pipercolt
Joined: 08 Jan 2012 Posts: 46 Location: Randolph New York
Posted: Sat Apr 11, 2015 6:02 pm Post subject: Re: MK 111 rebuild |
Hi All
I just looked in my airframe logbook and it says that if it is flown solo, the pilot must weigh at least 195 lbs. That is with the pizza cutter tail wheel. I am removing that one and installing one that weighs about twice as much. I have not run the numbers yet but I am guessing that the pilot will have to be well over 200 lbs to stay within limits. As far as the battery goes, on my snowmobile forum there is a lot of talk of light weight batteries that work well if it isn't real cold out.
Richard Pike
Posted: Sun Apr 12, 2015 6:35 am Post subject: Re: MK 111 rebuild |
I got one of those batteries, and it is awesome! Shorai Lithium Iron battery, 14 Amp Hour, 210 CCA, and weighs 1.5 pounds.
That's right, 1.5 pounds. With that little weight, you won't have to do a great deal of reinforcing if you move it to the nose.
http://oh2fly.net/oldpoops/pg9.htm
However, I did add a master cut off switch that isolates the battery from everything, like the dragsters use, and turn it off and on every time I do anything with the airplane, because if you ever totally discharge one of those batteries, it is toast. About $150 worth of toast.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sun Apr 12, 2015 6:42 am Post subject: MK 111 rebuild |
You'll have more weight in cable than battery if it is relocated to the
nose.
I think the numbers on a Kolb W&B weigh more than the actual "aft CG"
problem.
_________________ John Hauck
Titus, Alabama |
neilsenrm(at)gmail.com Guest
Posted: Sun Apr 12, 2015 10:22 am Post subject: MK 111 rebuild |
John
I figure my battery cables are two-three feet longer attaching to my nose cone mounted battery than they would be if they were attached to the battery behind the seat. What size cables do you use. Figuring three feet of cable weighing more than a 12-14 lb battery, those must be mighty big cables.
I also switched to a Lithium Iron battery (another brand also less than 2 lb) last summer. The cables are still less than half the weight of that battery. The two lb. battery and app one pound of cables still helps my weight and balance.
Rick Neilsen
Redrive VW powered MKIIIC
On Sun, Apr 12, 2015 at 10:41 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
nose.
problem.
pipercolt
Posted: Sun Apr 12, 2015 12:28 pm Post subject: Re: MK 111 rebuild |
Hi Neil
What size battery cable did you use? Yes Richard, that is the battery I was thinking of. Isn't it funny how many years ago when I was flying corporate we used NiCad batteries and every so often we totally discharged them and then recharged them. How theories have changed.
Bob
pipercolt
Hi Neil
Bob
Posted: Sun Apr 12, 2015 3:43 pm Post subject: MK 111 rebuild |
Well……reckon I should have put smiley faces on my post, or some such.
Why would someone put the battery in the nose if it is not necessary?
Why would someone put a 2 lb bat in the nose and run extra battery cable? Cost more, weighs more, and every inch means a little more voltage drop.
Remember, my comments are for myself. I don't care what you all do with your airplanes.
I find it amusing that folks add weight to the nose of a Kolb, but bust their ass to try and save a couple washers to reduce weight.
This comment below goes right along with the subject above.
Miss P'fer is on her newly overhauled gear. Brian did a super job of straightening the sagging twisted gear legs. She looks and sits like she did when she was new. Still have to put the seats back in, hook up the power pack for the Whelen Strobes, and replace a bunch of tie wraps that got cut to remove and replace the wheels, brakes, and gear legs. Never goes back together easy after it is cut apart and welded, but Dennis did a great job and I was able to get all the bolts back in. Sure feels good.
Now I need some good weather to clean her up and do a lot of test flying, for me and the airplane. Forecast rain all week at hauck's holler.
Plan to depart to Lakeland Monday, 20 April. Hope to see a bunch of you all down there.
BTW: I don't know how much my battery weighs or how big the battery cables are, but I can pick them up with two hands if I grunt a little.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Rick Neilsen
Sent: Sunday, April 12, 2015 1:23 PM
Subject: Re: Re: MK 111 rebuild
John
Rick Neilsen
nose.
problem.
Titus, Alabama |
Richard Pike
Posted: Mon Apr 13, 2015 5:47 am Post subject: Re: MK 111 rebuild |
| pipercolt wrote: | Hi Neil
Bob |
I had a friend at a car sound system shop sell me some of this at a good price: http://www.americanbassusa.com/categories/power---speaker-wires.htm
I have never seen wire cable like this before, it uses extremely small fine wires woven together, it is almost as limp as rope. I used 8 gauge, soldered the end fittings on and it seems to work fine - for 18 years so far.
Kingsport, TN 3TN0
ceengland7(at)gmail.com Guest
Posted: Mon Apr 13, 2015 6:25 am Post subject: MK 111 rebuild |
On 4/13/2015 8:47 AM, Richard Pike wrote:
pipercolt wrote:
> Hi Neil
> Bob
I have never seen large diameter wire like this before, it uses extremely small fine wires woven together, it is almost as limp as rope. I used 8 gauge, soldered the end fittings on and it seems to work fine.
Richard Pike
Kingsport, TN 3TN0
There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.'
That's how welding cable is made, with the bonus of having durable
insulation that's probably a lot more fire resistant than the stuff on
that speaker wire. Very common to see welding cable used for
battery/starter wire in big...(sorry, John) heavier homebuilts.
Available in various sizes from any local welding supply shop.
Charlie
Posted: Mon Apr 13, 2015 6:57 am Post subject: MK 111 rebuild |
My MKIII must be an antique. I bought battery cable from Aircraft Spruce in
1991. It is aviation grade with a woven fabric chafe guard.
Looked for battery cable at Aircraft Spruce before writing this post. They
don't have anything that resembles the cable I am using. Guess it is a
thing of the past. All they have is what looks like normal 4 and 8 ga
cable.
Could hand prop the 80 horse 912, although it was still risky and not easy
to do because of the sharp edges of the blades. Hand propping the 912ULS is
out of the question with higher compression ratio on top of the gear
reduction. It is extremely important for me to be able to rely on battery
start. Want to make sure I have a system that is going to perform and get
stuck out in the boondocks somewhere.
On occasion I have failed to turn off the Master Switch and run the battery
down. If it gets near depletion the alternator will not pick up the charge.
One year at Sun and Fun I had a helper turn on my Master Switch, or I
accidentally hit the toggle switch with my toe getting out of the aircraft.
I got a jump start to get home, but was not able to get the alternator to
pick up the charge. I flew 425 miles with no electrical system. Radio was
able to operate on its integral battery. GPS on its batteries. Lost all my
electric engine instruments. All was well until I got to Headland, AL, to
refuel. No one at the airport to help me. Could not shut the engine down.
Was able to get close enough to the gas pump to get a chock with my foot,
while I kept the aircraft from rolling away. Refueled hot, which I did most
of the time in VN, and made the remainder of the flight back to Gantt IAP
without incident.
insulation that's probably a lot more fire resistant than the stuff on that
speaker wire. Very common to see welding cable used for battery/starter wire
Charlie
Titus, Alabama |
Richard Pike
Posted: Mon Apr 13, 2015 3:17 pm Post subject: Re: MK 111 rebuild |
Hard core John, hard core. Good on ya, do what you have to do. I guess I am spoiled, the 582 is a jewel when it comes to hand start.
Kingsport, TN 3TN0
pipercolt
Posted: Mon Apr 13, 2015 4:14 pm Post subject: Re: MK 111 rebuild |
Thanks Richard for your last comment about hand propping the 582. I was just about to post that question.
Bob
