeter checks are
normally done together with the transponder check because of the
requirement for correspondence between the Mode C transponder output and
the altimeter reading. The IFR check takes longer because of the need to
check up to certified altitude, and consequently usually costs 2-3 times
a VFR certification.
It is possible for a US aircraft to not have Mode C encoder, and thus
only need certification of the Mode A output, but then it is restricted
generally from using certain airspace such as Class A,B&C as well as E
above 10,000 MSL. As Joe said, either way the transponder has to be
checked every 24 months.
On 5/21/2015 5:27 AM, user9253 wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=442398#442398
KCHD |
BobsV35B(at)aol.com Guest
Posted: Thu May 21, 2015 4:58 am Post subject: Transpondertest |
Good Morning Kelly.
We should remember that if we avoid Class A, B, & C and fly only below 10,000 feet unless in a mountainous area, we don't need any stinkin' Transponder. <G>
That means that we can fly in better than ninety percent of the USA without that particular expensive toy!
Just gotta stay roughly thirty miles away from those big cities.
Happy Skies,
Old Bob
Posted: Thu May 21, 2015 5:00 am Post subject: Transpondertest |
Ok thanks,
seems to be more stringent then under EASA where it is a recommendation
only.
With newer electronics I see the risk for malfunctioning being very low.
Would save some money.
Werner
On 21.05.2015 14:44, Kelly McMullen wrote:
Quote: |
<kellym(at)aviating.com>
certified altimeter. The transponder and static system altimeter
checks are normally done together with the transponder check because
of the requirement for correspondence between the Mode C transponder
output and the altimeter reading. The IFR check takes longer because
of the need to check up to certified altitude, and consequently
usually costs 2-3 times a VFR certification.
restricted generally from using certain airspace such as Class A,B&C
as well as E above 10,000 MSL. As Joe said, either way the transponder
has to be checked every 24 months.
> Joe Gores
ceengland7(at)gmail.com Guest
Posted: Thu May 21, 2015 5:17 am Post subject: Transpondertest |
On 5/21/2015 6:29 AM, Werner Schneider wrote:
Quote: |
<glastar(at)gmx.net>
Good morning folks,
Cheers Werner
The transponder must be checked every 2 years to remain in compliance.
Be sure to tell the shop that you just need a VFR certification; IFR is
a bit more involved.
ARGOLDMAN(at)aol.com Guest
Posted: Thu May 21, 2015 5:43 am Post subject: Transpondertest |
Probably has something to do with the fact that although you personally only fly VFR, you are flying, or may fly, in an environment in which IFR, flight flolowing and other services depend on accurate altitude reports (via transponder ) from all of the aircraft in the system .
Of course we all know that electronics never fail, that they are never installed correctly that they never vary in their response.
Maybe instead of thinking why should I do it, you should think of if my setup is inaccurate and ATC or whoever is looking doesn't have a proper idea of my altitude perhaps that unseen shadow coming from my rear is made of aluminum or glass with everybody thinking that the different altitude reports are correct. As imperfect as the system is, it just may save your bacon.
Hell, if you are really against the testing, you really don't need a transponder at all in uncontrolled airspace and if you want to go into some controlled airspace and are not required to have a transponder (certain incidences) you can arrange that.---- Is it worth the trouble for $1-200.00 per year?
Rich
In a message dated 5/21/2015 6:32:18 A.M. Central Daylight Time, glastar(at)gmx.net writes:
Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
Good morning folks,
Cheers ========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Kellym
Posted: Thu May 21, 2015 5:44 am Post subject: Transpondertest |
Good morning Old Bob,
Yes, I guess that is what I was trying to say. I don't know how
tolerant ATC in the lower 48 would be to flying IFR without a
transponder. I did that for about 5 yrs in Alaska, before I added the
transponder, because about 1/3 of the IFR flights I did went through
non-radar areas anyway. I didn't add an encoder until I moved to the
lower 48 and knew I would be basing underneath a Mode C veil. Getting
above 10,000 IFR in the C170B I had was pretty marginal anyway as it
would only do about 13,500 with the cruise prop it had.
These days, if I needed to make cross country trips of any distance, it
would involve more evasion of Mode C areas, especially through the
Rockies where the major roads and valleys seem to have either Class B or
C areas. I'm not fond of the $250 it costs me for IFR certification of
the static system and transponder, but over a couple years I would
probably save that much gas by having all options available. Not mention
the equipment was in the Mooney when I bought it. Narco AT-50 still
going strong with an old TransCal bellows blind encoder.
Kelly
Transponder. <G>
Happy Skies,
Old Bob
KCHD |
Posted: Thu May 21, 2015 6:17 am Post subject: Transpondertest |
Rich,
I'm not against testing in general, but I have a transponder with
altitude readout, 3 different independent altimeters, I can compare that
against (plus GPS) and I fly regularly in ATC controlled space with
active radar coverage so I see general a pretty good testing of my
output and will get immediate attention of ATC if something goes wrong.
And I'm very interested in everybody having a transponder output as it
does enhance safety. If you remember the Gillham Encoders had a partial
fail rate and a seperate AD for testing which made sense.
Werner
Quote: | Hell, if you are really against the testing, you really don't need a
Rich
Kellym
Posted: Thu May 21, 2015 7:12 am Post subject: Transpondertest |
From what I have seen, the old transponders with cavity tubes needed
testing and every 6-10 years would need to be tuned up with the aging
of the cavity tube. When mine was off, some ATC radars would see it,
others not, or with 1200 instead of assigned code. After tuning, has
been perfect.
I don't have enough experience with solid state transponders, but my
guess is they don't need testing, and probably hard fail or continue
working. Probably will take FAA 30 yrs to realize that and another 10
years to amend the rules.
On 5/21/2015 7:15 AM, Werner Schneider wrote:
Rich,
that against (plus GPS) and I fly regularly in ATC controlled space
with active radar coverage so I see general a pretty good testing of
my output and will get immediate attention of ATC if something goes
wrong.
partial fail rate and a seperate AD for testing which made sense.
Werner
> Rich
KCHD |
Posted: Thu May 21, 2015 7:31 am Post subject: Transpondertest |
All of which may be true.
And, please, Werner, don't consider this as a personal note toward you and your setup... such is not intended.
Lesee-- 3 different independent altimeters?? I assume that these are all connected to their own static system and there is no commonality in plumbing or location of static port(s). I also assume that they each have separately been checked for accuracy. I will also have to assume that your GPS is WAAS. If they all agree then your indications are probably accurate--------------
However the ATC does not depend on your indication which is, of course determined by however you set your Kollsman window either correctly or incorrectly, and static system error (including undetected leaks).
What they see on their scopes may be quite different than your indication in that they look at more absolute numbers not depending on what your indication are and not depending on the local baro setting. If memory serves me correctly, part of the examination includes making a table of inaccuracies to determine if the entire system is within limits.
That is why there is not barometric setting on an encoder.(available to the pilot)
All of the aircraft may be off of their indicated altitude but they will all be off by the same amount and thus their relative altitude indication is taken away from the possible error of the pilot and/or many other sources.
Rich
In a message dated 5/21/2015 9:19:50 A.M. Central Daylight Time, glastar(at)gmx.net writes:
Rich,
Werner
========================bsp; = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Thu May 21, 2015 7:38 am Post subject: Transpondertest |
Again, the testing is not specifically for the transponder, or the encoder but is a total system check including the static system.
Interestingly enough, if the transponder is removed from it's mounting, at any time after an inspection, I believe that the testing has to be redone.
Rich
In a message dated 5/21/2015 10:13:25 A.M. Central Daylight Time, kellym(at)aviating.com writes:
Quote: | --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com>
been perfect.
Rich,
wrong.
Werner
> ================================================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
art(at)zemon.name Guest
Posted: Fri May 22, 2015 3:55 am Post subject: Transpondertest |
Folks,
Sometimes the transponder test finds failures in the pneumatic tubing or in the antenna. It's not a bad safety investment, since we all share the sky, IMHO.
-- Art Z.
--http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
Kellym
Posted: Fri May 22, 2015 6:52 am Post subject: Transpondertest |
Just to be clear....what is tested depends on what the aircraft has
installed, and its desired use.
There are aircraft that have transponders without an altitude
encoder...only the transponder signal output is tested. There are VFR
only aircraft with transponder and encoder, where the transponder with
Mode C output is looked at to match altimeter at field elevation and
maybe one more altitude. There are IFR aircraft with transponder and
encoder that need certification of the altimeter, encoder and static
system at 500 ft intervals up to max certified altitude.
To show that they are related but separate...if a transponder is removed
for repair/alignment or to just clean the contacts, only a ramp check of
the transponder output is needed.
If an IFR aircraft needs the static system opened, to replace something,
repair a line, etc. the A&P doing the work can do a simple leak
check...no repeat of full static system is required.
Two most common failures I have seen are static system plumbing leaks
(including instrument housing leaks), and coax to the antenna failure.
Antennas rarely fail for anything other than physical damage.
On 5/22/2015 4:53 AM, Art Zemon wrote:
Quote: |
Folks,
-- Art Z.
what am I? And if not now, when?" Hillel/
KCHD |
