matronics.list(at)gmail.c Guest
Posted: Wed Feb 25, 2015 2:27 pm Post subject: Shield grounds |
I thought I understood how shield grounds worked and how to implement them but now looking at a Garmin G3X. The garmin manual specifically has some of the shields terminated on both ends and grounded. some of the shields are only terminated and grounder on one end and the other is floating. So what is the proper termination of shields and what is the science behind the proper methods.
John Snapp
( excuse the typos. This email was sent from a mobile device!)
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Thu Feb 26, 2015 6:22 am Post subject: Re: Shield grounds |
Here is the ultimate authority on the subject:
http://eeeic.eu/proc/papers/55.pdf
Also see my attachment on the subject.
 Download |
| Filename: |
Dabbling with Electricity.pdf |
248.25 KB |
| Downloaded: |
408 Time(s) |
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Thu Feb 26, 2015 6:52 am Post subject: Shield grounds |
At 16:26 2015-02-25, you wrote:
<matronics.list(at)gmail.com>
The 'shielding' feature of a conductor
wrapped about a central wire or collection
of wires is to break potential electro-static
coupling between said wires and any other
wires.
Wires inside a shield can be EITHER a potential
antagonist (like p-leads) or victim (audio
wires). Shielding allows potential victims and
antagonists to share the same wire bundles.
Since the shield is also a conductor, the system
designer may . . . and often does . . . use
the shield for both electro-static barrier
AND as some functional flow of energy from
one item to another. Obviously, in this
case BOTH ends of a shield may be terminated.
Sometimes, shielded wire is used as two conductor
cable and both ends of the shield are terminated
even if wires within the shielding are neither
potential victim or antagonist. I have used
shielded wire to build flying leads off an LED
annunciators to exploit the nice round characteristic
of the shielded wire versus say, an open twisted
pair. I have used shielded trios to wire a 4-conductor
power/control path even tho the shielding is
not REQUIRED . . . only handy.
When the shield is applied ONLY for a barrier
to electro-static coupling, the general practice
is to terminate ONE END only. Terminating the
other end may not be a bad idea but it is
unnecessary and offers a low risk for creating
a 'ground loop' that was not foreseen by the
installer . . . or perhaps event the system
designer.
Bottom line: Don't second guess the system
designer. Wire per installation instructions.
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Sat Apr 11, 2015 2:55 pm Post subject: Re: Shield grounds |
Interesting discussion on VansAirforce
Posted by Richard
| Quote: | | General rule is: If you want to keep EMI inside the cable, ground both ends. If you want to keep the EMI outside the cable, ground one end. |
Reply by Louis | Quote: | This isn't really the case. Terminating the shield at one point vs. multiple depends on the electromagnetic coupling mode you're trying to defend against (electric or magnetic)[1]. Electric coupling is a function of the capacitance across the insulator between the signal wire and the shield[2], while magnetic coupling is picked up by the loop formed by the cable and the ground plane[1].
Low frequency signals interfere via magnetic coupling, and high frequency signals via electric[1][2]. Therefore, when trying to defend against low frequency interference (like when you're trying to protect a low frequency audio signal), you use single point shield termination to avoid creating a loop/current path for magnetic coupling to occur. For high frequencies, it's important to reduce the voltage accumulating on the shield, so multiple grounding points are used[2].
[1] Fröbel, Anke. "Cable Shielding to Minimize Electromagnetic Interference." Cotbus University of Technology, Germany.
http://eeeic.org/proc/papers/55.pdf
[2] Renner, E. NAVSO P-3181 Aircraft and Avionics Cabling E3 Design Manufacturing Guidelines. U.S. Navy, 1992 para 4.3
http://bmpcoe.org/library/books/navso%20p-3181/53.html |
_________________ Joe Gores |
Posted: Sat Apr 11, 2015 3:15 pm Post subject: Shield grounds |
At 17:55 2015-04-11, you wrote:
Posted by Richard
"Keeping the EMI inside the cable" is the same task
as "keeping the EMI from getting INTO the cable.:"
Shielding can only break the electro-static coupling
mode of transferring EMI from antagonist to victim . . .
and shielding EITHER wire will do the task. Furhter,
the currents that flow in the shield are exceedingly
tiny . . . easy to calculate but very difficult to
measure. Hence, the pig-tail that brings a shield to
chassis ground COULD be a 40 AWG wire without degrading
the shield's performance.
Both of the documents cited use the term "EMI"
and "shielded cable" but the discussions and
energy propagation models immediately jump into
the realm of transmission lines and frequencies
of interest of a Mhz and up . . .
Almost NONE of what is discussed in those papers
applies to why wires may be shielded in light
aircraft navigation and audio systems. If we
were designing for resistance to nuclear EMP
then the electro-magnetic coupling modes would
have some significance . . . but understand
also that the appliance designs and system integration
problems go wAAAAYYyyyy beyond any fussing with
shielded wires.
I don't find much to argue with in those documents
except that they don't apply to what we do. As
cited many times in the past . . . follow the
installation manual's instructions first. If
there are doubts, determine IF the shield conductor
is ALSO part of a signal/power path. If so
attach both ends. If not, attach one end only.
